Discuss
Need tips on replacing the icemaker auger!
 in
Refrigerator & Freezer Repair
The plastic blade on the auger in the icemaker started cracking, so I ordered a new auger from you. We
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Need tips on replacing the icemaker auger!
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-26-2008, 03:57 PM
Laurel Laurel is offline
Junior Member
Laurel is on a distinguished road
Default Need tips on replacing the icemaker auger!
Brand: GE   Age: Less than 1 year
The plastic blade on the auger in the icemaker started cracking, so I ordered a new auger from you. We just received our replacement auger (AP3672963) and I began taking the icemaker apart so that I could replace the cracked auger. I can't get the stupid thing out!! Any tips on how to replace it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-27-2008, 01:24 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Laurel,
In order to provide the most accurate advise I need the complete model number of the fridge.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 02-27-2008, 01:28 PM
Junior Member
Default
Hi Gene,
Thank you for responding! The model number is GSS22WGMCC.
  #4 (permalink)
Old 02-27-2008, 01:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Turn over the ice bucket and ice dispenser cover. Remove the Phillips screw.
Remove the cover.
Remove the Phillips screw for the ice cube control linkage and slide the linkage to the rear of the ice bucket.
Using a pair of pliers, break the tabs off the back cover.
Using 2 flat blade screwdrivers, disengage the locking tabs at either side of the ice crusher and remove the assembly
Slide the back cover off the auger. The back cover must be replaced because of tabs broken off for disassembly.
With a flat-head screwdriver, remove the C-clip from the end of the auger.
Remove the auger and ice crusher blade assembly.
__________________
  #5 (permalink)
Old 02-27-2008, 02:14 PM
Junior Member
Default
Thank you, I really appreciate that!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing an icemaker amcsky Refrigerator & Freezer Repair 1 02-22-2008 06:30 PM
Maytag auger assembly broke David Arey Washer Repair 1 01-27-2008 12:02 PM
Installing an auger trishaustin Refrigerator & Freezer Repair 1 12-21-2007 01:38 PM
Broken Ice Maker Auger museman Refrigerator & Freezer Repair 2 11-03-2007 07:22 PM
Tips to getting blower wheel off Turbotom Dryer Repair 9 09-16-2007 02:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
