Discuss
upright not going below 22 degrees
 in
Refrigerator & Freezer Repair
Freezer is just over 5 years old (1/13). Problems stated when one of our many afternoon thunderstorms rolled in. Yes
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » upright not going below 22 degrees
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-24-2018, 04:49 PM
Junior Member
thom12 is on a distinguished road
Default upright not going below 22 degrees
Model Number: LFFH21F7HWJ   Brand: Frigidaire   Age: 1 - 5 years
Freezer is just over 5 years old (1/13). Problems stated when one of our many afternoon thunderstorms rolled in. Yes there were lighting strikes in the area and several appliances took hits (freezer just one of them). Symptoms started with high temp alarm and 23* displayed, and confirmed with I/R thermometer. Attempted to enter diagnostic mode by pressing both up and down arrows at same time. It never entered diagnostic mode. The condenser fan is operational (all the time) and circulating air nicely. At this point, I figured control board is shot.
Replaced control board and plugged it back in. Still not able to enter diagnostic mode and the temp never went below 23* after 2 days with the new control panel.
Next I tried the defrost thermostat. There was not any frost on any of the coils. Same result, 23* coldest after 2 days, no diagnostics.
I do not believe (but I am not an expert) that the issue would be the cabinet thermostat since the control panel is registering 23* and that is confirmed by the I/R thermostat.
Summary: freezer won't go below 23* and no access to diagnostic mode (even after replacing control board). There are no cold air leaks around the door seal.
Any help would be awesome!
Thanks,
Thom
Related Models
Frigidaire LFFH21F7HWJ FREEZER
Frigidaire LFFN15M5HWA FREEZER
Frigidaire LFFN15M5HWB FREEZER
Frigidaire LFFU1153DW0 Frigidaire/freezer
Frigidaire LFFU1153DW1 Frigidaire/freezer
Frigidaire LFFU1153DW2 Frigidaire/freezer
Frigidaire LFFU1153DW3 Frigidaire/freezer
Frigidaire LFFU1424DW0 Frigidaire/freezer
Frigidaire LFFU1424DW1 Frigidaire/freezer
Frigidaire LFFU1424DW10 FREEZER
Frigidaire LFFU1424DW11 FREEZER
Frigidaire LFFU1424DW12 FREEZER
Frigidaire LFFU1424DW13 FREEZER
Frigidaire LFFU1424DW14 FREEZER
Frigidaire LFFU1424DW15 FREEZER
Frigidaire LFFU1424DW16 FREEZER
Frigidaire LFFU1424DW2 Frigidaire/freezer
Frigidaire LFFU1424DW3 Frigidaire/freezer
Frigidaire LFFU1424DW4 Frigidaire/freezer
Frigidaire LFFU1424DW5 Frigidaire/freezer
Frigidaire LFFU1424DW6 FREEZER
Frigidaire LFFU1424DW7 FREEZER
Frigidaire LFFU1424DW8 FREEZER
Frigidaire LFFU1424DW9 FREEZER
Frigidaire LFFU1465DW0 Frigidaire/freezer
Frigidaire LFFU1465DW1 Frigidaire/freezer
Frigidaire LFFU1465DW2 Frigidaire/freezer
Frigidaire LFFU1465DW3 Frigidaire/freezer
Frigidaire LFFU1465DW4 Frigidaire/freezer
Frigidaire LFFU1465DW5 Frigidaire/freezer
Frigidaire LFFU1465DW6 Frigidaire/freezer
Frigidaire LFFU1466GW0 FREEZER
Frigidaire LFFU1466GW1 FREEZER
Frigidaire LFFU1466GW2 FREEZER
Frigidaire LFFU1466GW3 FREEZER
Frigidaire LFFU14F5HWA FREEZER
Frigidaire LFFU14F5HWB FREEZER
Frigidaire LFFU14F5HWC FREEZER
Frigidaire LFFU14F5HWD FREEZER
Frigidaire LFFU14F5HWE FREEZER
Frigidaire LFFU14F5HWF FREEZER
Frigidaire LFFU14F5HWG FREEZER
Frigidaire LFFU14F5HWH FREEZER
Frigidaire LFFU14F5HWJ FREEZER
Frigidaire LFFU14F5HWK FREEZER
