Discuss
Freezer too cold, Ice build up causing leak
 in
Refrigerator & Freezer Repair
A while ago unnoticed my freezer was getting very cold, way past it's set point. Set to 0 Degrees and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer too cold, Ice build up causing leak
  #1 (permalink)
Old 04-23-2018, 10:12 PM
Junior Member
Sgibb16 is on a distinguished road
Default Freezer too cold, Ice build up causing leak
Model Number: LGHC2342LF0   Brand: Frigidaire   Age: 1 - 5 years
A while ago unnoticed my freezer was getting very cold, way past it's set point. Set to 0 Degrees and would go down to -15 degrees or so at times.
Eventually I noticed a small water leak under the refrigerator. This was due to a large brick of ice forming under the evaporator coils clogging the drain tube. Eventually water would melt in the defrost cycle and leak down to the floor of the unit and then out of the unit.
I replaced the defrost thermostat, and the defrost heater is definitely getting hot. I tested both freezer and fridge thermistors.
I'm at a loss, looking for some suggestions on parts to test before I keep throwing money at random parts.
Related Models
Frigidaire LGHC2342LF0 REFRIGERATOR
Frigidaire LGHC2342LF2 REFRIGERATOR
Frigidaire LGHC2342LP1 REFRIGERATOR
Frigidaire LGHD2433KM0 DISHWASHER
Frigidaire LGHD2433KM1 DISHWASHER
Frigidaire LGHN2844ME0 REFRIGERATOR
Frigidaire LGHN2844MF0 REFRIGERATOR
Frigidaire LGHN2844MP0 REFRIGERATOR
Frigidaire LGHS2634KE0 REFRIGERATOR
Frigidaire LGHS2634KE1 REFRIGERATOR
Frigidaire LGHS2634KE2 REFRIGERATOR
Frigidaire LGHS2634KP0 REFRIGERATOR
Frigidaire LGHS2634KP1 REFRIGERATOR
Frigidaire LGHS2634KP2 REFRIGERATOR
Frigidaire LGHS2644KM0 REFRIGERATOR
Frigidaire LGHS2644KM1 REFRIGERATOR
Frigidaire LGHS2644KM2 REFRIGERATOR
Frigidaire LGHS2655KE0 REFRIGERATOR
Frigidaire LGHS2655KE1 REFRIGERATOR
Frigidaire LGHS2655KE2 REFRIGERATOR
Frigidaire LGHS2655KP0 REFRIGERATOR
Frigidaire LGHS2655KP1 REFRIGERATOR
Frigidaire LGHS2655KP2 REFRIGERATOR
Frigidaire LGHS2665KF0 REFRIGERATOR
Frigidaire LGHS2665KF1 REFRIGERATOR
Frigidaire LGHS2665KF2 REFRIGERATOR
Frigidaire LGHS2667KE0 REFRIGERATOR
Frigidaire LGHS2667KP0 REFRIGERATOR
Frigidaire LGHT1837LE0 REFRIGERATOR
Frigidaire LGHT1837LE1 REFRIGERATOR
Frigidaire LGHT1837LE3 REFRIGERATOR
Frigidaire LGHT1837LE4 REFRIGERATOR
Frigidaire LGHT1837LP0 REFRIGERATOR
Frigidaire LGHT1837LP1 REFRIGERATOR
Frigidaire LGHT1837LP3 REFRIGERATOR
Frigidaire LGHT1837LP4 REFRIGERATOR
Frigidaire LGHT2137LE0 REFRIGERATOR
Frigidaire LGHT2137LE1 REFRIGERATOR
Frigidaire LGHT2137LE2 REFRIGERATOR
Frigidaire LGHT2137LP0 REFRIGERATOR
Frigidaire LGHT2137LP1 REFRIGERATOR
Frigidaire LGHT2137LP2 REFRIGERATOR
Whirlpool LGL7646EQ0 DRYER
Whirlpool LGL8858DQ0 GAS DRYER
Whirlpool LGL8858DZ0 GAS DRYER
Whirlpool LGL8858EQ0 DRYER
Whirlpool LGL8858EQ1 DRYERS
Whirlpool LGL8858EQ2 GAS DRYER
Whirlpool LGL8858EQ3 GAS DRYER
Frigidaire LGLF305MMFA GAS RANGE
Amana LGM439L DRYER- GAS
Amana LGM439W DRYER- GAS
Amana LGM449L DRYER- GAS
Amana LGM449W DRYER- GAS
Amana LGM549L DRYER- GAS
Amana LGM549W DRYER- GAS
Amana LGM849W DRYER- GAS
Whirlpool LGN1000HQ0 DRYER
Whirlpool LGN1000HQ1 GAS DRYER
Whirlpool LGN1000PQ0 29"GAS DRYER
Whirlpool LGN1000PQ1 29"GAS DRYER
Whirlpool LGN2000JQ0 GAS DRYER
Whirlpool LGN2000JQ1 GAS DRYER
Whirlpool LGN2000JQ2 GAS DRYER
Whirlpool LGN2000JQ3 RESIDENTIAL DRYER
Whirlpool LGN2000JT0 GAS DRYER
Whirlpool LGN2000JT1 GAS DRYER
Whirlpool LGN2000JT2 GAS DRYER
Whirlpool LGN2000JT3 RESIDENTIAL DRYER
Whirlpool LGN2000KQ0 DRYER
Whirlpool LGN2000KQ1 29"GAS DRYER
Whirlpool LGN2000KQ2 29"GAS DRYER
Whirlpool LGN2000KT0 DRYER
Whirlpool LGN2000KT1 29"GAS DRYER
Whirlpool LGN2000LG0 RESIDENTIAL DRYER
Whirlpool LGN2000LG1 29"GAS DRYER
Whirlpool LGN2000LW0 RESIDENTIAL DRYER
Whirlpool LGN2000LW1 29"GAS DRYER
Whirlpool LGN2000PG0 29"GAS DRYER
Whirlpool LGN2000PG1 29"GAS DRYER
Whirlpool LGN2000PW0 29"GAS DRYER
Whirlpool LGN2000PW1 29"GAS DRYER
Whirlpool LGN3434AW0 Residential Dryer
Whirlpool LGN3624BN0 GAS DRYER
Whirlpool LGN3624BN1 GAS DRYER
Whirlpool LGN3624BN2 GAS DRYER
Whirlpool LGN3624BW0 GAS DRYER
Whirlpool LGN3624BW1 GAS DRYER
Whirlpool LGN3624BW2 GAS DRYER
Whirlpool LGN3634DW0 GAS DRYER
Whirlpool LGN3634DW1 GAS DRYER
