Discuss
Kenmore Elite 795.74025 not cooling enough
 in
Refrigerator & Freezer Repair
This unit is a bottom freezer with french doors on upper fridge. Over the past couple weeks, the temps have
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Elite 795.74025 not cooling enough
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-09-2018, 06:45 AM
Junior Member
tom_shell is on a distinguished road
Default Kenmore Elite 795.74025 not cooling enough
Model Number: 795.74025.411   Brand: Kenmore   Age: 1 - 5 years
This unit is a bottom freezer with french doors on upper fridge. Over the past couple weeks, the temps have slowly moved up. After some troubleshooting, Iíve discovered that the fans for the fridge and freezer are not running. The compressor runs, condensor fan is clean and runs fine. It appears to be an issue with the evaporator fan - it is not running. If I place the unit in Test mode #1, the fan starts and blows air in both the upper fridge and freezer. When operating normally it does not.
Iíve check the resistance on the sensors for the fridge and freezer and while the voltage appears to be in range, the measured resistance is wrong and indicates a temperature far too warm. Logic would dictate that the fan would run constantly, but it is actually not running at all.
Is the issue with both thermistors/sensors? Seem unlikely that both would fail at the same time. Unfortunately, this would mean that the PCB is badÖ
Any ideas?
Related Models
Kenmore 79531002700 REFRIGERATOR
Kenmore 79531006700 REFRIGERATOR
Kenmore 79539113600 SIDE-BY-SIDE
Kenmore 79551012010 REFRIGERATOR
Kenmore 79551012011 REFRIGERATOR
Kenmore 79551012012 REFRIGERATOR
Kenmore 79551013010 REFRIGERATOR
Kenmore 79551013011 REFRIGERATOR
Kenmore 79551013012 REFRIGERATOR
Kenmore 79551014010 REFRIGERATOR
Kenmore 79551014011 REFRIGERATOR
Kenmore 79551014012 REFRIGERATOR
Kenmore 79551016010 REFRIGERATOR
Kenmore 79551016011 REFRIGERATOR
Kenmore 79551016012 REFRIGERATOR
Kenmore 79551019010 REFRIGERATOR
Kenmore 79551019011 REFRIGERATOR
Kenmore 79551019012 REFRIGERATOR
Kenmore 79551022010 REFRIGERATOR
Kenmore 79551022011 REFRIGERATOR
Kenmore 79551022012 REFRIGERATOR
Kenmore 79551023010 REFRIGERATOR
Kenmore 79551023011 REFRIGERATOR
Kenmore 79551023012 REFRIGERATOR
Kenmore 79551024010 REFRIGERATOR
Kenmore 79551024011 REFRIGERATOR
Kenmore 79551024012 REFRIGERATOR
Kenmore 79551026010 REFRIGERATOR
Kenmore 79551026011 REFRIGERATOR
Kenmore 79551026012 REFRIGERATOR
Kenmore 79551029010 REFRIGERATOR
Kenmore 79551029011 REFRIGERATOR
Kenmore 79551029012 REFRIGERATOR
Kenmore 79551032010 REFRIGERATOR
Kenmore 79551032011 REFRIGERATOR
Kenmore 79551033010 REFRIGERATOR
Kenmore 79551033011 REFRIGERATOR
Kenmore 79551034010 REFRIGERATOR
Kenmore 79551034011 REFRIGERATOR
Kenmore 79551036010 REFRIGERATOR
Kenmore 79551036011 REFRIGERATOR
Kenmore 79551039010 REFRIGERATOR
Kenmore 79551039011 REFRIGERATOR
Kenmore 79551072010 REFRIGERATOR
Kenmore 79551072011 REFRIGERATOR
