Discuss
Can't unclog the freezer drain
 in
Refrigerator & Freezer Repair
I have a clogged drain in my side-by-side freezer. Water collects on the bottom of the compartment and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Can't unclog the freezer drain
  #1 (permalink)
Old 11-06-2009, 11:08 AM
Denis_D Denis_D is offline
Junior Member
Denis_D is on a distinguished road
Default Can't unclog the freezer drain
Model Number: FRS24XHAW0   Brand: Frigidaire   Age: More than 10 years
I have a clogged drain in my side-by-side freezer. Water collects on the bottom of the compartment and freezes, then leaks onto the kitchen floor. I've removed the back panel of the freezer compartment and carefully lifted the coil assembly out of the way to clear the drain hole. First i use a pipe cleaner-not long enough. Then a 10" x 3/3" spring that use for cleaning the coffee pot - still not long enough. finally i used a wire coat hanger. it's long enough, but bottoms out on the drain hole and has not cleared the clog. I still have water standing in the bottom of the coil housing.
How can I clean this drain? I can't see the drian path from the back of the unit due to the sheet metal shroud that contains the assembly. Where does this drain to, the main catch pan at the very bottom housing? And what happens to the water (condensate) once it get to wherever it goes?
I need some help.
Thanks in advance,
Denis
Related Models
Frigidaire FRS24XHAW0 Frg(v6) / Side By Side Refrigerator
Frigidaire FRS24XHAW1 Frg(v6) / Side By Side Refrigerator
Frigidaire FRS24XHAW2 Frg(v6) / Refrigerator
Frigidaire FRS24ZGEB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZGEB2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZGED0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZGED2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZGEW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZGEW2 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZGGB0 Frg(v1)
Frigidaire FRS24ZGGB1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZGGB2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZGGB3 Frg(v1) / Refrigerator
Frigidaire FRS24ZGGB4 Frg(v2) / Refrigerator
Frigidaire FRS24ZGGD0 Frg(v2)
Frigidaire FRS24ZGGD1 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZGGD2 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS24ZGGD3 Frg(v3) / Refrigerator
Frigidaire FRS24ZGGD4 Frg(v4) / Refrigerator
Frigidaire FRS24ZGGW0 Frg(v3)
Frigidaire FRS24ZGGW1 Frg(v5) / Side By Side Refrigerator
Frigidaire FRS24ZGGW2 Frg(v6) / Side By Side Refrigerator
Frigidaire FRS24ZGGW3 Frg(v5) / Refrigerator
Frigidaire FRS24ZGGW4 Frg(v6) / Refrigerator
Frigidaire FRS24ZGHB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZGHB2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZGHB3 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZGHD0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZGHD2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZGHD3 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZGHW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZGHW2 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZGHW3 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZRGB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZRGD0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZRGD1 Frigidaire/refrigerator / Side By Side Refrigerato
Frigidaire FRS24ZRGW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZRGW1 Frigidaire/refrigerator / Side By Side Refrigerato
Frigidaire FRS24ZRHB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZRHB1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZRHB2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZRHB3 Frg(v1) / Refrigerator
Frigidaire FRS24ZRHB4 Frg(v1) / Refrigerator
Frigidaire FRS24ZRHB5 Frigidaire/refrigerator
Frigidaire FRS24ZRHD0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZRHD1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZRHD2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZRHD3 Frg(v2) / Refrigerator
Frigidaire FRS24ZRHD4 Frg(v2) / Refrigerator
Frigidaire FRS24ZRHD5 Frigidaire/refrigerator
Frigidaire FRS24ZRHW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZRHW1 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZRHW2 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS24ZRHW3 Frg(v3) / Refrigerator
