I have a Kenmore model # 253.703431D french door refrigerator that I believe is made by Frigidaire. I am having trouble with the ice maker freezing up now and then and have pretty much narrowed it down to low water pressure due to the filter becoming clogged prematurely. I would like to cycle the ice maker with some commands from the front panel (as I have seen the service man do). I can enter the diagnostic mode by pressing and holding the ^ and + buttons simultaneously for several seconds. I can use the arrow keys to scroll through some numbers and I know that '55' is used to perform the water fill function. I would like to know what the other numbers are meant to do and how to exit the diagnostic mode? Currently I just wait for 10 minutes and it will exit by itself.
Thanks for any help.
