Discuss
GE side by side refrigerator freezer not cooling
 in
Refrigerator & Freezer Repair
Hi. Having a problem with freezer, fridge. We had a power outage and the unit was fun on a generator
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE side by side refrigerator freezer not cooling
  #1 (permalink)
Old 06-10-2018, 04:21 PM
Junior Member
ReddogRudy is on a distinguished road
Default GE side by side refrigerator freezer not cooling
Model Number: GSHF5KGXBCWW   Brand: GE   Age: 5 - 10 years
Hi. Having a problem with freezer, fridge. We had a power outage and the unit was fun on a generator for about 2 hours. Power restored, and ran for another day. Came home to find water leaking from front I've dispenser. Door seemed to have been left ajar and as ice bin seemed to be pushed forward out of place. Temp on door said fridge was about 48 and freezer was 39 Reset bin closed door. Unit was running all the while. After about an hour apparent it was not getting cold. Removed everything and let run overnight. Temperature on door came down to 42 and 35. Called local tech and described problem. He was honest and up front and said it sounded electronic and really did not want to get into it. Ok checked on line found this sight started to check out. Could at bottom and condenser can were dirty especially from the harder to access front of coil. Cleaned with soft brush, compressed air and vacuum. Removed unit in ran for about 2 to 3 hours temperature on changed a degree of to. Temperature read 51 fridge, 44 freezer. Adjusting temperature control is bad no effect. Next took off read freezer panel. Evaporator coils had approx 1 to 2 inches of ice along entire left side starting a quarter of the way across top. Used a low heat hair dryer several inches from coil to melt ice. Checked to see if any damage to temp sensor. Nothing appeared unusual. Replaced cover plugged unit back in. Problem now worse. Temp in fridge said 63 and freezer said -5. There was no air even moving into fridge now. Tried adjusting temp again. Said actual temp was now 63 fridge and now-9 in freezer but both completely warm. Checked run capacitor. It shows on multimeter no resistance. Evaporator and condenser can both running. Motherboard has slight discoloration along side i believe what is described as the fan resistors. No capacitors are bulged but one large capacitor has a white hard substance all around its bottom which has partially covered 2 other small components. Defrost heater circuit shows its functioning. Any help with this problem would be greatly appreciated. I just don't want to junk this unit, I have had no issues with it till now.
Related Models
General Electric GSHF5KGXBCWW REFRIGERATOR X SERIES
General Electric GSHF5KGXCCBB REFRIGERATOR X SERIES
General Electric GSHF5KGXCCCC REFRIGERATOR X SERIES
General Electric GSHF5KGXCCWW REFRIGERATOR X SERIES
General Electric GSHF5KGXDCBB REFRIGERATOR X SERIES
General Electric GSHF5KGXDCWW REFRIGERATOR X SERIES
General Electric GSHF5KGXECBB REFRIGERATOR X SERIES
General Electric GSHF5KGXECCC REFRIGERATOR X SERIES
General Electric GSHF5KGXECWW REFRIGERATOR X SERIES
General Electric GSHF5KGXFCBB REFRIGERATOR X SERIES
