Discuss
GE Profile voltage from main board j15 plug to inverter panel
 in
Refrigerator & Freezer Repair
Hello, I just replaced a main board on my GE Profile french door fridge. (about 9 years old) The board
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Profile voltage from main board j15 plug to inverter panel
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-26-2018, 01:14 PM
SRP SRP is offline
Junior Member
SRP is on a distinguished road
Default GE Profile voltage from main board j15 plug to inverter panel
Model Number: pfss5nfwass   Brand: GE   Age: 5 - 10 years
Hello, I just replaced a main board on my GE Profile french door fridge. (about 9 years old) The board I removed had a burnt spot on it. The problem with the fridge was it originally stopped cooling on the freezer, then both freezer and fridge quit. If I unplugged the unit from wall power and let sit for couple hours, then plugged it back in, it would start working again, but only for short time.
After replacing the main board, the compressor will not come on. I checked voltage from the main board J15 pin and am getting 12.1 volts both on the board pins and at the connection to invertor board. I also checked the continuity of the compressor and all three pins were at 6.8 volts so assuming the compressor is ok. I was reading the J15 voltage should be between 4 and 6 volts, so do I have a bad board if it's putting out 12.1?
Using a cooler for food... no fun.
Thanks for your help in advance.
Related Models
General Electric PFSS5NFWASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NFXASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NFXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NFXCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NFYASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NFYCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NFZASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NFZBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NFZCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NJWASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NJXASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NJXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5NJXCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5PJXASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5PJXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5PJXCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5PJYASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5PJYCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5PJZASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5PJZCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5RKZASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS5RKZCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6PKWASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6PKWBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6PKXASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6PKXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6PKXCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6PKXDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6PKXESS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6PKXGSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SKXASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SKXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SKXCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SKXDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SMXASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SMXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SMXCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SMXDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS6SMXESS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS9PKYASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSS9SKYASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSW2MIXASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSW2MIXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSW2MIYASS BOTTOM MOUNT REFRIGERATOR
General Electric PFSW2MIYCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFWS4600L0WW WASHER
General Electric PFWS4605L0MG WASHER
General Electric PFWS4605L0MV WASHER
General Electric PGB900DEM1BB GAS RANGE
General Electric PGB900DEM1CC GAS RANGE
General Electric PGB900DEM1WW GAS RANGE
General Electric PGB900DEM2BB GAS RANGE
General Electric PGB900DEM2CC GAS RANGE
General Electric PGB900DEM2WW GAS RANGE
General Electric PGB900DEM3BB GAS RANGE
General Electric PGB900DEM3CC GAS RANGE
General Electric PGB900DEM3WW GAS RANGE
General Electric PGB900DEM4BB GAS RANGE
General Electric PGB900DEM4CC GAS RANGE
General Electric PGB900DEM4WW GAS RANGE
General Electric PGB900DEM5BB GAS RANGE
General Electric PGB900DEM5WW GAS RANGE
General Electric PGB900DET1BB GAS RANGE
General Electric PGB900DET1WW GAS RANGE
General Electric PGB900SEM1SS GAS RANGE
General Electric PGB900SEM2SS GAS RANGE
General Electric PGB900SEM3SS GAS RANGE
General Electric PGB900SEM4SS GAS RANGE
General Electric PGB900SEM5SS GAS RANGE
General Electric PGB900SET1SS GAS RANGE
General Electric PGB908DEM1BB GAS RANGE
General Electric PGB908DEM1CC GAS RANGE
General Electric PGB908DEM1WW GAS RANGE
General Electric PGB908DEM2BB GAS RANGE
General Electric PGB908DEM2CC GAS RANGE
General Electric PGB908DEM2WW GAS RANGE
General Electric PGB908DEM3BB GAS RANGE
General Electric PGB908DEM3CC GAS RANGE
General Electric PGB908DEM3WW GAS RANGE
General Electric PGB908DEM4BB GAS RANGE
General Electric PGB908DEM4CC GAS RANGE
General Electric PGB908DEM4WW GAS RANGE
General Electric PGB908SEM1SS GAS RANGE
General Electric PGB908SEM2SS GAS RANGE
General Electric PGB908SEM3SS GAS RANGE
General Electric PGB908SEM4SS GAS RANGE
General Electric PGB910DET1BB GAS RANGE
General Electric PGB910DET1CC GAS RANGE
General Electric PGB910DET1WW GAS RANGE
General Electric PGB910SEM1SS GAS RANGE
General Electric PGB910SEM2SS GAS RANGE
General Electric PGB910SEM3SS GAS RANGE
General Electric PGB910SEM4SS GAS RANGE
General Electric PGB910SET1SS GAS RANGE
General Electric PGB915SET1SS GAS RANGE
General Electric PGB916DEM1BB GAS RANGE
General Electric PGB916DEM1CC GAS RANGE
General Electric PGB916DEM1WW GAS RANGE
General Electric PGB916DEM2BB GAS RANGE
General Electric PGB916DEM2CC GAS RANGE
General Electric PGB916DEM2WW GAS RANGE
General Electric PGB916DEM3BB GAS RANGE
General Electric PGB916DEM3CC GAS RANGE
General Electric PGB916DEM3WW GAS RANGE
General Electric PGB916DEM4BB GAS RANGE
General Electric PGB916DEM4CC GAS RANGE
General Electric PGB916DEM4WW GAS RANGE
General Electric PGB916SEM1SS GAS RANGE
General Electric PGB916SEM2SS GAS RANGE
General Electric PGB916SEM3SS GAS RANGE
General Electric PGB916SEM4SS GAS RANGE
General Electric PGB918DEM1BB GAS RANGE
General Electric PGB918DEM1WW GAS RANGE
General Electric PGB918DEM2BB GAS RANGE
General Electric PGB918DEM2WW GAS RANGE
General Electric PGB918DEM3BB GAS RANGE
General Electric PGB918DEM3WW GAS RANGE
General Electric PGB918DEM4BB GAS RANGE
General Electric PGB918DEM4WW GAS RANGE
General Electric PGB918SEM1SS GAS RANGE
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Not the main board, not inverter board...compressor? Riotubes Refrigerator & Freezer Repair 2 08-06-2017 10:23 PM
GE PROFILE main control board replaced - no cold still flcowboy Refrigerator & Freezer Repair 3 06-24-2014 06:47 PM
GE Profile Arctica Fried the brand new Main Board Nightmare Refrigerator & Freezer Repair 1 06-23-2012 02:31 AM
GE Profile French Door Bottom Freezer - Inverter board malfunction? jcims Refrigerator & Freezer Repair 2 05-14-2012 06:09 PM
Main Board w/ Inverter Harness joedadog Refrigerator & Freezer Repair 0 01-31-2009 06:27 AM
