Discuss
water in bottom of fridge
 in
Refrigerator & Freezer Repair
water pools in bottom of refrigerator. No water is going into drip pan under fridge. Defroster hose clogged. How do
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water in bottom of fridge
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-01-2008, 12:26 PM
mtrimboli mtrimboli is offline
Junior Member
mtrimboli is on a distinguished road
Default water in bottom of fridge
Model Number: gs214tzbbo   Brand: Frigidaire   Age: 1 - 5 years
water pools in bottom of refrigerator. No water is going into drip pan under fridge. Defroster hose clogged. How do I clean it out?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-01-2008, 01:45 PM
Junior Member
Default
the correct model number is GS21HTZBBO
  #3 (permalink)
Old 03-01-2008, 02:21 PM
Junior Member
Default
still asking anyone
I tried unplugging the fridge and letting any ice that was in the system to melt.
I tried sticking all kinds of wires down the tube under the coils in freezer: coat hanger- too stiff, speaker wire-too limp, even got desperate and tried a plumber's snake---all would not go too far.
I tried to stick wires up from the bottom of the tube down where it is supposed to empty into the drain tray. No success.
What kind of wire can I use?
  #4 (permalink)
Old 03-02-2008, 02:45 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Do not use any wires - you can damage the drain hose.
Using a hair dryer make sure the drain is defrosted. Check the bottom end of the drain hose for a clog.
Using a hot water check if it goes through. If it does not then blow an air under pressure through the hose. You can use any kind of canned air.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water coming out the bottom of refridg amberandjakhimomma Refrigerator & Freezer Repair 2 02-20-2008 10:26 AM
refrigerator smells and water in bottom jim Refrigerator & Freezer Repair 1 10-17-2007 11:42 AM
bottom freezer works top fridge barely cool mickey Refrigerator & Freezer Repair 2 10-15-2007 04:20 PM
Kenmore fridge - water drips into fridge njblue55 Refrigerator & Freezer Repair 3 08-07-2007 07:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