General Electric GSHF5KGXFCCC REFRIGERATOR X SERIES
General Electric GSHF5KGXFCWW REFRIGERATOR X SERIES
General Electric GSHF5KGXGCBB REFRIGERATOR X SERIES
General Electric GSHF5KGXGCCC REFRIGERATOR X SERIES
General Electric GSHF5KGXGCWW REFRIGERATOR X SERIES
General Electric GSHF5MGXBEBB REFRIGERATOR X SERIES
General Electric GSHF5MGXBEWW REFRIGERATOR X SERIES
General Electric GSHF5MGXCEBB REFRIGERATOR X SERIES
General Electric GSHF5MGXCEWW REFRIGERATOR X SERIES
General Electric GSHF5MGXGEBB REFRIGERATOR X SERIES
General Electric GSHF5MGXGEWW REFRIGERATOR X SERIES
General Electric GSHF5PGXAEBB REFRIGERATOR X SERIES
General Electric GSHF5PGXAEWW REFRIGERATOR X SERIES
General Electric GSHF5PGXCEBB REFRIGERATOR X SERIES
General Electric GSHF5PGXCEWW REFRIGERATOR X SERIES
General Electric GSHF6KGZBCBB REFRIGERATOR Z SERIES
General Electric GSHF6KGZBCCC REFRIGERATOR Z SERIES
General Electric GSHF6KGZBCWW REFRIGERATOR Z SERIES
General Electric GSHF6LGBBHBB REFRIGERATOR B SERIES
General Electric GSHF6LGBBHWW REFRIGERATOR B SERIES
General Electric GSHF6LGBCHBB REFRIGERATOR B SERIES
General Electric GSHF6LGBCHWW REFRIGERATOR B SERIES
General Electric GSHF6LGZBCBB REFRIGERATOR Z SERIES
General Electric GSHF6LGZBCWW REFRIGERATOR Z SERIES
General Electric GSHF6NGBBHBB REFRIGERATOR N SERIES
General Electric GSHF6NGBBHWW REFRIGERATOR N SERIES
General Electric GSHF6NGBCHBB REFRIGERATOR B SERIES
General Electric GSHF6NGBCHWW REFRIGERATOR B SERIES
General Electric GSHF6PGYAEBB REFRIGERATOR Y SERIES
General Electric GSHF6PGYAEWW REFRIGERATOR Y SERIES
General Electric GSHF6PHXBEBB REFRIGERATOR X SERIES
General Electric GSHF6PHXBEWW REFRIGERATOR X SERIES
General Electric GSHF6PHXCEBB REFRIGERATOR X SERIES
General Electric GSHF6PHXCEWW REFRIGERATOR X SERIES
General Electric GSHF6PHXIEBB REFRIGERATOR X SERIES
General Electric GSHF6PHXIEWW REFRIGERATOR X SERIES
Whirlpool GSHF7801W0 Dishwasher
Whirlpool GSHF7804W0 Dishwasher
Whirlpool GSHF7804W1 Dishwasher
Whirlpool GSHF7884P0 Dishwasher
Whirlpool GSHF7884P1 Dishwasher
Whirlpool GSHF7884P2 Dishwasher
General Electric GSHF9NGYACBB REFRIGERATOR Y SERIES
General Electric GSHF9NGYACWW REFRIGERATOR Y SERIES
General Electric GSHL5KGXBCLS REFRIGERATOR X SERIES
General Electric GSHL5KGXCCLS REFRIGERATOR X SERIES
General Electric GSHL5KGXDCLS REFRIGERATOR X SERIES
General Electric GSHL5KGXECLS REFRIGERATOR X SERIES
General Electric GSHL5KGXGCLS REFRIGERATOR X SERIES
General Electric GSHL5MGXBELS REFRIGERATOR X SERIES
General Electric GSHL5MGXCELS REFRIGERATOR X SERIES
General Electric GSHL5MGXGELS REFRIGERATOR X SERIES
General Electric GSHL6KGZBCLS REFRIGERATOR Z SERIES
General Electric GSHL6PHXBELS REFRIGERATOR X SERIES
General Electric GSHL6PHXCELS REFRIGERATOR X SERIES
General Electric GSHL6PHXIELS REFRIGERATOR X SERIES
General Electric GSHS3KGXBCSS REFRIGERATOR X SERIES
General Electric GSHS3KGXCCSS REFRIGERATOR X SERIES
General Electric GSHS3KGXGCSS REFRIGERATOR X SERIES
General Electric GSHS3KGXHCSS REFRIGERATOR X SERIES
General Electric GSHS3KGZBCSS REFRIGERATOR Z SERIES
General Electric GSHS5KGXBCSS REFRIGERATOR X SERIES
General Electric GSHS5KGXCCSS REFRIGERATOR X SERIES
