Discuss
Amana Bottom Freezer Refridgerator Defrost Issue
 in
Refrigerator & Freezer Repair
The freezer will slowly stop freezing due to frost/ice build up on the back access panel in the freezer and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Bottom Freezer Refridgerator Defrost Issue
  #1 (permalink)
Old 11-10-2009, 07:46 PM
Junior Member
RycherGirl is on a distinguished road
Default Amana Bottom Freezer Refridgerator Defrost Issue
Model Number: BM20TBW   Brand: Amana   Age: More than 10 years
The freezer will slowly stop freezing due to frost/ice build up on the back access panel in the freezer and on the coils behind the panel. This problem began a couple of years ago and every six months or so we would have to manually defrost the freezer by using space heaters / blow dryers to melt the ice. Once everything melted the freezer would cool great. Last March we hired a technician who replaced a defroster type part under the fridge. This took care of the problem until 2 months ago when it began happening again but now its every 3 weeks that we have to go through and melt everything with heaters. I love love love this fridge and can't possibly phatom having to go back to a regular top freezer type but there is no way we could afford to buy a new bottom freezer type. Any help would be greatly appreciated! Kim
Here is the product information:
Model# BM20TBW
MFG# P1305801WW
S/N# 9606152514
Related Models
Amana BM20TBW REF - BOTTOM MOUNTS
Norge BNEA3G1 RANGE- F/S STD ELE
Norge BNEA3H2X RANGE- F/S STD ELE
Norge BNEA3H9TZ RANGE- S/C F/S ELE
Norge BNEW3G1 RANGE- F/S STD ELE
Norge BNEW3H2WEV RANGE- F/S STD ELE
Norge BNEW3H2X RANGE- F/S STD ELE
Norge BNEW3H8TVEV RANGE- S/C F/S ELE
Norge BNEW3H9TZ RANGE- S/C F/S ELE
Whirlpool BNQ11CVANA0 AUTOMATIC WASHER
Maytag BNS22F5 REF - SXS
Maytag BNS22F5A REF - SXS
Maytag BNS22F5H REF - SXS
Maytag BNT15B4V REF - TOP MOUNT
Maytag BNT15B4VA REF - TOP MOUNT
Maytag BNT15B4VH REF - TOP MOUNT
Maytag BNT15H4 REF - TOP MOUNT
Maytag BNT15H4A REF - TOP MOUNT
Maytag BNT15H4H REF - TOP MOUNT
Maytag BNT17B4V REF - TOP MOUNT
Maytag BNT17B4VA REF - TOP MOUNT
Maytag BNT17B4VH REF - TOP MOUNT
Maytag BNT17H4 REF - TOP MOUNT
Maytag BNT17H4A REF - TOP MOUNT
Maytag BNT17H4H REF - TOP MOUNT
Maytag BNT21LE REF - TOP MOUNT
Maytag BNT21LEA REF - TOP MOUNT
Maytag BNT21LEH REF - TOP MOUNT
Maytag BNT23J9 REF - TOP MOUNT
Maytag BNT23J9A REF - TOP MOUNT
Maytag BNT23J9LA REF - TOP MOUNT
Maytag BNT23K9 REF - TOP MOUNT
Maytag BNT23K9A REF - TOP MOUNT
Maytag BNT23L8 REF - TOP MOUNT
Maytag BNT23L8A REF - TOP MOUNT
Maytag BNT23L8K REF - TOP MOUNT
Maytag BNT23L8KA REF - TOP MOUNT
Maytag BNT23L8L REF - TOP MOUNT
Maytag BNT23L8LA REF - TOP MOUNT
Amana BP22A2E REF - BOTTOM MOUNTS
Amana BP22A2L REF - BOTTOM MOUNTS
Amana BP22AW REF - BOTTOM MOUNTS
 BP6000ER Air Conditioner
Whirlpool BPAC0500AS0 AIR CONDITIONERS
Whirlpool BPAC0500AS1 Air-conditioner/heat pump
Whirlpool BPAC0500AS2 AIR CONDITIONER
Whirlpool BPAC0500AS3 AIR CONDITIONER
Whirlpool BPAC0500FS0 AIR CONDITIONER
Whirlpool BPAC0700AS0 Air-conditioner/heat pump
Whirlpool BPAC0700AS1 AIR CONDITIONER
Whirlpool BPAC0700FS0
Whirlpool BPAC0830AS1 AIR CONDITIONER
Whirlpool BPAC0830AS2
Whirlpool BPAC1000AS0 AIR CONDITIONER
Whirlpool BPAC1000AS2 AIR CONDITIONER
Whirlpool BPAC1200AS0 Air-conditioner/heat pump
Whirlpool BPAC1200AS2 AIR CONDITIONERS
Whirlpool BPAC1200FS0 AIR CONDITIONERS
