Discuss
Refrigerator Tripping Circuit Breaker
 in
Refrigerator & Freezer Repair
Need help diagnosing an intermittent problem. Refrigerator trips circuit breaker every few hours for a couple of days then works
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Tripping Circuit Breaker
  #1 (permalink)
Old 05-11-2018, 01:30 PM
Junior Member
236384 is on a distinguished road
Default Refrigerator Tripping Circuit Breaker
Model Number: FPHF2399MF0   Brand: Frigidaire   Age: 5 - 10 years
Need help diagnosing an intermittent problem. Refrigerator trips circuit breaker every few hours for a couple of days then works normally for a few months. Unit is Frigidaire FPHF2399MF0 purchased new in 2011. (French door unit with ice maker in upper fresh food compartment). Used indoors.
Unit continues to cool well as long as it is powered. After restarting, if either compartment was too warm, the unit cools them down as quickly as can be expected (an hour or so). Sounds fine. None of usual symptoms other than the cube/crush selector is stuck at crush.
Some (or lots of) history:
Oct 2017(?):
-Ice dispenser only dispensed crushed ice after re-installation after remodel, but we ignored it.
1st week Feb 2018:
-Found fridge off and breaker tripped. Reset breaker and unit ran for 3-8 hours before tripping again. This continued for a few days.
-Switched off ice maker during this period in an attempt to eliminate unnecessary load.
-Meanwhile, ran fridge on other circuit which also tripped breaker. Seems house wiring ok, Fridge is the problem.
-Repair guy came, visually checked the control board, which he thought was fine so he figured the compressor was going bad, expensive repair => just buy a new one. (Later learned that he actually checked the inverter board for the variable speed compressor, not main control board). Repair guy cleaned the very dusty coils.
-Unit tripped breaker maybe one or two more times since then and then ran normally...
-Turned ice maker back on at some point.
1st week May 2018:
-Again, found fridge off and breaker tripped. Reset breaker and unit ran for 3-8 hours before tripping again. This continued again for a few days.
-Switched off ice maker again in an attempt to eliminate unnecessary load.
-Tried the unit's diagnostic mode. Tested all components individually. Cube/Crush solenoid still did not work. Switching on defrost heater tripped the breaker one time, but could not replicate in subsequent attempts.
-Next day, tested functions in diagnostic mode while measuring current draw in the main AC cable. Nothing seemed unusual, but I don't know the expected current draw. Compressor: 2.0A, Ice Auger motor (no ice): 3.0A, Defrost Heater 5.0A. Ran unit overnight, max draw 2.0A. No more breaker tripping -> So these measurements may have been taken without the fault present.
-Inspected main control board, a loose piece fell out upon removal, it was a chip off of a small transistor controlling the cube/crush solenoid. Measured voltage to solenoid at connector near icemaker, 7.9VAC in either cube or crush. Manually moving the solenoid latch felt no different if it was turned off or on.
-Freezer defrost heater measured ~230Ohms, measured at main board connector. Ice maker defrost heater measured 20Ohms, measured at ice maker connector.
-Compressor coils measured 17.3/17.3/17.7 Ohms.
Outside back panel has rusty streak which starts behind the ice maker defrost drain. I think this was always there. If so, it could be due to condensation rather than a leak.
Questions:
Any ideas on what else to check? Or how to replicate? I'm not sure how long the ice maker had been back on before the problem occurred again. At least a month or more?
The cube/crush solenoid/transistor are obviously a problem but could that be the root cause of the breaker tripping? I could replace the main board and/or cube/crush solenoid, but I'm not confident that either caused the breaker to trip given that it runs normally for months in that condition.
Since it runs a while before tripping, I'm suspicious of the defrost cycle.
I'm wondering if keeping the ice maker off might be allowing the problem to right itself, even though the ice maker coils/fan are still cooling that compartment.
