Discuss
Amana Fridge Defrost Issue
 in
Refrigerator & Freezer Repair
Hello, I am having a peculiar issue with this Amana Fridge I got from a friend. When the defrost heater
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Fridge Defrost Issue
  #1 (permalink)
Old 08-16-2018, 07:54 PM
Junior Member
splash1995 is on a distinguished road
Default Amana Fridge Defrost Issue
Model Number: SXD26VE   Brand: Amana   Age: More than 10 years
Hello,
I am having a peculiar issue with this Amana Fridge I got from a friend. When the defrost heater turns on, the evaporator fan still runs, which blasts super hot air into the freezer, melting everything in there. Then once the defrost mode finishes (about 30 mins?), it goes back to cooling mode, and of course it takes a long time to chill the freezer down again. I suspect this is NOT normal operation, since everything in the freezer is basically thawed and refrozen every defrost cycle. This also affects the refrigerator side, but since there seems to be little airflow between the two sides anyways (probably a separate issue), it doesn't warm as much as the freezer does. I have changed the defrost timer already, and no change.
Other observations:
1. The fridge seems to cool just fine; when it isn't battling the defrost heater of course.
2. The defrost timing cycle seems to happen as it should; minus the evaporator fan not turning off when the defrost heater is on.
3. There seems to be very little air flow from the refrigerator side vent, though the freezer side has strong air flow. Probably a separate issue, but I would like to fix that as well at some point.
4. I have external fridge thermostats on both sides, and can monitor the temperature changes after the defrost mode turns off, and the compressor turns on. The fridge will run non-stop it seems to cool down again.
I think that is it. I haven't found any post about my specific problem, so I am hoping someone here can put the pieces together for me. Plus I don't want to just throw a bunch of parts willy-nilly at a free fridge at this point. Thank you all for your time!
Related Models
Amana SXD26VE REF - SXS/I&W
Amana SXD26VL REF - SXS/I&W
Amana SXD26VW REF - SXS/I&W
Amana SXD27NE REF - SXS/I&W
Amana SXD27NL REF - SXS/I&W
Amana SXD27NW REF - SXS/I&W
Amana SXD27Q2E REF - SXS/I&W
Amana SXD27Q2L REF - SXS/I&W
Amana SXD27Q2W REF - SXS/I&W
Amana SXD27TE REF - SXS/I&W
Amana SXD27TL REF - SXS/I&W
Amana SXD27TW REF - SXS/I&W
Amana SXD322L REF - SXS/I&W
Amana SXD322S2L REF - SXS/I&W
Amana SXD322S2W REF - SXS/I&W
Amana SXD322W REF - SXS/I&W
Amana SXD520NW REF - SXS/I&W
Amana SXD520SL REF - SXS/I&W
Amana SXD520SW REF - SXS/I&W
Amana SXD520TE REF - SXS/I&W
Amana SXD520TW REF - SXS/I&W
Amana SXD522VE REF - SXS/I&W
Amana SXD522VW REF - SXS/I&W
Amana SXD524VE REF - SXS/I&W
Amana SXD524VW REF - SXS/I&W
Amana SXDE25J REF - SXS/I&W
Amana SXDE25JB REF - SXS/I&W
Amana SXDE25JP REF - SXS/I&W
Amana SXDE27NE REF - SXS/I&W
Amana SXDE27NL REF - SXS/I&W
Amana SXDE27NPE REF - SXS/I&W
Amana SXDE27NPL REF - SXS/I&W
Amana SXDE27NPW REF - SXS/I&W
Amana SXDE27NW REF - SXS/I&W
Amana SXDE27QE REF - SXS/I&W
Amana SXDE27QL REF - SXS/I&W
Amana SXDE27QW REF - SXS/I&W
Amana SXDE522K REF - SXS/I&W
Amana SXDE522M REF - SXS/I&W
Amana SXDE526K REF - SXS/I&W
Amana SXDE526M REF - SXS/I&W
Amana SXDE528MW REF - SXS/I&W
Amana SXDT22H REF - SXS/I&W
Amana SXDT25H REF - SXS/I&W
Amana SXDT522J REF - SXS/I&W
Amana SXDT522K REF - SXS/I&W
Amana SXDT522M REF - SXS/I&W
Amana SXDT526J REF - SXS/I&W
Amana SXI20J REF - SXS/I&W
Amana SXI20NE REF - SXS/I&W
Amana SXI20NL REF - SXS/I&W
Amana SXI20NW REF - SXS/I&W
Amana SXI25SE REF - SXS/I&W
Amana SXI25SL REF - SXS/I&W
Amana SXI25SW REF - SXS/I&W
Amana SXP22H REF - SXS/I&W
Amana SXP25H REF - SXS/I&W
Amana SXPD20H REF - SXS/I&W
Amana SXPD22H REF - SXS/I&W
Amana SXPD25H REF - SXS/I&W
Amana SZ22MBL REF - SXS/I&W
Amana SZ22MBW REF - SXS/I&W
Amana SZ22ML REF - SXS/I&W
Amana SZ22MW REF - SXS/I&W
Amana SZ22NE REF - SXS/I&W
Amana SZ22NL REF - SXS/I&W
Amana SZ22NW REF - SXS/I&W
Amana SZ25M2L REF - SXS/I&W
Amana SZ25M2W REF - SXS/I&W
Amana SZ25ML REF - SXS/I&W
Amana SZ25MP2L REF - SXS/I&W
Amana SZ25MP2W REF - SXS/I&W
Amana SZ25MPL REF - SXS/I&W
Amana SZ25MPW REF - SXS/I&W
Amana SZ25MW REF - SXS/I&W
Amana SZ25NE REF - SXS/I&W
Amana SZ25NL REF - SXS/I&W
Amana SZ25NW REF - SXS/I&W
Amana SZD20J Ref - SXS/I&W
Amana SZD20K REF - SXS/I&W
Amana SZD20KB REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost cycle issue - how to force defrost? jlatenight Refrigerator & Freezer Repair 0 05-20-2014 09:11 AM
Amana defrost issue CapeCoddah Refrigerator & Freezer Repair 2 04-11-2013 01:56 AM
LG fridge fan won't turn-error ER FF (NOT a defrost issue) NorthNJ Refrigerator & Freezer Repair 0 08-06-2012 10:20 AM
Amana Bottom Freezer Refridgerator Defrost Issue RycherGirl Refrigerator & Freezer Repair 1 11-11-2009 02:38 AM
Defrost Terminator on Amana fridge bobdavisnpf Refrigerator & Freezer Repair 0 03-30-2009 03:35 PM