Frigidaire FRS24ZRHW4 Frg(v3) / Refrigerator
Frigidaire FRS24ZRHW5 Frigidaire/refrigerator
Frigidaire FRS24ZSFB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS24ZSFB1 Frg(v0) / Side By Side Refrigerator
Frigidaire FRS24ZSFW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS24ZSGB0 Frg(v1) / Refrigerator
Frigidaire FRS24ZSGB1 Frg(v2) / Refrigerator
Frigidaire FRS24ZSGB2 Frg(v3) / Refrigerator
Frigidaire FRS24ZSGB3 Frg(v4) / Refrigerator
Frigidaire FRS24ZSGB4 Frg(v5) / Refrigerator
Frigidaire FRS266ZDSB0 Frigidaire/refrigerator
Frigidaire FRS266ZDSB1 Frigidaire/refrigerator
Frigidaire FRS266ZDSB2 Frigidaire/refrigerator
Frigidaire FRS266ZDSB3 Frigidaire/refrigerator
Frigidaire FRS266ZDSB4 Frigidaire/refrigerator
Frigidaire FRS266ZDSB5 Frigidaire/refrigerator
Frigidaire FRS266ZDSB7 Frigidaire/refrigerator
Frigidaire FRS266ZDSB8 Frigidaire/refrigerator
Frigidaire FRS266ZDSB9 Frigidaire/refrigerator
Frigidaire FRS266ZDSBA Frigidaire/refrigerator
Frigidaire FRS266ZDSBN Frigidaire/refrigerator
Frigidaire FRS26BH5CB0 Frigidaire/refrigerator
Frigidaire FRS26BH5CB2 Frigidaire/refrigerator
Frigidaire FRS26BH5CQ0 Frigidaire/refrigerator
Frigidaire FRS26BH5CQ2 Frigidaire/refrigerator
Frigidaire FRS26BH5CW0 Frigidaire/refrigerator
Frigidaire FRS26BH5CW2 Frigidaire/refrigerator
Frigidaire FRS26BH6CB0 Frigidaire/refrigerator
Frigidaire FRS26BH6CB1 Frigidaire/refrigerator
Frigidaire FRS26BH6CB2 Frigidaire/refrigerator
Frigidaire FRS26BH6CB3 Frigidaire/refrigerator
Frigidaire FRS26BH6CB4 Frigidaire/refrigerator
Frigidaire FRS26BH6CQ0 Frigidaire/refrigerator
Frigidaire FRS26BH6CQ2 Frigidaire/refrigerator
Frigidaire FRS26BH6CQ3 Frigidaire/refrigerator
Frigidaire FRS26BH6CQ4 Frigidaire/refrigerator
Frigidaire FRS26BH6CS0 Frigidaire/refrigerator
Frigidaire FRS26BH6CS1 Frigidaire/refrigerator
Frigidaire FRS26BH6CS2 Frigidaire/refrigerator
Frigidaire FRS26BH6CS3 Frigidaire/refrigerator
Frigidaire FRS26BH6CS4 Frigidaire/refrigerator
Frigidaire FRS26BH6CS5 Frigidaire/refrigerator
Frigidaire FRS26BH6CW0 Frigidaire/refrigerator
Frigidaire FRS26BH6CW2 Frigidaire/refrigerator
Frigidaire FRS26BH6CW3 Frigidaire/refrigerator
Frigidaire FRS26BH6CW4 Frigidaire/refrigerator
Frigidaire FRS26BRDSB1 Frigidaire/refrigerator
Frigidaire FRS26BRDSB2 Frigidaire/refrigerator
Frigidaire FRS26BRDSB3 Frigidaire/refrigerator
Frigidaire FRS26BRDSB4 Frigidaire/refrigerator
Frigidaire FRS26BRDSB5 Frigidaire/refrigerator
Frigidaire FRS26BRDSB7 Frigidaire/refrigerator
Frigidaire FRS26BRDSB9 Frigidaire/refrigerator
Frigidaire FRS26BRDSBN Frigidaire/refrigerator
Frigidaire FRS26BRDSBP Frigidaire/refrigerator
Frigidaire FRS26DR7DS0 Frigidaire/refrigerator
Frigidaire FRS26DR7DS2 Frigidaire/refrigerator
Frigidaire FRS26DR7DS3 Frigidaire/refrigerator
Frigidaire FRS26DR7DS4 Frigidaire/refrigerator
Frigidaire FRS26DR7DS5 Frigidaire/refrigerator
Frigidaire FRS26DR7DS6 Frigidaire/refrigerator
Frigidaire FRS26DR7DS7 Frigidaire/refrigerator
Frigidaire FRS26F4CB0 Frigidaire/refrigerator
Frigidaire FRS26F4CB1 Frigidaire/refrigerator
Frigidaire FRS26F4CB2 Frigidaire/refrigerator
Frigidaire FRS26F4CB3 Frigidaire/refrigerator
  #2 (permalink)
Old 11-06-2009, 06:02 PM
applianceman applianceman is offline
Senior Member
applianceman is on a distinguished road
Default
If you use a turkey baser (or something similar) to force hot water down the drain it should do the trick. Once done mix baking-soda with water and pour it down the drain to prevent this from happing again soon. The water goes into a pan were it evaporates. Hope this helps! Refrigerator repair guide
  #3 (permalink)
Old 11-06-2009, 06:16 PM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
I would remove the rear cover so you can see the pan.
It may be plugged with dust and crud at the pan.
You could try a compressor if you have one.
Blowing into a straw or piece of tubing sometimes works, problem is trying to get a decent seal at the drain.
Sometimes a turkey baster and some warm water works.
Once you get it clear, wipe out the drip pan as best you can.
Also flush it with about a cup of 10% bleach solution to kill the crud in the tubing, just be careful to not overflow the drip tray.
If you remove the rear lower cover you should be able to see the compressor and the drain pan Item 22 in Section 12. Sometimes you can see it if you remove the front kick plate.
