Discuss
Overload, Relay, Capacitor Replaced What Next?
 in
Refrigerator & Freezer Repair
Kitchenaid Built-in model KSSS42MDX00 aprox 10 years old but new compressor installed last year (kitchenaid has 12 year sealed system
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Overload, Relay, Capacitor Replaced What Next?
  #1 (permalink)
Old 11-16-2009, 03:56 PM
Junior Member
lrich002 is on a distinguished road
Default Overload, Relay, Capacitor Replaced What Next?
Model Number: KSSS42MDX00   Brand: Kitchen Aid   Age: 5 - 10 years
Kitchenaid Built-in model KSSS42MDX00 aprox 10 years old but new compressor installed last year (kitchenaid has 12 year sealed system warranty on this model). Not cooling poperly so I replaced the relay the overload and now the capacitor. All parts were original factory or authorized replacement parts. After replacing the cap the frig ran good for one day making ice both freezer and frig cold so I though problem solved. Next day compressor not on freezer getting warm...warmer....I thought it might be a defrost issue since the compressor was not on at the time. I checked the defrost by turning it till it clicked turned again click made sure the compressor came on and off. The compressor does come on but not cooling. I'm at a loss here....any suggestions?
Ads By Google
Related Models
Whirlpool KSSS42MDX00
Whirlpool KSSS42MDX02
Whirlpool KSSS42MDX03
Whirlpool KSSS42MDX04
Whirlpool KSSS42MDX05
Whirlpool KSSS42MHB00
Whirlpool KSSS42MHT00
Whirlpool KSSS42MHW00
Whirlpool KSSS42MHX00
Whirlpool KSSS42MWX00
Whirlpool KSSS42MWX01
Whirlpool KSSS42QDW00
Whirlpool KSSS42QDW02
Whirlpool KSSS42QDW03
Whirlpool KSSS42QDW04
Whirlpool KSSS42QDW05
Whirlpool KSSS42QDX00
Whirlpool KSSS42QDX02
Whirlpool KSSS42QDX03
Whirlpool KSSS42QDX04
Whirlpool KSSS42QDX05
Whirlpool KSSS42QHB00
Whirlpool KSSS42QHT00
Whirlpool KSSS42QHW00
Whirlpool KSSS42QHX00
Whirlpool KSSS42QJB00
Whirlpool KSSS42QJT00
Whirlpool KSSS42QJW00
Whirlpool KSSS42QJX00
Whirlpool KSSS42QKB00
Whirlpool KSSS42QKB01
Whirlpool KSSS42QKB02 42" Built in Refrigerator
Whirlpool KSSS42QKT00
Whirlpool KSSS42QKT01
Whirlpool KSSS42QKT02 42" Built in Refrigerator
Whirlpool KSSS42QKW00
Whirlpool KSSS42QKW01
Whirlpool KSSS42QKW02 42" Built in Refrigerator
Whirlpool KSSS42QKX00
Whirlpool KSSS42QKX01
Whirlpool KSSS42QKX02 42" Built in Refrigerator
Whirlpool KSSS42QMB00 42" Built in Refrigerator
Whirlpool KSSS42QMB01 42" Built in Refrigerator
Whirlpool KSSS42QMB02 42" Built in Refrigerator
Whirlpool KSSS42QMB03 42" Built in Refrigerator
Whirlpool KSSS42QMW00 42" Built in Refrigerator
Whirlpool KSSS42QMW01 42" Built in Refrigerator
Whirlpool KSSS42QMW02 42" Built in Refrigerator
Whirlpool KSSS42QMW03 42" Built in Refrigerator
Whirlpool KSSS42QMX00 42" Built in Refrigerator
Whirlpool KSSS42QMX01 42" Built in Refrigerator
Whirlpool KSSS42QMX02 42" Built in Refrigerator
Whirlpool KSSS42QMX03 42" Built in Refrigerator
Whirlpool KSSS42QTB00 42" Built in Refrigerator
Whirlpool KSSS42QTW00 42" Built in Refrigerator
Whirlpool KSSS42QTX00 42" Built in Refrigerator
Whirlpool KSSS48DAW00
Whirlpool KSSS48DAW01
Whirlpool KSSS48DAW03
Whirlpool KSSS48DAX00
Whirlpool KSSS48DAX01
Whirlpool KSSS48DAX03
Whirlpool KSSS48DBW00
Whirlpool KSSS48DBX00
Whirlpool KSSS48DWW00
Whirlpool KSSS48DWW01
Whirlpool KSSS48DWX00
Whirlpool KSSS48DWX01
Whirlpool KSSS48DWX02
Whirlpool KSSS48DYW00
Whirlpool KSSS48FJB00
Whirlpool KSSS48FJT00
Whirlpool KSSS48FJW00
Whirlpool KSSS48FJX00
Whirlpool KSSS48FKB00
Whirlpool KSSS48FKB01
