Discuss
Frigidaire LFUS2613LFO No water out dispenser
 in
Refrigerator & Freezer Repair
I believe this fridge is around 4-7 yrs old. 2nd owner as I knew previous owners of house prior to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidaire LFUS2613LFO No water out dispenser
  #1 (permalink)
Old 03-26-2018, 11:05 AM
Junior Member
dtnel is on a distinguished road
Default Frigidaire LFUS2613LFO No water out dispenser
Model Number: LFUS2613LFO   Brand: Frigidaire   Age: 1 - 5 years
I believe this fridge is around 4-7 yrs old. 2nd owner as I knew previous owners of house prior to current.
Neighbor lady said water wasn't working. Pushed water button and would hear noise as I hear on my whirlpool at home where water pump or something kicks in.
Replaced water filter as it was unknown when last replaced. When I put the new water filter in the fridge I didn't hear it fill with water as mine makes a filling noise at home.
Today I plan on going by and shutting house water main off and disconnecting the line then turning water on as the shutoff isn't located in the utility room as it should be. I think the original homeowner (knew him to) just tapped in directly below the kitchen which is above the basement living room instead of going 15ft to the utility room.
House is on 5th homeowner since new in fall of 2000. I've lived next door since Feb 2001.
So the question I have is when I go back today if I have water going into the fridge then what would I need to check next and if so I'massuming I'll need my multimeter as that's common with any electronics.
My guess would be a faulty inlet water valve but I'm no expert. Any help would be greatly appreciated.
To add a little more information I did have to replace the water line connector where it comes from under the fridge to the bottom of the freezer door as the plastic coupler had a broken line in it. Even after that there wasn't any water. There's no ice being made either. I also want to add that the new homeowner had called the previous owner (they're friends) and the previous homeowners according to her told her that you have to press the water filter button several times I believe she mentioned. There's a language barrier in play as well as the families are Nepali so understanding them can be rough at times.
IF there's a way to bypass the inlet valve to see if the valve is bad I do have someone that can assist me there in the house.
Thanks in advance for any help and suggestions.
Related Models
Frigidaire LFUS2613LM0 REFRIGERATOR
Frigidaire LFUS2613LM1 REFRIGERATOR
Frigidaire LFUS2613LM2 REFRIGERATOR
Frigidaire LFUS2613LM3 REFRIGERATOR
Frigidaire LFUS2613LP0 REFRIGERATOR
Frigidaire LFUS2613LP1 REFRIGERATOR
Frigidaire LFUS2613LP2 REFRIGERATOR
Frigidaire LFUS2613LP3 REFRIGERATOR
Frigidaire LFW201EW0 WASHER
 LFX21960ST Refrigerator
 LFX21971ST Refrigerator
 LFX21975ST Refrigerator
 LFX21980ST Refrigerator
 LFX23961SB Refrigerator
 LFX23961ST Refrigerator
 LFX23961SW Refrigerator
 LFX25950SB Refrigerator
 LFX25950SW Refrigerator
 LFX25950TT Refrigerator
 LFX25960SB Refrigerator
 LFX25960ST Refrigerator
 LFX25960SW Refrigerator
 LFX25960TT Refrigerator
 LFX25961SB Refrigerator
 LFX25961ST Refrigerator
 LFX25961SW Refrigerator
 LFX25971SB Refrigerator
 LFX25971ST Refrigerator
 LFX25971SW Refrigerator
 LFX25975SB Refrigerator
 LFX25975ST Refrigerator
 LFX25975SW Refrigerator
 LFX25980ST Refrigerator
Amana LG1009W DRYER- GAS
Amana LG1101 DRYER- GAS
Amana LG1112 WASHER-TOP LOADING
Amana LG1112 DRYER- GAS
Whirlpool LG2001XSW0 Residential Dryer
Amana LG2112L DRYER- GAS
Amana LG2112W DRYER- GAS
Amana LG2401 DRYER- GAS
Amana LG2412 WASHER-TOP LOADING
Amana LG2412 DRYER- GAS
Amana LG2501 DRYER- GAS
Amana LG2512 WASHER-TOP LOADING
Amana LG2512 DRYER- GAS
Amana LG2811 DRYER- GAS
Amana LG2812 WASHER-TOP LOADING
