Discuss
Upright freezer stopped working
 in
Refrigerator & Freezer Repair
Freezer was working fine but on 11/02/09. I went to my garage and found all my food thawed
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Upright freezer stopped working
  #1 (permalink)
Old 11-05-2009, 06:36 PM
delphino delphino is offline
Junior Member
delphino is on a distinguished road
Default Upright freezer stopped working
Model Number: ffu2064dw2   Brand: Frigidaire   Age: 5 - 10 years
Freezer was working fine but on 11/02/09. I went to my garage and found all my food thawed out. I heard the freezer still working,but today 11/05/09 everything went bad and nothing runs only the light turns on. I hope I could get help in how to fix it.
Thank You
Delphino
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 11-06-2009, 07:10 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for FRG FFU2064DW2 | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodin.../297010000.pdf
Could be that you were in a defrost cycle, the second time you checked it.
The evaporator fan goes off when in defrost.
The defrost timer looks like it is at the back by the compressor.
Rotate the cam to see if you can get the compressor to come on.
Remove the evaporator coil cover to see if it is a defrost problem.
Turn the temperature control to off the back on, sometimes thermostats can stick.
Your problem can be a number of things.
Compressor is toast
Compressor starter is toast
Evaporator is not defrosting
The thermostat is toast.
Here is a good link much of the fridge info also applies to a freezer.
http://www.applianceaid.com/repair-help.html
__________________
  #3 (permalink)
Old 11-06-2009, 06:30 PM
Junior Member
Default Thanks for your help Denman
I unplugged the freezer for five hours and then plugged it back up. It works but does not get cold. I read on another thread that it might be the relay. I looked through the diagrams and did not find no relay. Could someone give me a hand
  #4 (permalink)
Old 11-07-2009, 07:43 AM
Senior Expert
APP Volunteer
Default
You say it works so if the compressor is running re: it is warm and you can feel it vibrating then it is probably not be the relay.
If the compressor is not running then it may be the relay. See Item 30 in Section 4, they call it a controller and it is listed at the bottom of the page as Item F30.
If the compressor is not starting it could also be that the thermostat's contacts are not close so the relay does not get any power.
Also I would not replace the relay without checking the compressor windings first with a meter. And checking that it is getting power from the thermostat.
Here is another good link on how to check things
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
upright freezer stopped working / will not start wuba Refrigerator & Freezer Repair 2 11-07-2009 05:54 AM
GE upright freezer not working properly. MVMOORE70 Refrigerator & Freezer Repair 0 09-23-2009 08:22 PM
GE Upright freezer not working properly crazymomvivi Refrigerator & Freezer Repair 0 07-30-2009 07:49 PM
Frigidaire Upright freezer not working MPp Refrigerator & Freezer Repair 3 05-11-2009 03:24 PM
upright freezer stopped working drjfwright Refrigerator & Freezer Repair 4 04-05-2008 06:32 AM
