Discuss
Fridge not consistently cooling to set temp
 in
Refrigerator & Freezer Repair
Last week the fridge was getting warm and ice maker quit making ice. First checked the condenser coils and noticed
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge not consistently cooling to set temp
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-12-2018, 01:28 AM
Junior Member
scojag is on a distinguished road
Default Fridge not consistently cooling to set temp
Model Number: KFIV29PCMS03   Brand: Kitchen Aid   Age: 1 - 5 years
Last week the fridge was getting warm and ice maker quit making ice. First checked the condenser coils and noticed they were fairly dirty (cat hair), so cleaned them and continued to monitor the temperature. The next morning checked both the freezer and fridge temperatures and both were about 11 deg Celsius warmer than set point.
Pulled the freezer apart and noticed evaporator coils were iced up for at least the top 1/4. Pulled the refrigerator apart and found its evaporator coils were almost completely iced up. Defrosted both coils and checked the following components:
- Freezer heating element had continuity
- Both Freezer and Fridge thermistor had continuity.
- Freezer defrost thermostat had continuity when temperature dropped low enough, sprayed it with upside down bottle of air duster to freeze it.
- Freezer and Fridge bi-metal contactor switch had continuity
- Both the freezer and fridge evap fans would receive power and turn on
- The condensor fan had power and would turn on
Plugged the fridge back in and the following day the freezer was reaching the set temperature (-18 deg celsius) however the fridge was only getting to around 12 deg celsius and was set for 3 deg. Let it sit longer and the following day the fridge jumped between 10-13 deg celsius. Left another day and it did get down to 3 deg celsius but shortly after opening the door it jumped back up and hovered around 6-7 deg celsius.
I then pulled the fridge's thermistor and checked its resistance at a couple of different temperature and it seemed good. 2850 ohms at 22 deg C (72 deg F) and 4300 ohm at 14 deg C (57 deg F). Also there were no signs of ice building up on the fridges evap coils.
Not sure what the root problem is or what to check next? Is this a control board issue and if so which control board, WPW10453401 or WPW10589837? Is there a way to test these, any help is greatly appreciated!
Related Models
General Electric KFN13DSW1 Room air conditioner
KitchenAid KFP1333ACS0 13-CUP FOOD PROCESSOR
KitchenAid KFP1333BD0 13-CUP FOOD PROCESSOR
KitchenAid KFP1333CU0 13-CUP FOOD PROCESSOR
KitchenAid KFP1333ER0 13-CUP FOOD PROCESSOR
KitchenAid KFP1333OB0 13-CUP FOOD PROCESSOR