Frigidaire LFFU14F5HWL FREEZER
Frigidaire LFFU14F5HWM FREEZER
Frigidaire LFFU14F5HWN FREEZER
Frigidaire LFFU1765DW0 Frigidaire/freezer
Frigidaire LFFU1765DW1 Frigidaire/freezer
Frigidaire LFFU1765DW11 Frigidaire/freezer
Frigidaire LFFU1765DW12 Frigidaire/freezer
Frigidaire LFFU1765DW13 Frigidaire/freezer
Frigidaire LFFU1765DW14 Frigidaire/freezer
Frigidaire LFFU1765DW15 Frigidaire/freezer
Frigidaire LFFU1765DW16 FREEZER
Frigidaire LFFU1765DW2 Frigidaire/freezer
Frigidaire LFFU1765DW3 Frigidaire/freezer
Frigidaire LFFU1765DW4 Frigidaire/freezer
Frigidaire LFFU1765DW5 Frigidaire/freezer
Frigidaire LFFU1765DW6 Frigidaire/freezer
Frigidaire LFFU1765DW8 Frigidaire/freezer
Frigidaire LFFU1765DW9 Frigidaire/freezer
Frigidaire LFFU1766GW1 FREEZER
Frigidaire LFFU1766GW2 FREEZER
Frigidaire LFFU1766GW3 FREEZER
Frigidaire LFFU1766GW4 FREEZER
Frigidaire LFFU17F5HWA FREEZER
Frigidaire LFFU17F5HWB FREEZER
Frigidaire LFFU17F5HWC FREEZER
Frigidaire LFFU17F5HWD FREEZER
Frigidaire LFFU17F5HWE FREEZER
Frigidaire LFFU17F5HWF FREEZER
Frigidaire LFFU17F5HWG FREEZER
Frigidaire LFFU17F5HWH FREEZER
Frigidaire LFFU17F5HWJ FREEZER
Frigidaire LFFU17F5HWK FREEZER
Frigidaire LFFU17F5HWL FREEZER
Frigidaire LFFU2065DW0 Frigidaire/freezer
Frigidaire LFFU2065DW1 Frigidaire/freezer
Frigidaire LFFU2065DW10 Frigidaire/freezer
Frigidaire LFFU2065DW2 Frigidaire/freezer
Frigidaire LFFU2065DW3 Frigidaire/freezer
Frigidaire LFFU2065DW4 Frigidaire/freezer
Frigidaire LFFU2065DW5 Frigidaire/freezer
Frigidaire LFFU2065DW6 Frigidaire/freezer
Frigidaire LFFU2065DW7 Frigidaire/freezer
Frigidaire LFFU2065DW8 Frigidaire/freezer
Frigidaire LFFU2065DW9 Frigidaire/freezer
Frigidaire LFFU2067DS0 Frigidaire/freezer
Frigidaire LFGF3014LBA GAS RANGE
Frigidaire LFGF3014LBB GAS RANGE
Frigidaire LFGF3014LBC GAS RANGE
Frigidaire LFGF3014LWA GAS RANGE
Frigidaire LFGF3014LWB GAS RANGE
Frigidaire LFGF3014LWC GAS RANGE
Frigidaire LFGF3022LSA GAS RANGE
Frigidaire LFGF3022LSB GAS RANGE
Frigidaire LFGF3022LSC GAS RANGE
Frigidaire LFGF3022LSD GAS RANGE
Frigidaire LFGF3022LWA GAS RANGE
Frigidaire LFGF3022LWC GAS RANGE
Frigidaire LFGF3027LBA GAS RANGE
Frigidaire LFGF3027LBB GAS RANGE
Frigidaire LFGF3027LSA GAS RANGE
Frigidaire LFGF3027LSB GAS RANGE
Frigidaire LFGF3027LSC GAS RANGE
Frigidaire LFGF3027LWA GAS RANGE
Frigidaire LFGF3027LWB GAS RANGE
Frigidaire LFHI1826LB0 REFRIGERATOR
Frigidaire LFHI1826LM0 REFRIGERATOR
Frigidaire LFHI1826LW0 REFRIGERATOR
Frigidaire LFHT1513LB0 REFRIGERATOR
Frigidaire LFHT1513LB1 REFRIGERATOR
Frigidaire LFHT1513LB2 REFRIGERATOR
Frigidaire LFHT1513LB3 REFRIGERATOR
Frigidaire LFHT1513LB4 REFRIGERATOR
Frigidaire LFHT1513LB5 REFRIGERATOR
Frigidaire LFHT1513LW0 REFRIGERATOR
Frigidaire LFHT1513LW1 REFRIGERATOR
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fridge bottom 25 degrees, top 50 degrees regardless of FF control setting mgb4ever Refrigerator & Freezer Repair 0 02-28-2014 05:06 PM
Upright Freezer alarm went off, temp is 20 degrees jimmar Refrigerator & Freezer Repair 0 10-12-2013 05:57 AM
Fridge is warm 54 degrees and freezer is 7 degrees kassull Refrigerator & Freezer Repair 0 08-15-2012 02:50 PM
Freezer/Upright Outside use to -10 Degrees Pacman Refrigerator & Freezer Repair 1 11-08-2009 07:54 AM
upright freezer staying at 25 degrees fimrite Refrigerator & Freezer Repair 0 03-19-2009 06:28 PM