General Electric GSHS5KGXDCSS REFRIGERATOR X SERIES
General Electric GSHS5KGXECSS REFRIGERATOR X SERIES
General Electric GSHS5KGXGCSS REFRIGERATOR X SERIES
General Electric GSHS5MGXBESS REFRIGERATOR X SERIES
General Electric GSHS5MGXCESS REFRIGERATOR X SERIES
General Electric GSHS5MGXGESS REFRIGERATOR X SERIES
General Electric GSHS5PGXAESS REFRIGERATOR X SERIES
General Electric GSHS5PGXCESS REFRIGERATOR X SERIES
General Electric GSHS6KGZBCSS REFRIGERATOR Z SERIES
General Electric GSHS6LGBBHSS REFRIGERATOR B SERIES
General Electric GSHS6LGZBCSS REFRIGERATOR Z SERIES
General Electric GSHS6NGBBHSS REFRIGERATOR N SERIES
General Electric GSHS6PGYAESS REFRIGERATOR Y SERIES
General Electric GSHS9NGYACSS REFRIGERATOR Y SERIES
Whirlpool GSHU3024W0 Dishwasher
Whirlpool GSHU3024W1 Dishwasher
Frigidaire GSIE36WH2-00 Tap(v16) / Side By Side Refrigerator
Frigidaire GSIW36AH2 Frg(v2) / Side By Side Refrigerator
Frigidaire GSIW36BH1 Frg(v5) / Side By Side Refrigerator
Frigidaire GSIW36BH2 Frg(v5) / Side By Side Refrigerator
Frigidaire GSIW36CH1 Frg(v4) / Side By Side Refrigerator
Frigidaire GSIW36CH2 Frg(v4) / Side By Side Refrigerator
Frigidaire GSIW36DH1 Wwh(v10) / Side By Side Refrigerator
Frigidaire GSIW36EH1 Gib(v14) / Side By Side Refrigerator
Frigidaire GSIW36FH1 Gib(v12) / Side By Side Refrigerator
Frigidaire GSIW36HH1 Tap(v4) / Side By Side Refrigerator
Frigidaire GSIW36HH2 Gib(v3) / Side By Side Refrigerator
Frigidaire GSIW36JH1 Kel(v23) / Side By Side Refrigerator
Frigidaire GSIW36VH1 Kel(v22) / Side By Side Refrigerator
Roper GSIW36WH1 REFRIGERATOR
Frigidaire GSIW36WH1-00 Tap(v16) / Side By Side Refrigerator
Frigidaire GSIW36WH1-23 Tap(v20) / Side By Side Refrigerator
Frigidaire GSIW36WH1-45 Tap(v19) / Side By Side Refrigerator
Frigidaire GSIW36WH1-57 Tap(v17) / Side By Side Refrigerator
Frigidaire GSIW36WHD1 Wwh(v10) / Side By Side Refrigerator
Frigidaire GSIW36WHD2 Wwh(v10) / Side By Side Refrigerator
Frigidaire GSIW36WHE1 Gib(v14) / Side By Side Refrigerator
Frigidaire GSIW36WHE2 Gib(v14) / Side By Side Refrigerator
Frigidaire GSIW36WHF1 Gib(v12) / Side By Side Refrigerator
Frigidaire GSIW36WHF2 Gib(v12) / Side By Side Refrigerator
Frigidaire GSIW36WHJ1 Kel(v23) / Side By Side Refrigerator
Frigidaire GSIW36WHJ2 Kel(v23) / Side By Side Refrigerator
Frigidaire GSIW36WHV1 Kel(v22) / Side By Side Refrigerator
Frigidaire GSIW36WHV2 Kel(v22) / Side By Side Refrigerator
Frigidaire GSIW36WHW2 Frg(v1) / Side By Side Refrigerator
Frigidaire GSIW36YH1 Gib(v13) / Side By Side Refrigerator
General Electric GSK25LAPCCCC Refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Side by side freezer or refrigerator not cooling shopgirloh Refrigerator & Freezer Repair 5 09-29-2016 12:48 PM
GE Side by Side Refrigerator- Freezer Cold- Fresh Food Side Warm mosquito jones Refrigerator & Freezer Repair 0 02-07-2015 09:16 PM
GE side by side refrigerator - upper half not cooling and no ice cubes or water ngarey Refrigerator & Freezer Repair 0 09-13-2011 01:01 PM
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
Refrigerator/freezer side by side not cooling tennfly Refrigerator & Freezer Repair 2 06-02-2011 08:04 PM
