Discuss
Frozen water supply tube to icemaker
 in
Refrigerator & Freezer Repair
Hello, My unit is less than a year old... I had this problem, along with a water leak from the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frozen water supply tube to icemaker
  #1 (permalink)
Old 03-22-2018, 08:22 AM
Junior Member
AUTiger is on a distinguished road
Exclamation Frozen water supply tube to icemaker
Model Number: WRS325FNAM   Brand: Whirlpool   Age: Less than 1 year
Hello, My unit is less than a year old... I had this problem, along with a water leak from the top of the supply tube where it connects from the outside to the ice maker. I gather once the water supply "chute" to the ice maker freezes, something is malfunctioning and needs to be replaced? i.e. thawing is always a temporary resolution? I did notice the freezer setting was at 4 (1:00 position), which is beyond the notched position at 12:00...could this higher setting be the cause? Another aspect of my situation is I have relatively high water pressure into my house. I closed the water supply valve to roughly 1/2 to 3/4 open. Could that be a factor? As far as the leak, I made sure the tube was fully inserted (with metal sleeve inside) and tightened the clamp as much as possible...assume the leak resulted from the pump pushing against the blocked tube, and will stop with a functioning tube?
Many thanks...the new wood floors can't tolerate any more leaks!
Related Models
White Westinghouse WRS3R3EW0 White Westinghouse/refrigerator
White Westinghouse WRS3R3EW1 White Westinghouse/refrigertor
White Westinghouse WRS3R3EW2 White Westinghouse/refrigerator
White Westinghouse WRS3R3EW3 White Westinghouse/refrigertor
White Westinghouse WRS3R3EW4 White Westinghouse/refrigerator
White Westinghouse WRS3R3EW6 White Westinghouse/refrigerator
White Westinghouse WRS3R3EW7 White Westinghouse/refrigerator
White Westinghouse WRS3R3EW9 White Westinghouse/refrigerator
White Westinghouse WRS3R3EWA REFRIGERATOR
White Westinghouse WRS3R3EWB REFRIGERATOR
White Westinghouse WRS3R3EWC REFRIGERATOR
White Westinghouse WRS3R3EWD REFRIGERATOR
White Westinghouse WRS3R3EWE REFRIGERATOR
White Westinghouse WRS3R3EWG REFRIGIERATOR
White Westinghouse WRS6MR5FMB0 White Westinghouse/refrigerator
White Westinghouse WRS6R3EW0 White Westinghouse/refrigerator
White Westinghouse WRS6R3EW1 White Westinghouse/refrigerator
White Westinghouse WRS6R3EW2 White Westinghouse/refrigerator
White Westinghouse WRS6R3EW4 White Westinghouse/refrigerator
White Westinghouse WRS6R3EW6 White Westinghouse/refrigerator
White Westinghouse WRS6R3EW7 White Westinghouse/refrigerator
White Westinghouse WRS6R3EW8 White Westinghouse/refrigerator
White Westinghouse WRS6R3EW9 White Westinghouse/refrigerator
White Westinghouse WRS6R3EWA REFRIGERATOR
White Westinghouse WRS6W1EW0 White Westinghouse/refrigerator
White Westinghouse WRS6W1EW1 White Westinghouse/refrigerator
White Westinghouse WRS6W1EW2 White Westinghouse/refrigerator
White Westinghouse WRS6W1EW4 White Westinghouse/refrigerator
White Westinghouse WRS6W1EW5 White Westinghouse/refrigerator
White Westinghouse WRS6W1EW6 White Westinghouse/refrigerator
White Westinghouse WRS6W1EW7 White Westinghouse/refrigerator
White Westinghouse WRS6W1EW8 White Westinghouse efrigerator
White Westinghouse WRS6W1EW9 White Westinghouse/refrigerator
Whirlpool WRT108TFYB00 REFRIGERATOR
Whirlpool WRT108TFYW00 REFRIGERATOR
Whirlpool WRT138TFYB00 REFRIGERATOR
Whirlpool WRT138TFYS00 REFRIGERATOR
Whirlpool WRT138TFYW00 REFRIGERATOR
Frigidaire WRT13CGAD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT13CGAW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT13CGAY0 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT13CGAZ0 Wwh(v4) / Top Mount Refrigerator
