Discuss
Freezer drips water into fridge
 in
Refrigerator & Freezer Repair
The freezer drips water into the fridge. When this happened last year I defrosted the freezer and let all the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer drips water into fridge
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-27-2008, 02:29 PM
Salisa Salisa is offline
Junior Member
Salisa is on a distinguished road
Default Freezer drips water into fridge
Model Number: YET19DKXDW01   Brand: Whirlpool   Age: More than 10 years
The freezer drips water into the fridge. When this happened last year I defrosted the freezer and let all the built up ice melt then I plugged it back in and it lasted for about a year but this time when I defrosted it it only lasted a few weeks until the drips returned. I checked the water tray under the fridge and it is dry. Can you help???
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-27-2008, 04:22 PM
washer washer is offline
Junior Member
washer is on a distinguished road
Default
When the freezer defrosts all of the water flows into a tray in the rear of the freezer, behind the sheetmetal, and then is supposed to drain down through a hose into the catch pan at the bottom of the fridge where it evaporates. What is happening is that the water does not completely drain before the freezer defrost cycle ends causing the water to freeze in the catch pan blocking the drain hole. When the freezer again defrosts, the water cannot drain and overflows down into the refridge. This may also be caused by dirt in the catch tray. My repair on two Amanas was to enlarge the drain hole allowing for faster draining. I had to rig a larger adapter to the drain hose to accomodate the larger opening.
  #3 (permalink)
Old 02-27-2008, 06:17 PM
Junior Member
Default freezer leaks water into fridge
Thanks for the quick response, that sounds like what I am experiencing. Do you know how I would access the drain hole?
  #4 (permalink)
Old 02-28-2008, 06:28 AM
Junior Member
Default
The best way is to access the freezer coils which are generally behind the sheet metal in the rear of the freezer. That panel once removed will show the coils and the defrost heating elements, which by the way are working since the freezer is obviously defrosting. Locate the water catch tray below the coils and make sure both the tray and the drain hole are clean and clear of any dirt or pieces of insulation. Make sure also that the drain hose is clear all the way down and into the pan under the fridge. If you have found any reason for water obstruction, and have cleared it, reassemble the freezer panels and put the fridge back into use. Install the fridge with a slight tilt toward the rear, just enough that the door swings shut on its own, and with a slight tilt left or right toward the freezer water catch tray drain hole. This should be the end of it. If not the next step would be to enlarge the drain hole in the catch tray and adapt to the drain hose. Good luck.
  #5 (permalink)
Old 06-03-2008, 01:31 PM
Junior Member
Default
Thanks so much for your help. It took me long enough to get around to doing it but it seems to have worked. You saved me an expensive repair bill!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge OK Freezer temps vary widely slow ice and slow freezer fan start shado118 Refrigerator & Freezer Repair 2 04-24-2008 05:07 PM
Freezer Works/Fridge Does not jomigo Refrigerator & Freezer Repair 5 01-09-2008 01:35 PM
Fridge and Freezer both Warm xsivspeed454 Refrigerator & Freezer Repair 4 12-06-2007 05:39 AM
freezer ok, fridge not cooling 535bimmer Refrigerator & Freezer Repair 0 09-04-2007 03:28 PM
Kenmore fridge - water drips into fridge njblue55 Refrigerator & Freezer Repair 3 08-07-2007 07:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
