sharkey
#1 Posted : Tuesday, April 24, 2018 4:11:25 PM(UTC)
sharkey
I bought a house with a Whirlpool WRB322DMBM00 bottom-freezer refrigerator. There was an ice maker installed, but to my knowledge never had water connected to it. I got copper tubing and connected it to a nearby cold water line. At first, I also added a reverse osmosis filter inline. The water pressure seemed fine (although I do not have the tools to check it).
No leaks when I turned on the water. After about an hour, it popped out a few ice cubes. Then a short while later I heard it start filling up. It never stopped. I read that the filters could lower the pressure enough to cause this, so I removed the filter and coupled the two ends together. Same thing. I took off the back plate, disconnected both water lines and the power to the valve and put it back together. Same thing.
Like I said, I don't have a pressure meter, but when I put the tube in the sink and turn it on, the water really blasts in there. It's hard to imagine pressure is the issue.
Before I buy a new valve, is there anything else I should try? It seems odd that a part never used before should be defective, but I'm sure stranger things have happened.
Sorry for the lengthy post, and thanks in advance for your help!
Frigidaire Ice maker Valve not open (Refrigerator & Freezer Repair)
by jkor 5/20/2011 1:55:01 PM(UTC)
ice maker valve installation (Refrigerator & Freezer Repair)
by bjustice 4/30/2009 4:47:26 AM(UTC)
ice maker valve opening with water dispenser (Refrigerator & Freezer Repair)
by sunbob 8/20/2008 8:30:01 AM(UTC)
Ice maker Valve (Refrigerator & Freezer Repair)
by normdyer 1/11/2008 9:08:16 PM(UTC)
