Discuss
frigidaire chess freezer not cold at all
 in
Refrigerator & Freezer Repair
freezer is not cold at all. compressor is running. compressor use about .5 amp. check line pressure low side is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » frigidaire chess freezer not cold at all
  #1 (permalink)
Old 08-15-2007, 09:14 PM
djohner djohner is offline
Junior Member
djohner is on a distinguished road
Default frigidaire chess freezer not cold at all
Model Number: cf16dl4   Brand: Frigidaire   Age: 1 - 5 years
freezer is not cold at all. compressor is running. compressor use about .5 amp. check line pressure low side is below zero while high side is about 50 psig. it is using R-12. please help. could it be low on freon or what? thank you
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-27-2007, 12:34 PM
jdappl07 jdappl07 is offline
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default
it is low or out of freon the only way to get r-12 is to buy this freon called hot shot which is able to run r-12 and r-134a systems
  #3 (permalink)
Old 10-27-2007, 12:45 PM
lyd lyd is offline
Junior Member
lyd is on a distinguished road
Default
where cant this hot shot be purchased?
  #4 (permalink)
Old 10-31-2007, 04:31 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default low charge
The possibility of a plugged capillary tubing exists in this instance as well and next to impossible to repair on a chest freezer... You're showing this freezer to be 1 to 5 years old but uses R-12, I would guess this frigidaire is older than 5 years if it has R-12 in it... If this system is low on refrigerant then that means there's a leak somewhere in the system also next to impossible to repair if the leak is inaccessable... The hotshot refrigerant (R-414B) can be purchased from local suppliers but requires the buyer to be EPA certified to handle refrigerants which it sounds as tho you may be since you were able to read system pressures... I know Johnstone Supply carries 10oz containers which will get you going until it leaks back down again... cheers, kooler
  #5 (permalink)
Old 11-01-2007, 03:56 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If compressor only drawing .5 amp sounds like a clogged capillary. This can be blown out with nitrogen gas. Will have to purge refrigerant, file open the capillary and blow out contaminents. Helps to heat up the capillary with a propane torch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frig & Freezer not cold enough BRIDGETSTEPP Refrigerator & Freezer Repair 0 08-14-2007 03:15 PM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 06:43 AM
Freezer no longer cold enough clowder64 Refrigerator & Freezer Repair 1 07-25-2007 04:21 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