Whirlpool KSSS48FKB02 48" Built in Refrigerator
Whirlpool KSSS48FKT00
Whirlpool KSSS48FKT01
Whirlpool KSSS48FKT02 48" Built in Refrigerator
Whirlpool KSSS48FKW00
Whirlpool KSSS48FKW01
Whirlpool KSSS48FKW02 48" Built in Refrigerator
Whirlpool KSSS48FKX00
Whirlpool KSSS48FKX01
Whirlpool KSSS48FKX02 48" Built in Refrigerator
Whirlpool KSSS48FMB00 48" Built in Refrigerator
Whirlpool KSSS48FMB01 48" Built in Refrigerator
Whirlpool KSSS48FMB02 48" Built in Refrigerator
Whirlpool KSSS48FMX00 48" Built in Refrigerator
Whirlpool KSSS48FMX01 48" Built in Refrigerator
Whirlpool KSSS48FMX02 48" Built in Refrigerator
Whirlpool KSSS48FMXO3 48" Built in Refrigerator
Whirlpool KSSS48FTX00 48" Built in Refrigerator
Whirlpool KSSS48FTX02 48" Built in Refrigerator
Whirlpool KSSS48MAX03
Whirlpool KSSS48MBX00
Whirlpool KSSS48MBX01
Whirlpool KSSS48MDX00
Whirlpool KSSS48MDX02
Whirlpool KSSS48MDX03
Whirlpool KSSS48MDX04
Whirlpool KSSS48MDX05
Whirlpool KSSS48MHB00
Whirlpool KSSS48MHT00
Whirlpool KSSS48MHW00
Whirlpool KSSS48MHX00
Whirlpool KSSS48MWX00
Whirlpool KSSS48MWX01
Whirlpool KSSS48QDW00
Whirlpool KSSS48QDW02
Whirlpool KSSS48QDW03
Whirlpool KSSS48QDW04
Whirlpool KSSS48QDW05
Whirlpool KSSS48QDX00
Whirlpool KSSS48QDX02
Whirlpool KSSS48QDX03
Whirlpool KSSS48QDX04
Whirlpool KSSS48QDX05
Whirlpool KSSS48QHB00
  #2 (permalink)
Old 11-17-2009, 04:01 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL KSSS42MDX00 | AppliancePartsPros.com
Not sure why you replaced the above. Unless the compressor was not running but further on you say the compressor does run???
Cannot explain this unless you moved the defrost timer to check things out.
How long did you leave it? Defrost is normally 20 to 30 minutes.
Could be the unit is hanging up in a defrost cycle but your last statement below seems to contradict this.
Figure out where defrost starts, set the defrost timer to just before a defrost cycle should occur. Mark a point on the cam and the frame. Let it run and check your marks every 20 minutes or so. If the unit goes into defrost and then does not advance the timer cam, the timer is toast re: it will not come out of defrost on its own.
When it is doing this are the evaporator coils clear or heavy frost/ice.
If iced up then it is a defrost problem. The unit is trying to cool down but cannot because the coils are iced up.
If the coils are clear then let it run for a couple hours. Then pull the defrost coil cover off and check the coils. If there is a patchy or just one area on the coils that have frost on them then it could be you are low on freon and have a leak somewhere. If no frost at all and the compressor is running could be the compressor is toast or you are out of freon.
Below is a good site with trouble shooting help
http://www.applianceaid.com/refrigerator.html
Low freon. Check out Item 20. "example picture" at the bottom of the page. Note the first one does not work.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Supco 3 N 1 (overload, capacitor, and start relay) bluefitness Refrigerator & Freezer Repair 28 11-27-2011 09:38 AM
Compressor Clicking - Replaced relay and overload jmpjr99 Refrigerator & Freezer Repair 4 09-10-2009 01:06 PM
Connecting Capacitor To Overload/relay AUSGOD Refrigerator & Freezer Repair 1 08-25-2009 03:42 AM
Maytag Top Freezer not cold enough, but I've just replaced Relay/Run Capacitor... 80sGuy Refrigerator & Freezer Repair 2 08-29-2008 10:09 AM
Relay Overload, Start Capacitor Combo Install rmam Refrigerator & Freezer Repair 0 12-01-2007 09:37 AM