KitchenAid KFP1333WH0 13-CUP FOOD PROCESSOR
KitchenAid KFP1344ACA0 13-CUP FOOD PROCESSOR
KitchenAid KFP1344ACS0 13-CUP FOOD PROCESSOR
KitchenAid KFP1344ACU0 13-CUP FOOD PROCESSOR
KitchenAid KFP1344AES0 13-CUP FOOD PROCESSOR
Whirlpool KFP300WH FOOD PROCESSOR
KitchenAid KFP350AC FOOD PROCESSOR
KitchenAid KFP350BU FOOD PROCESSOR
KitchenAid KFP350GN FOOD PROCESSOR
KitchenAid KFP350MY FOOD PROCESSOR
KitchenAid KFP350OB FOOD PROCESSOR
KitchenAid KFP350RE FOOD PROCESSOR
Whirlpool KFP350WH FOOD PROCESSOR
Whirlpool KFP403
Whirlpool KFP450WH FOOD PROCESSOR
Whirlpool KFP495WH FOOD PROCESSOR
Whirlpool KFP500WH FOOD PROCESSOR
Whirlpool KFP600BU FOOD PROCESSOR
Whirlpool KFP600CH FOOD PROCESSOR
Whirlpool KFP600ER FOOD PROCESSOR
Whirlpool KFP600GN FOOD PROCESSOR
Whirlpool KFP600MY FOOD PROCESSOR
Whirlpool KFP600OB FOOD PROCESSOR
Whirlpool KFP600WH FOOD PROCESSOR
Whirlpool KFP600WW FOOD PROCESSOR
Whirlpool KFP650WH FOOD PROCESSOR
Whirlpool KFP670OB FOOD PROCESSOR
Whirlpool KFP670WH FOOD PROCESSOR
Whirlpool KFP710WH0 FOOD PROCESSOR 7 Cup
Whirlpool KFP710WH1 7-CUP FOOD PROCESSOR
Whirlpool KFP710WH2 7-CUP FOOD PROCESSOR
Whirlpool KFP715BW0 7-CUP FOOD PROCESSOR
Whirlpool KFP715BW2 7-CUP FOOD PROCESSOR
Whirlpool KFP715ER0 7-CUP FOOD PROCESSOR
Whirlpool KFP715ER2 7-CUP FOOD PROCESSOR
Whirlpool KFP715OB0 7-CUP FOOD PROCESSOR
Whirlpool KFP715OB2 7-CUP FOOD PROCESSOR
Whirlpool KFP715WH0 7-CUP FOOD PROCESSOR
Whirlpool KFP715WH2 7-CUP FOOD PROCESSOR
Whirlpool KFP720BU0 FOOD PROCESSOR 7 Cup
Whirlpool KFP720BU1 7-CUP FOOD PROCESSOR
Whirlpool KFP720BU2 7-CUP FOOD PROCESSOR
Whirlpool KFP720BW1 7-CUP FOOD PROCESSOR
Whirlpool KFP720BW2 7-CUP FOOD PROCESSOR
Whirlpool KFP720ER0 FOOD PROCESSOR 7 Cup
Whirlpool KFP720ER1 7-CUP FOOD PROCESSOR
Whirlpool KFP720ER2 7-CUP FOOD PROCESSOR
Whirlpool KFP720OB0 FOOD PROCESSOR 7 Cup
Whirlpool KFP720OB1 7-CUP FOOD PROCESSOR
Whirlpool KFP720OB2 7-CUP FOOD PROCESSOR
Whirlpool KFP720WH0 FOOD PROCESSOR 7 Cup
Whirlpool KFP720WH1 7-CUP FOOD PROCESSOR
Whirlpool KFP720WH2 7-CUP FOOD PROCESSOR
Whirlpool KFP740CR0 9-CUP FOOD PROCESSOR
Whirlpool KFP740QBF1 9-CUP FOOD PROCESSOR
Whirlpool KFP740QBF2 9-CUP FOOD PROCESSOR
Whirlpool KFP740QBF3 9-CUP FOOD PROCESSOR
Whirlpool KFP740QBW1 9-CUP FOOD PROCESSOR
Whirlpool KFP740QBW2 9-CUP FOOD PROCESSOR
Whirlpool KFP740QBW3 9-CUP FOOD PROCESSOR
Whirlpool KFP740QER1 9-CUP FOOD PROCESSOR
Whirlpool KFP740QER2 9-CUP FOOD PROCESSOR
Whirlpool KFP740QER3 9-CUP FOOD PROCESSOR
Whirlpool KFP740QGC1 9-CUP FOOD PROCESSOR
Whirlpool KFP740QGC2 9-CUP FOOD PROCESSOR
Whirlpool KFP740QGC3 9-CUP FOOD PROCESSOR
Whirlpool KFP740QOB1 9-CUP FOOD PROCESSOR
Whirlpool KFP740QOB2 9-CUP FOOD PROCESSOR
Whirlpool KFP740QOB3 9-CUP FOOD PROCESSOR
