Discuss
Long term refrigerator problem
 in
Refrigerator & Freezer Repair
Began having problems with 15+ yr old Kenmore side by side 2-1/2 yrs ago. It started with ice maker which
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Long term refrigerator problem
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-26-2018, 01:51 PM
Junior Member
michiganDIYman is on a distinguished road
Default Long term refrigerator problem
Model Number: 106.9550781   Brand: Kenmore   Age: More than 10 years
Began having problems with 15+ yr old Kenmore side by side 2-1/2 yrs ago. It started with ice maker which i replaced, but it probably was related to later symptoms of not keeping it cold enough, causing ice and frozen food to melt and temps to rise in fridge up towards room temp.
Each time,(many) we would take / move everything out before it spoiled to another fridge and freezer. Dumping ice drawer, emptying drip pan, wiping the wet out then turning off for an hour allowed it to come back on and work fine for a week or longer. The condenser coils were cleaned of dust / crap multiple times as was fan blades and area.
Thermostat was replaced (several times) because of either an off brand part or I kinked capillary tube on install. It worked for a while, only to repeat the same drill.
Next, the defrost timer was replaced, then the freezer coil heater and thermister. It still failed off and on with weeks, sometimes months in between before we had to do yet another food transfer to secondary refrigerator in the basement. Although the old girl is 36 yrs old, it has never so much as burped, but it is an ugly color.
In May this year, I finally determined the freezer coils were only getting frosty on the bottom two inches or so, indicating low freon. I put a vampire tap on the low refrigerant side and added a R-134 until the pressure was correct. While it was opened up, I removed the thin, metal partition in the back of the freezer covering the coils. I cut a 8" x 12" section out and replaced using double sticky tape to hold a piece of plexiglass in the opening. This allowed me to "see" coils and kept watch to insure they were uniformly frosty over the whole area. Checking every now and then, they remain frosty.
It's been almost 3 months. Every time we take something out of freezer or fridge we regularly check thermometer temps in both freezer and fridge.
They are consistently near 0 and slightly under 40 respectively. The exception is when the door is open for a to load new groceries on a warm day. A temperature recorder also verified temps holding, except for the the defrost cycle which show spike for a couple minutes in the defrost cycle.
As seems to be the case, it picks the worst time to warm up. I had just loaded a cooler with picnic stuff for a church picnic and had the door open for a bit. Both freezer and fridge were also stocked up from shopping trip yesterday. I was heading out the door, running late and my wife said, "hold it, ice is melting and temp in the freezer was 45 and climbing". This meant carrying everything downstairs to the standby refrigerator and I was late to church picnic.
The unit was turned off for an hour or so and back on. Now, an hour or so sine turned on, coils are uniformly frosty (visible through my plexiglass "window"). Temp in the freezer is zero and fridge is 37. Although these are just cheap thermometers, swapping them yields the same temps
Given I've eliminated just about every common fail point, can anyone give me a fresh, new idea? Does this point to the thermostat and possibly the capillary not installed perfectly? If so, why would it work for months and then crap out?
Have we reached the point where I can't breath life into this old horse anymore?
Related Models
Hoover 1060
Kenmore 1060359089 AIR CONDITIONER
Kenmore 10605 GRILL
Kenmore 106106-8130600 REFRIGERATOR
Kenmore 106106-8130610 REFRIGERATOR
Kenmore 106106-8130620 REFRIGERATOR
Kenmore 106106-8130630 REFRIGERATOR
Kenmore 106106-8130640 REFRIGERATOR
Kenmore 106106-8130650 REFRIGERATOR
Kenmore 106106-8130660 REFRIGERATOR
Kenmore 106106-8130680 REFRIGERATOR
Kenmore 106106-8130690 REFRIGERATOR
Kenmore 1061105299 ICEMAKER KIT
Kenmore 1061118553 ICEMAKER
Kenmore 1061118555 ICE MAKER
Craftsman 106161050 SEARS PAINT-TANK