Amana LG2812 DRYER- GAS
Amana LG2902 WASHER-TOP LOADING
Amana LG2911 DRYER- GAS
Amana LG2912 WASHER-TOP LOADING
Amana LG2912 DRYER- GAS
Whirlpool LG3001XMW0 Residential Dryer
Whirlpool LG3001XMW1 Residential Dryer
Whirlpool LG3001XMW2 Residential Dryer
Whirlpool LG3001XPW0 Residential Dryer
Whirlpool LG3001XSW0 Residential Dryer
Whirlpool LG3006XPW0 Residential Dryer
Amana LG3412G DRYER- GAS
Amana LG3412L DRYER- GAS
Amana LG3412W DRYER- GAS
Amana LG3512L DRYER- GAS
Amana LG3512W DRYER- GAS
Amana LG3812L DRYER- GAS
Amana LG3812W DRYER- GAS
Amana LG3912L DRYER- GAS
Amana LG3912W DRYER- GAS
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L DRYER- GAS
Amana LG4209L2 DRYER- GAS
Amana LG4209W DRYER- GAS
Amana LG4209W2 DRYER- GAS
Amana LG4219L2 DRYER- GAS
Amana LG4219W2 DRYER- GAS
Amana LG4309L DRYER- GAS
Amana LG4309W DRYER- GAS
Amana LG4319L2 DRYER- GAS
Amana LG4319W2 DRYER- GAS
Amana LG4409L DRYER- GAS
Amana LG4409W DRYER- GAS
Amana LG4429L DRYER- GAS
Amana LG4429W DRYER- GAS
Whirlpool LG4441XWW0 Residential Dryer
Whirlpool LG4441XWW1 Residential Dryer
Amana LG4509L DRYER- GAS
Amana LG4509W DRYER- GAS
Amana LG4609L DRYER- GAS
Amana LG4609W DRYER- GAS
Amana LG4809L DRYER- GAS
Amana LG4809W DRYER- GAS
Amana LG4909L DRYER- GAS
Amana LG4909W DRYER- GAS
Whirlpool LG4931XMW0 Residential Dryer
Whirlpool LG4931XSW0 Residential Dryer
  #2 (permalink)
Old 03-26-2018, 02:12 PM
Junior Member
hkp7 is on a distinguished road
Default
It sounds like the solenoid valve for the water needs to be replaced. You can verify by disconnecting the leads to the solenoid, and checking the resistance of the coil. If it's open, the solenoid is shot. If it's not open check for voltage to the leads while someone presses the water dispenser button; it could be a bad relay (likely the relay isn't the culprit).
  #3 (permalink)
Old 03-26-2018, 03:12 PM
Junior Member
Default
Quote:
Found the unlikely source. No water pressure to the fridge thru the water line and the rookie original owner never ran a line from the utility room but rather somewhere else which I'll have to open up the basement ceiling as it's probably the pipe piercing type. After I get the old shut down then I'll run a new line. Can't believe the rookie things people do.
  #4 (permalink)
Old 03-26-2018, 06:01 PM
Junior Member
Default
Glad to hear it is a straight forward fix. I personally don't care for the pipe piercing saddle valves. I put a "T" fitting into the pipe, and used copper tubing to feed the fridge. Ended up replacing the plastic tubing on the fridge with copper tubing as well. The plastic tubing eventually gets brittle, and will leak when you least expect it.
  #5 (permalink)
Old 03-26-2018, 11:34 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Just something I learned after years of doing it both ways.
Put your valve on a vertical pipe. Valves placed on horizontal pipes are much more likely to plug up with debris and corrosion from the pipe.
Water pressure isn't the same as water volume. Always verify the the amount of water will be enough to do what you are needing it for.
I've had more than a few times it seemed like there was plenty of pressure, but not enough volume to fill an ice maker in time.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire water dispenser not working/ice maker and dispenser fine Exjerseygirl Refrigerator & Freezer Repair 0 04-19-2014 11:27 AM
my frigidaire leak water at the water dispenser. ice melting but the freezer working samsanwoo Refrigerator & Freezer Repair 0 09-25-2013 04:38 AM
Frigidaire Water Dispenser Danbonsell Refrigerator & Freezer Repair 0 05-18-2011 11:34 AM
Broken Frigidaire Water Dispenser catluvr51 Refrigerator & Freezer Repair 1 08-13-2010 04:33 AM
Frigidaire, Water Dispenser, even when off IKNOWNOTHING Refrigerator & Freezer Repair 1 06-21-2010 05:27 PM