Whirlpool KFP740QWH1 9-CUP FOOD PROCESSOR
Whirlpool KFP740QWH2 9-CUP FOOD PROCESSOR
Whirlpool KFP740QWH3 9-CUP FOOD PROCESSOR
Whirlpool KFP740WH0 9-CUP FOOD PROCESSOR
Whirlpool KFP740WH1 9-CUP FOOD PROCESSOR
Whirlpool KFP740WH2 9-CUP FOOD PROCESSOR
Whirlpool KFP740WH3 9-CUP FOOD PROCESSOR
Whirlpool KFP750AQ2 MIDLINE FOOD PROCESSOR
Whirlpool KFP750AQ3 MIDLINE FOOD PROCESSOR 12-CUP
Whirlpool KFP750BU0 12-CUP FOOD PROCESSOR
Whirlpool KFP750BU1 12-CUP FOOD PROCESSOR
Whirlpool KFP750BW1 12-CUP FOOD PROCESSOR
Whirlpool KFP750BW2 MIDLINE FOOD PROCESSOR
Whirlpool KFP750CR0 12-CUP FOOD PROCESSOR
Whirlpool KFP750CR1 MIDLINE FOOD PROCESSOR
Whirlpool KFP750ER0 12-CUP FOOD PROCESSOR
Whirlpool KFP750ER1 12-CUP FOOD PROCESSOR
Whirlpool KFP750ER2 MIDLINE FOOD PROCESSOR
Whirlpool KFP750ER3 MIDLINE FOOD PROCESSOR 12-CUP
Whirlpool KFP750GC1 12-CUP FOOD PROCESSOR
Whirlpool KFP750GC2 MIDLINE FOOD PROCESSOR
Whirlpool KFP750OB0 12-CUP FOOD PROCESSOR
Whirlpool KFP750OB1 12-CUP FOOD PROCESSOR
Whirlpool KFP750OB2 MIDLINE FOOD PROCESSOR
Whirlpool KFP750OB3 MIDLINE FOOD PROCESSOR 12-CUP
Whirlpool KFP750PK0 12-CUP FOOD PROCESSOR
Whirlpool KFP750PK1 12-CUP FOOD PROCESSOR
Whirlpool KFP750PK2 MIDLINE FOOD PROCESSOR
Whirlpool KFP750PK3 MIDLINE FOOD PROCESSOR 12-CUP
Whirlpool KFP750WH0 12-CUP FOOD PROCESSOR
Whirlpool KFP750WH1 12-CUP FOOD PROCESSOR
Whirlpool KFP750WH2 MIDLINE FOOD PROCESSOR
Whirlpool KFP750WH3 MIDLINE FOOD PROCESSOR 12-CUP
Whirlpool KFPM770CR0 FOOD PROCESSOR 12 Cup (Wide Mouth)
Whirlpool KFPM770NK0 FOOD PROCESSOR
Whirlpool KFPM770NK1 MIDLINE FOOD PROCESSOR
Whirlpool KFPM770NK2 MIDLINE FOOD PROCESSOR 12 CUP - WIDE MOUTH/METALLIC
Whirlpool KFPM773CA0 ARCHITECT - FOOD PROCESSOR
Whirlpool KFPM773CS0 ARCHITECT - FOOD PROCESSOR
Whirlpool KFPW760CER2 MIDLINE FOOD PROCESSOR
Whirlpool KFPW760CER3 MIDLINE FOOD PROCESSOR 12 CUP - WIDE MOUTH
Whirlpool KFPW760COB0 FOOD PROCESSOR
Whirlpool KFPW760COB2 MIDLINE FOOD PROCESSOR
Whirlpool KFPW760COB3 MIDLINE FOOD PROCESSOR 12 CUP - WIDE MOUTH
Whirlpool KFPW760CR1 MIDLINE FOOD PROCESSOR 12 CUP - WIDE MOUTH
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge and freezer not cooling temp for both flashing 0 Biggie121 Refrigerator & Freezer Repair 9 01-27-2016 04:19 AM
Iced behind freezer back panel. Freezer and Fridge not cooling, temp around 50F guanacux Refrigerator & Freezer Repair 2 01-22-2014 10:37 AM
My refrigerator is not cooling/running consistently Whirlpool_fridge Refrigerator & Freezer Repair 4 01-06-2012 07:26 PM
Whirlpool Gold Fridge/Doesn't cycle consistently formalliving Refrigerator & Freezer Repair 3 06-07-2011 05:50 PM
ge fridge no cooling at all no lights on temp control rollerzonlyone Refrigerator & Freezer Repair 1 03-13-2009 07:43 PM
