| » chris |
Model Number: GE PSS27NGMA BB Brand: GE Age: 1 - 5 years
Hi!
I have been noticing the freezer light is intermittant. I would open the door and the light would flicker and I would "bump" the switch and it would stay lit. Today, I opened it and found frost showing up and the light out. I also noticed that the doors are easy to open- there would be a few seconds where I would hear a sucking sound and the doors would be hard to open until the sucking sound stopped. I know that was a normal function. Now, no more sound and the doors are easy to open immediately after closing. Does this have anything to do with the door switch? 2/24 This morning I opened the ref and it seems to cool ok- I can hear it cycle on and off, but still no vacuum mode and no light- OK- After taking some more time, found the light bulb loose in socket (DUH!) so that is ok- the switch seems to be ok too- It turns on/off the light and the condenser? fan goes on/off with the switch. Pulled the back panels and found everything mostly clean. Everything else works ok, ice, water, cooling/defrost, temp adjustments, fans for express thaw/chill, etc. But no vacuum? mode. No "gurguling" or "sucking" sounds which were always present after opening/closing the doors. Worried about the water that is occasionally in the drip pan. Dry. Not a bad thing, but something IS missing. Please help!!! Thanks! Ads By Google Related Models Last edited by nysryd : 02-24-2008 at 11:23 AM. Reason: continuation |
| Display Modes | |
| chris | cleanslate | Dishwasher Repair | 1 | 12-04-2009 06:07 AM |
| Chris | chrisdods9 | Washer Repair | 3 | 02-07-2009 05:11 AM |
| Chris | chrisdods9 | Washer Repair | 0 | 02-04-2009 04:13 PM |
| ge mircrowave chris | chrisapiccola | Microwave Repair | 4 | 09-05-2008 06:28 PM |
| Chris | ceh | Refrigerator & Freezer Repair | 7 | 07-07-2008 01:11 PM |