Craftsman 106161051 PAINT TANK
Craftsman 106161430 SEARS PAINT TANK
Craftsman 106161450 SEARS PAINT-TANK
Craftsman 106170121 TANK TYPE COMPRESSOR
Craftsman 106170340 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106170341 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106170570 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106171141 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106171190 SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106172440 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106172441 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 1061895 CRAFTSMAN PAINT TANK
Craftsman 10618951 CRAFTSMAN PAINT TANK
Hoover 1062
Kenmore 1062155184 ICEMAKER
Kenmore 106257 WIDE WINDOW KITS
Kenmore 10629 OUTDOOR GRILL
Kenmore 10631400200 REFRIGERATOR
Kenmore 10631402200 REFRIGERATOR
Kenmore 10631404200 REFRIGERATOR
Kenmore 10631409200 REFRIGERATOR
Kenmore 10631410200 REFRIGERATOR
Kenmore 10631412200 REFRIGERATOR
Kenmore 10631414200 REFRIGERATOR
Kenmore 10631419200 REFRIGERATOR
Kenmore 10632242101 REFRIGERATOR
Kenmore 10632243101 REFRIGERATOR
Kenmore 10632249101 REFRIGERATOR
Kenmore 10632842010 REFRIGERATOR
Kenmore 10632852010 REFRIGERATOR
Kenmore 10632852011 REFRIGERATOR
Kenmore 10632853010 REFRIGERATOR
Kenmore 10632853011 REFRIGERATOR
Kenmore 10632862010 REFRIGERATOR
Kenmore 10632862011 REFRIGERATOR
Kenmore 10632863010 REFRIGERATOR
Kenmore 10632863011 REFRIGERATOR
Kenmore 10632872010 REFRIGERATOR
Kenmore 10632873010 REFRIGERATOR
Kenmore 10632882010 REFRIGERATOR
Kenmore 10632883010 REFRIGERATOR
Kenmore 10632889010 REFRIGERATOR
Kenmore 10632942101 REFRIGERATOR
Kenmore 10632943101 REFRIGERATOR
Kenmore 10632949101 REFRIGERATOR
Kenmore 10635705591 AIR CONDITIONER
Kenmore 10635710591 AIR CONDITIONER
Kenmore 10639420990 TOP MOUNT REFRIGERATOR
Kenmore 10639422990 TOP MOUNT REFRIGERATOR
Kenmore 10639424990 TOP MOUNT REFRIGERATOR
Kenmore 10639427990 TOP MOUNT REFRIGERATOR
Kenmore 10639430990 TOP MOUNT REFRIGERATOR
Kenmore 10639432990 TOP MOUNT REFRIGERATOR
Kenmore 10639434990 TOP MOUNT REFRIGERATOR
Kenmore 10639437990 TOP MOUNT REFRIGERATOR
Kenmore 10640212010 REFRIGERATOR
Kenmore 10640262010 REFRIGERATOR
Kenmore 10640263010 REFRIGERATOR
Kenmore 10640269010 REFRIGERATOR
Kenmore 10640562010 REFRIGERATOR
Kenmore 10640563010 REFRIGERATOR
Kenmore 10640563011 REFRIGERATOR
Kenmore 10640569010 REFRIGERATOR
Kenmore 10640569011 REFRIGERATOR
Kenmore 10641012100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641012101 REFRIGERATOR
Kenmore 10641012104 REFRIGERATOR
Kenmore 10641014100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641014101 REFRIGERATOR
Kenmore 10641014104 REFRIGERATOR
Kenmore 10641212100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641212101 REFRIGERATOR
Kenmore 10641214100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641214101 REFRIGERATOR
Kenmore 10641262800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641262801 SIDE-BY-SIDE
Kenmore 10641263800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641263801 SIDE-BY-SIDE
Kenmore 10641263802 REFRIGERATOR
Kenmore 10641264800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641264801 SIDE-BY-SIDE
Kenmore 10641269800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641269801 SIDE-BY-SIDE
Kenmore 10641512100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641512101 REFRIGERATOR
Kenmore 10641514100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641514101 REFRIGERATOR
Kenmore 10641519100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641519101 REFRIGERATOR
Kenmore 10641522500 SIDE BY SIDE REFRIGERATOR
Kenmore 10641523500 SIDE BY SIDE REFRIGERATOR
Kenmore 10641524500 SIDE BY SIDE REFRIGERATOR
Kenmore 10641529500 SIDE BY SIDE REFRIGERATOR
Kenmore 10641562800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641562801 SIDE-BY-SIDE
Kenmore 10641562802 REFRIGERATOR
Kenmore 10641563800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641563801 SIDE-BY-SIDE
Kenmore 10641563802 REFRIGERATOR
Kenmore 10641563803 REFRIGERATOR
Kenmore 10641564800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641564801 SIDE-BY-SIDE
Kenmore 10641564802 REFRIGERATOR
Kenmore 10641569800 SIDE-BY-SIDE REFRIGERATOR
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