Kenmore 79551073010 REFRIGERATOR
Kenmore 79551073011 REFRIGERATOR
Kenmore 79551074010 REFRIGERATOR
Kenmore 79551074011 REFRIGERATOR
Kenmore 79551076010 REFRIGERATOR
Kenmore 79551076011 REFRIGERATOR
Kenmore 79551079010 REFRIGERATOR
Kenmore 79551079011 REFRIGERATOR
Kenmore 79551082010 REFRIGERATOR
Kenmore 79551082011 REFRIGERATOR
Kenmore 79551083010 REFRIGERATOR
Kenmore 79551083011 REFRIGERATOR
Kenmore 79551086010 REFRIGERATOR
Kenmore 79551086011 REFRIGERATOR
Kenmore 79551089010 REFRIGERATOR
Kenmore 79551089011 REFRIGERATOR
Kenmore 79551092010 REFRIGERATOR
Kenmore 79551092011 REFRIGERATOR
Kenmore 79551093010 REFRIGERATOR
Kenmore 79551093011 REFRIGERATOR
Kenmore 79551099010 REFRIGERATOR
Kenmore 79551099011 REFRIGERATOR
Kenmore 79551312010 REFRIGERATOR
Kenmore 79551312011 REFRIGERATOR
Kenmore 79551312012 REFRIGERATOR
Kenmore 79551313010 REFRIGERATOR
Kenmore 79551313011 REFRIGERATOR
Kenmore 79551313012 REFRIGERATOR
Kenmore 79551314010 REFRIGERATOR
Kenmore 79551314011 REFRIGERATOR
Kenmore 79551314012 REFRIGERATOR
Kenmore 79551316010 REFRIGERATOR
Kenmore 79551316011 REFRIGERATOR
Kenmore 79551316012 REFRIGERATOR
Kenmore 79551319010 REFRIGERATOR
Kenmore 79551319011 REFRIGERATOR
Kenmore 79551319012 REFRIGERATOR
Kenmore 79551322010 REFRIGERATOR
Kenmore 79551322011 REFRIGERATOR
Kenmore 79551322012 REFRIGERATOR
Kenmore 79551323010 REFRIGERATOR
Kenmore 79551323011 REFRIGERATOR
Kenmore 79551326010 REFRIGERATOR
Kenmore 79551326011 REFRIGERATOR
Kenmore 79551329010 REFRIGERATOR
Kenmore 79551329011 REFRIGERATOR
Kenmore 79551329012 REFRIGERATOR
Kenmore 79551372010 REFRIGERATOR
Kenmore 79551373010 REFRIGERATOR
Kenmore 79551374010 REFRIGERATOR
Kenmore 79551376010 REFRIGERATOR
Kenmore 79551379010 REFRIGERATOR
Kenmore 79558812900 REFRIGERATOR
Kenmore 79558813900 REFRIGERATOR
Kenmore 79558814900 REFRIGERATOR
Kenmore 79558814901 REFRIGERATOR
Kenmore 79558816900 REFRIGERATOR
Kenmore 79558819900 REFRIGERATOR
Kenmore 79558819901 REFRIGERATOR
Kenmore 79558822900 REFRIGERATOR
Kenmore 79558823900 REFRIGERATOR
Kenmore 79558826900 REFRIGERATOR
Kenmore 79558829900 REFRIGERATOR
Kenmore 79565002400 REFRIGERATOR
Kenmore 79565002401 BOTTOM-MOUNT
Kenmore 79565002402 BOTTOM-MOUNT REFRIGERATOR
Kenmore 79565004400 REFRIGERATOR
Kenmore 79565004401 BOTTOM-MOUNT
Kenmore 79565004402 REFRIGERATOR
Kenmore 79565009400 REFRIGERATOR
Kenmore 79565009401 BOTTOM-MOUNT
Kenmore 79565012400 REFRIGERATOR
Kenmore 79565012401 BOTTOM-MOUNT
Kenmore 79565014400 REFRIGERATOR
Kenmore 79565014401 BOTTOM-MOUNT
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite intermittently cooling rkm Refrigerator & Freezer Repair 0 11-29-2017 05:37 PM
Kenmore Elite Not Cooling lawprelim Refrigerator & Freezer Repair 0 10-14-2016 02:16 PM
Kenmore Elite Fridge not cooling rkcarguy Refrigerator & Freezer Repair 0 05-06-2013 11:39 AM
Kenmore Elite Refrigerator not cooling Parker23 Refrigerator & Freezer Repair 2 08-03-2012 10:30 AM
Kenmore Elite not cooling Bull-37 Refrigerator & Freezer Repair 3 06-10-2009 03:39 PM
