Discuss
iCE MAKER - NO WATER in
 in
Refrigerator & Freezer Repair
Problem: No water from door fill up or ice maker What I know. - Can manually fill ice maker with water
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » iCE MAKER - NO WATER in
  #1 (permalink)
Old 02-28-2008, 10:10 AM
cfuller201 cfuller201 is offline
Junior Member
cfuller201 is on a distinguished road
Default iCE MAKER - NO WATER in
Model Number: GSS25lgmabb   Brand: GE   Age: 5 - 10 years
What I know.
- Can manually fill ice maker with water and makes 1 tray of ice
- Replaced Water Valve Part Number WR57X10026
- Input water flows fine into a bucket
- No water goes to ice maker or door fill up
- Disconnected electrical connectors going to orange output tube and measured 127.4 v on the red connector in and 15.6 v on the blue connector in
- Disconnected electrical connectors going to brn/blk and white tubes and measured 115v on red input and 15.4 v on blue input
- Put brn/blk tube coming from filter into a bucket after connecting all wires and no water comes out when refrigerator plugged in.
Where does the blue connector electrical inputs come from. Shouldn't this input be 115v to pull the solenoid. Is there a bad board here? Which board?
It looks like water comes in, solenoid engages, output thru the orange tube up to the filter and back down into the brn/blk input and out again to the white 1/4 " to the ice maker and the 5/16" tube to the water fill.
Clark
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-29-2008, 02:39 PM
Junior Member
Default
Replacing the water valve seems to have solved the problem. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker will not draw water but water in door works normally kg1okc Refrigerator & Freezer Repair 3 01-26-2008 03:57 PM
Ice maker not getting water bbrazeal@bellsouth.net Refrigerator & Freezer Repair 0 11-27-2007 04:13 PM
ice maker no water mpmc Refrigerator & Freezer Repair 3 11-07-2007 01:48 PM
Ice maker not getting water DBBromberg Refrigerator & Freezer Repair 3 09-24-2007 09:30 AM
Ice maker not getting water. brandon58 Refrigerator & Freezer Repair 1 07-30-2007 03:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
