Replace and put a new ice maker. I checked that the valves worked great. The valves was sending water to the water dispenser and also great pressure and water to the ice maker. When I put the ice maker in, and connect the wires with the quick connect for the fan that is behind the ice maker. It works amazing. The I go connect the wires for the new ice maker and it makes the fan turn off. Is this normal.???? Or is the new ice maker I just installed come damaged?? What should i do next????