Whirlpool LGP6646AN1 GAS DRYER
Whirlpool LGP6646AN2 GAS DRYER
Whirlpool LGP6646AW0 Residential Dryer
Whirlpool LGP6646AW1 GAS DRYER
Whirlpool LGP6646AW2 GAS DRYER
Whirlpool LGP6848AN1 GAS DRYER
Whirlpool LGP6848AW0 Residential Dryer
Whirlpool LGP6848AW1 GAS DRYER
Whirlpool LGP7858AN2 GAS DRYER
Whirlpool LGP7858AQ2 GAS DRYER
Whirlpool LGP7858AW0 Residential Dryer
Whirlpool LGP7858AW2 GAS DRYER
Whirlpool LGP7858AZ2 GAS DRYER
Frigidaire LGQ1442ES0 Frigidaire/dryer
Frigidaire LGQ1442ES1 DRYER
Frigidaire LGQ1442ES2 DRYER
Frigidaire LGQ1452KS0 DRYER
Frigidaire LGQ2152EE0 Frigidaire/dryer
Frigidaire LGQ2152EE1 DRYER
Frigidaire LGQ2152EE2 DRYER
Frigidaire LGQ2152EE3 DRYER
Frigidaire LGQ2152ES0 Frigidaire/dryer
Frigidaire LGQ2152HS0 DRYER
Frigidaire LGQ2152HS1 DRYER
Frigidaire LGQ332DS0 Frigidaire/dryer
Frigidaire LGQ6000ES0 Frigidaire/dryer
Frigidaire LGQ6000ES1 Frigidaire/dryer
Frigidaire LGQ6000ES2 Frigidaire/dryer
Frigidaire LGQ6400FS0 DRYER
  #2 (permalink)
Old 05-01-2018, 05:58 PM
Junior Member
dk_980 is on a distinguished road
Default
Got a similar problem with my GE. The evaporator fan doesn't shut off and keeps running. The fresh food section gets really cold freezing the food. But I don't see any ice build-up.
Did you figure out your problem?
  #3 (permalink)
Old 05-01-2018, 06:27 PM
Junior Member
Default
I have not, I suspect it may be the main board but not sure I want to spend the money when I don't know if that is actually the cause.
My refrigerator side stays the correct temperature. Did you check the damper door between the freezer and fresh food side?
  #4 (permalink)
Old 05-01-2018, 10:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The complete model number of the refrigerator might help us to help you.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #5 (permalink)
Old 05-01-2018, 11:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Sgibb16 View Post
...I tested both freezer and fridge thermistors...
How did you test them and what were the readings?
If freezer thermistor is good, the control board is the culprit. If the part would not fix the problem, you can easily return it.
Control board Part number: AP5968389
__________________
  #6 (permalink)
Old 05-02-2018, 04:27 AM
Junior Member
Default
I place them in ice water and checked the resistance. If I remember correctly I was reading like 27K ohms and it was still rising. My refrigerator didn't come with a temperature- resistance chart. But they were consistent with each other, so I figured they were good.
  #7 (permalink)
Old 05-02-2018, 04:46 PM
Junior Member
Default
Thanks, I checked the damper door, working fine.
Will check the temperature sensors next. Do you know what should be the resistance reading? I saw a video that states it should be around 16k ohms...
The model is GSH25JSTASS
  #8 (permalink)
Old 05-03-2018, 12:50 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The normal reading should be from about 12KOhms at room temperature to about 32.5KOhms at 32F
If the readings are within range then the control board is very questionable.
__________________
  #9 (permalink)
Old 05-03-2018, 01:29 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There are 3 sensors in this refrigerator. They all are identical and have the same resistance readings. Normally it supposes to be: 42.5 KOhms @0F, 14.0 KOhms @37.0F and 4.92 KOhms @77F.
If the readings are good and you did not find anything wrong with the damper door, very possible the control board would need to be replaced.
The control board Part number: AP6048447
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Bottom Freezer Ice Build-up & Leak pcheckel Refrigerator & Freezer Repair 0 08-18-2017 12:59 PM
freezer too cold and ice build up kenmore elite cmpitt Refrigerator & Freezer Repair 5 08-16-2015 03:30 PM
ice build up in freezer, refrigerator not cold imagine45 Refrigerator & Freezer Repair 0 02-01-2010 01:03 AM
Frost Build-Up in freezer (refrig & freezer not as Cold as usual) boots1 Oven Repair (including Ranges and Cooktops) 1 01-18-2009 03:08 AM
Freezer cold, evaporator fan not working, frost build up in freezer heretolearn2 Refrigerator & Freezer Repair 3 05-28-2008 02:45 PM
