This is probably posted somewhere but I haven't been able to search for it successfully.
I have to change the damper in my Frigidaire Refrigerator Model GLHS65EHW6. After looking at a number of videos I felt confident in doing so. I realized when I started removing the necessary parts my refrigerator has a water filter on the front control whose removal was not shown on any of the videos.
I unscrewed all of the screws on the side starting where the damper is and in the front. I don't know what I need to remove on the right side where the water filter assembly is located. I looked at the video for replacing the filter base but I'm not replacing that part. Disappointed after the ordeal of unscrewing those screws you can't see.