It just evaporates
__________________
  #4 (permalink)
Old 11-06-2009, 09:44 PM
Qtip Qtip is offline
Member
Qtip is on a distinguished road
Default
Also I have found (strange, i know, but works) if you have a steam cleaner (little machine that you put water in and it sprays out very hot water vapor) use the steam cleaner on the drain - most cleaners have an attachment on the end that fits perfectly in all drains and the great thing about this is you actually hear the water vapor push through whatever is clogging the drain so you know its clear. These are usually used to clean grease or tile grout but has that perfect attachment that allows you to direct the spray straight down the drain with a nice seal to ensure the clog is removed. Also works great for a fridge that has a defrost problem and is all iced up - will melt a completely frozen over freezer in 15 minutes if you dont have time to leave it unplugged for hours
  #5 (permalink)
Old 11-06-2009, 09:50 PM
1lassiegirl 1lassiegirl is offline
Junior Member
1lassiegirl is on a distinguished road
Default
It's not a problem with the drain it's the icemaker it overflows water into the ice bin & the ice won't cut into pieces maybe because it's putting out to much water in the ice tray but why?
  #6 (permalink)
Old 11-06-2009, 09:54 PM
Member
Default
Lassiegirl i believe your problem is the Water Valve (some refrigerators have 2 depending on if there is a filter inside your refrigerator) if there is 2 replace both because i dont know of a way to actually test to see which one is bad (maybe there is but if so i dont know how)
  #7 (permalink)
Old 11-07-2009, 05:38 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would remove the icemaker, thaw out the filler tube going to it if necessary and see if water dribbles out of it, if so=bad filler valve. If not=bad/jamed icemaker.
__________________
  #8 (permalink)
Old 11-07-2009, 08:34 AM
Senior Member
Default
Quote:
I like that defrost idea Qtip good tip that may save me some time!
When it comes to cleaning drains I am convinced the turkey baser is the very best. I have cleaned out a ton of drains and the turkey baser has worked great for all but three. I have used a portable air tank, various squirt bottles, and some type of plunger made for cleaning drains I even used the garden hose twice. None come close to working as well as the turkey baser for me. Well except the garden hose but that is ridiculous I only used it because I didn’t have anything else nor did the person I was working for. I am not trying to say it wouldn't work very good just that I am happy with what I am using.
However I love that idea for defrosting refrigerators. I bet that steam melts the ice like crazy. Now I am going to have to go out and buy a steam cleaner (as if I needed anymore tools to junk up my truck).
I have found that spraying water on the coils works very well (fast) but it makes a huge mess. I spend as much time on clean up as I do melting the ice. So I just use a heat gun but it takes forever and it is the most boring job I have to do. Not to mention I normally have a ton of other jobs I need to do. I will probably give the steam cleaner a try because I believe it is going to work much faster than my heat gun and without the huge mess.
Even though I am totally sold on the turkey baser if I actually get a steam cleaner I will give it a try for cleaning out drains who knows I might change my mind.
  #9 (permalink)
Old 11-07-2009, 10:26 PM
Junior Member
Default
Thanks to all. The drain is clear and working like a charm. No ice buld up after 36 hours. Now and I understand where the pan is located and how this system works. I actually did have to break the initial clog with the coat hanger, but was able to blow out the rest of the crud with the turkey baster. Great tip!
I should have mentioned that i has defrosted the freezer before hand, so there was nothing frozen in the drain. just crud and standing water. If i have to defrost in the future I'll remember the steam genie.
One last question? I noticed that there is a ton of dust and crud on the black coils that sit under the fridge. Is there a simple way to access these to vacuume/clean them without turning the whole fridge on it's side and removing the galvanized metal tray that sits beneath the coils?
  #10 (permalink)
Old 11-08-2009, 03:44 AM
Senior Expert
APP Volunteer
Default
Yes, some units are a royal pain to clean.
There are long brushes available to do this.
I do not know if the following will work for you, it depends on how your kitchen is set up. It works great for me.
I remove the front kick plate and the rear cover.
Then open the kitchen door and roll the fridge over to it.
Then I just blow it out with my compressor from inside the house.
Just about all the dust is blown outside.
Also I do not have to worry about breaking anything under the unit while trying to clean the coils.
I have also been told that a leaf blower does a good job.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Where is GE refrigerator freezer drain tube mastone3 Refrigerator & Freezer Repair 3 09-20-2009 09:06 PM
Amana top freezer how do you get to the drain tube jdmyers19024 Refrigerator & Freezer Repair 2 09-18-2009 08:00 AM
Whirlpool Freezer Drain Keeps Freezing Up lkprice Refrigerator & Freezer Repair 1 05-28-2009 09:13 AM
freezer drain keeps freezing up hhs Refrigerator & Freezer Repair 6 02-09-2009 08:30 AM
Freezer drain freezes richappy Refrigerator & Freezer Repair 2 06-29-2008 04:56 AM