Related Models
Frigidaire FPHF2399MF0 REFRIGERATOR
Frigidaire FPHG2399MF0 REFRIGERATOR
Frigidaire FPHG2399MF1 REFRIGERATOR
Frigidaire FPHI1887KF0 REFRIGERATOR
Frigidaire FPHI1887KF1 REFRIGERATOR
Frigidaire FPHI1887KF2 REFRIGERATOR
Frigidaire FPHI1887KR0 REFRIGERATOR
Frigidaire FPHI1887KR1 REFRIGERATOR
Frigidaire FPHI1887KR2 REFRIGERATOR
Frigidaire FPHI2187KF0 REFRIGERATOR
Frigidaire FPHI2187KF1 REFRIGERATOR
Frigidaire FPHI2187KF2 REFRIGERATOR
Frigidaire FPHI2187KR0 REFRIGERATOR
Frigidaire FPHI2187KR1 REFRIGERATOR
Frigidaire FPHI2187KR2 REFRIGERATOR
Frigidaire FPHI21X7LF0 REFRIGERATOR
Frigidaire FPHN2899LF0 REFRIGERATOR
Frigidaire FPHN2899LF1 REFRIGERATOR
Frigidaire FPHN2899LF2 REFRIGERATOR
Frigidaire FPHN2899LF3 REFRIGERATOR
Frigidaire FPHS2386LF0 REFRIGERATOR
Frigidaire FPHS2386LF1 REFRIGERATOR
Frigidaire FPHS2386LF2 REFRIGERATOR
Frigidaire FPHS2387KF1 REFRIGERATOR
Frigidaire FPHS2387KF2 REFRIGERATOR
Frigidaire FPHS2387KF3 REFRIGERATOR
Frigidaire FPHS2387KF4 REFRIGERATOR
Frigidaire FPHS2387KF5 REFRIGERATOR
Frigidaire FPHS2387KF6 REFRIGERATOR
Frigidaire FPHS2399KF1 REFRIGERATOR
Frigidaire FPHS2399KF2 REFRIGERATOR
Frigidaire FPHS2399KF3 REFRIGERATOR
Frigidaire FPHS2399KF4 REFRIGERATOR
Frigidaire FPHS2399KF5 REFRIGERATOR
Frigidaire FPHS2687KF0 REFRIGERATOR
Frigidaire FPHS2687KF1 REFRIGERATOR
Frigidaire FPHS2687KF2 REFRIGERATOR
Frigidaire FPHS2687KF3 REFRIGERATOR
Frigidaire FPHS2687KF4 REFRIGERATOR
Frigidaire FPHS2699KF0 REFRIGERATOR
Frigidaire FPHS2699KF1 REFRIGERATOR
Frigidaire FPHS2699KF2 REFRIGERATOR
Frigidaire FPHS2699KF3 REFRIGERATOR
Frigidaire FPHS2699KF4 REFRIGERATOR
Frigidaire FPI11TAL3 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI11TAL5 Frg(v2) / Refrigerator
Frigidaire FPI11TAW3 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI11TAW5 Frg(v1) / Refrigerator
Frigidaire FPI11TFL1 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI11TFL2 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI11TFL3 Frg(v7) / Top Mount Refrigerator
Frigidaire FPI11TFW1 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI11TFW2 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI11TFW3 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI11TLAL5 Frg(v4) / Refrigerator
Frigidaire FPI11TLAW5 Frg(v3) / Refrigerator
Frigidaire FPI11TLFH1 Frg(v6) / Top Mount Refrigerator
Frigidaire FPI11TLFL1 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI11TLFL2 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI11TLFL3 Frg(v8) / Top Mount Refrigerator
Frigidaire FPI11TLFW1 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI11TLFW2 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI11TLFW3 Frg(v6) / Top Mount Refrigerator
Frigidaire FPI14TFA0 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI14TFF0 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI14TFH0 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI14TFL0 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI14TFW0 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI14TLA0 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI14TLA1 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI14TLF0 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI14TLF1 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI14TLH0 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI14TLH1 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI14TLL0 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI14TLL1 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI14TLW0 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI14TLW1 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI14TPH0 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI14TPL0 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI14TPL1 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI14TPW0 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI14TPW1 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI16TCH0 Frg(v12) / Top Mount Refrigerator
Frigidaire FPI16TCL0 Frg(v13) / Top Mount Refrigerator
Frigidaire FPI16TCW0 Frg(v14) / Top Mount Refrigerator
Frigidaire FPI16TEA0 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI16TEF0 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI16TEH0 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI16TEL0 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI16TEW0 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI17TFA0 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI17TFA2 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI17TFA3 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI17TFF0 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI17TFF2 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI17TFF3 Frg(v4) / Top Mount Refrigerator
Frigidaire FPI17TFH0 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI17TFH2 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI17TFH3 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI17TFL0 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI17TFL2 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI17TFL3 Frg(v5) / Top Mount Refrigerator
Frigidaire FPI17TFW0 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI17TFW2 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI17TFW3 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI17TPH0 Frg(v2) / Top Mount Refrigerator
Frigidaire FPI17TPL0 Frg(v3) / Top Mount Refrigerator
Frigidaire FPI17TPW0 Frg(v1) / Top Mount Refrigerator
Frigidaire FPI20VSL0 Frg(v1) / Side By Side Refrigerator
Frigidaire FPI20VSW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FPIC3095MSA COOKTOP
Frigidaire FPIC3695MSA COOKTOP
Frigidaire FPIF117BE Frg(v1) / Refrigerator
Frigidaire FPIF117BEL Frg(v2) / Refrigerator
Frigidaire FPIF3093LFA ELECTRIC RANGE
Frigidaire FPIF3093LFB ELECTRIC RANGE
Frigidaire FPIF3093LFC ELECTRIC RANGE
Frigidaire FPIF3093LFD ELECTRIC RANGE
Frigidaire FPIM18MA4 Frg(v2) / Refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Circuit breaker keeps tripping Johhar23 Dryer Repair 2 11-30-2014 07:41 AM
Tripping circuit breaker master54handyman Oven Repair (including Ranges and Cooktops) 2 11-30-2014 07:16 AM
Refrigerator tripping house circuit breaker. pacificbyte Refrigerator & Freezer Repair 0 04-22-2014 01:15 PM
Circuit breaker keeps tripping paulrk Dryer Repair 3 02-26-2014 02:03 AM
circuit breaker tripping laretta Refrigerator & Freezer Repair 2 05-10-2010 07:25 AM
