I have a 2004 GE refrigerator with water in the door. In 2006, the door was replaced under a recall. The water dispensor has worked fine until a few weeks ago when it stopped. I replaced the filter - it was not that old and did not indicte replacement was necessay. Not then, but a week or so later the water dispensor started working as quickly as it stopped. It worked fine for about a week and now it has stopped working again. When the door was replaced on recall the tech told us the water line will freeze up and that was the reason for replacing. Any suggestions?
