Discuss
Cam riser
 in
Refrigerator & Freezer Repair
I successfully replaced the cam risers on the fresh food door but am puzzled on how to perform that same
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Cam riser
  #1 (permalink)
Old 02-25-2008, 10:14 PM
dynamite dynamite is offline
Junior Member
dynamite is on a distinguished road
Default Cam riser
Model Number: TFX22RMD   Brand: GE   Age: More than 10 years
I successfully replaced the cam risers on the fresh food door but am puzzled on how to perform that same function on the freezer door due to the embedded ice maker. Electrical wires enter from the top (no problem) but the water line runs through the lower cams (problem). The line can be disconnected but the connector will obviously fit through the cam.
Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-26-2008, 05:40 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Disconnect the water line and remove the compression nut from the tube to put the tube through the cam.
After it's done, install the compression nut back on the tube and reconnect the water line.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