Whirlpool BPAC1230AS0 AIR CONDITIONER
Whirlpool BPAC1230AS2 AIR CONDITIONER
Whirlpool BPAC1400BS0 AIR CONDITIONER
Whirlpool BPAC1800AS0 AIR CONDITIONER
Whirlpool BPAC1800BS0 AIR CONDITIONER
Whirlpool BPAC1800BS1 AIR CONDITIONER
Whirlpool BPAC1800BS2 ROOM AIR CONDITIONER
Whirlpool BPAC1800FS0 AIR CONDITIONERS
Whirlpool BPAC1830AS1 AIR CONDITIONER
Whirlpool BPAC1830AS2 AIR CONDITIONER
Whirlpool BPAC2400AS0 Air-conditioner/heat pump
Whirlpool BPAC2400BS0 AIR CONDITIONER
Whirlpool BPAC2400BS2 AIR CONDITIONER
Whirlpool BPAC2400FS0 AIR CONDITIONERS
Whirlpool BPAC2530ES0 AIR CONDITIONERS
Whirlpool BPDH2500AS0 DEHUMIDIFIER
Whirlpool BPDH2500AS1 DEHUMIDIFIER
Whirlpool BPDH2500AS2 DEHUMIDIFIER
Whirlpool BPDH2500FS0 DEHUMIDIFIER
Whirlpool BPDH4000AS1 DEHUMIDIFIER
Whirlpool BPDH4000AS2 DEHUMIDIFIER
Whirlpool BPDH4000AS3 DEHUMIDIFIER
Whirlpool BPDH4000FS0 DEHUMIDIFIER
Whirlpool BPDH5000BS1 DEHUMIDIFIER
Whirlpool BPDH5000BS2 DEHUMIDIFIER
Whirlpool BPDH5000FS0 DEHUMIDIFIER
Maytag BPNS24H9 REF - SXS/I&W
Maytag BPNS24H9A REF - SXS/I&W
Maytag BPNS24H9H REF - SXS/I&W
Amana BQ20RB REF - BOTTOM MOUNTS
Amana BQ20RBG REF - BOTTOM MOUNTS
Amana BQ20RBL REF - BOTTOM MOUNTS
  #2 (permalink)
Old 11-11-2009, 02:38 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for AMANA BM20TBW | AppliancePartsPros.com
Here are a couple goods sites with fridge repair info
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Basically the defrost has 3 components.
Defrost timer - times the defrost cycles once every 8 hours or so. Shuts off the compressor, it's fan and the evaporator fan also turns on the defrost heater. Yours looks like it is mounted at the front behind the kick plate Item 342 in Section 9
Defrost heater - self explanatory
Defrost thermostat - This is closed when it is frozen, it opens just above freezing and is wired in line with the heater. A timer may have a defrost cycle of 25 minutes but it may only take 10 minutes to get all the ice/frost off the evaporator coils. The thermostat opens when the frost is gone and stops the heater from adding un-needed heat to the freezer compartment.
The timer continues through the defrost cycle and then switches back to cooling mode.
Remove the evaporator cover inside the freezer so you can see the coils. Turn the defrost timer cam till the compressor and fans go off, you are now in a defrost cycle. Note the timer only moves in one direction. Check to see if the heater comes on. Be careful do not burn your fingers. Also the coils must be frosted over for it to work.
If the heater comes on your timer is probably toast.
If the heater does not come on then it is either the heater or the defrost thermostat. Could also be that the contacts in the timer are toast.
Disconnect the heater should be around 20 ohms
Disconnect the thermostat should be 0 ohms when frozen.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Profile, Refridgerator W/bottom Freezer ncjbird Refrigerator & Freezer Repair 0 12-02-2009 02:07 PM
Refridgerator/Freezer, cold on the bottom NOT on the top mmkrussell Refrigerator & Freezer Repair 1 06-29-2009 08:37 AM
ice accumulation in bottom of self defrost freezer sevenbronson Refrigerator & Freezer Repair 6 04-05-2009 02:01 PM
Amana Bottom Freezer Defrost Cycle Help harryhoudini Refrigerator & Freezer Repair 5 12-30-2008 08:07 PM
Amana bottom freezer refrigerator MAL Refrigerator & Freezer Repair 1 08-18-2007 05:47 PM