Frigidaire WRT13CGBD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT13CGBD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT13CGBD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT13CGBD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT13CGBD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT13CGBW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT13CGBW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT13CGBW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT13CGBW3 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT13CGBW4 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT13CGBY0 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT13CGBY1 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT13CGBY2 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT13CGBY3 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT13CGBZ0 Wwh(v4) / Top Mount Refrigerator
Frigidaire WRT13CGBZ1 Wwh(v4) / Top Mount Refrigerator
Frigidaire WRT13CGBZ2 Wwh(v4) / Top Mount Refrigerator
Frigidaire WRT13CGBZ3 Wwh(v4) / Top Mount Refrigerator
Frigidaire WRT13CRJW0 Wwh(v0) / Refrigerator
Frigidaire WRT13GRHD0 Wwh(v1) / Refrigerator
Frigidaire WRT13GRHD1 Wwh(v1) / Refrigerator
Frigidaire WRT13GRHW0 Wwh(v2) / Refrigerator
Frigidaire WRT13GRHW1 Wwh(v2) / Refrigerator
Frigidaire WRT14CGAD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT14CGAW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT14CGAY0 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT14CGAZ0 Wwh(v4) / Top Mount Refrigerator
White Westinghouse WRT15A0AW0 White Westinghouse/refrigerator
White Westinghouse WRT15A0AW1 White Westinghouse/refrigerator
White Westinghouse WRT15A0AW2 White Westinghouse/refrigerator
White Westinghouse WRT15A0AW3 WHITE WESTINGHOUSE/REFRIGERATOR
White Westinghouse WRT15A0AW4 White Westinghouse/refrigerator
Frigidaire WRT15CGAD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT15CGAD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT15CGAW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT15CGAW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT15CGAY0 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT15CGAY1 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT15CGAZ0 Wwh(v4) / Top Mount Refrigerator
Frigidaire WRT15CGAZ1 Wwh(v4) / Top Mount Refrigerator
Frigidaire WRT15CGBD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT15CGBD1 Wwh(v5) / Top Mount Refrigerator
Frigidaire WRT15CGBW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT15CGBW1 Wwh(v6) / Top Mount Refrigerator
Frigidaire WRT15CGBY0 Wwh(v3) / Top Mount Refrigerator
Frigidaire WRT15CGBY1 Wwh(v7) / Top Mount Refrigerator
Frigidaire WRT15CGBZ0 Wwh(v4) / Top Mount Refrigerator
Frigidaire WRT15CGBZ1 Wwh(v8) / Top Mount Refrigerator
Frigidaire WRT15CSHD0 Wwh(v1) / Refrigerator
Frigidaire WRT15CSHD1 Wwh(v1) / Refrigerator
Frigidaire WRT15CSHD2 Wwh(v1) / Refrigerator
White Westinghouse WRT15CSHD4 WHITE-WESTINGHOUSE/REFRIGERATOR - P5995345815
Frigidaire WRT15CSHW0 Wwh(v2) / Refrigerator
Frigidaire WRT15CSHW1 Wwh(v2) / Refrigerator
Frigidaire WRT15CSHW2 Wwh(v2) / Refrigerator
White Westinghouse WRT15CSHW4 WHITE-WESTINGHOUSE/REFRIGERATOR - P5995345815
Frigidaire WRT15DRAD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT15DRAW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT15DRBD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT15DRBD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire WRT15DRBW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire WRT15DRBW1 Wwh(v2) / Top Mount Refrigerator
White Westinghouse WRT15GA2AQ1 White Westinghouse/refrigerator
White Westinghouse WRT15GA2AW1 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AQ0 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AQ1 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AQ2 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AQ3 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AQ4 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AW0 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AW1 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AW2 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AW3 White Westinghouse/refrigerator
White Westinghouse WRT15MB3AW4 White Westinghouse/refrigerator
White Westinghouse WRT15MG4BQ0 White Westinghouse/refrigerator
White Westinghouse WRT15MG4BQ1 White Westinghouse/refrigerator
White Westinghouse WRT15MG4BQ3 White Westinghouse/refrigerator
White Westinghouse WRT15MG4BQ4 White Westinghouse/refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaking Water Supply Tube At Valve PENZZZ Refrigerator & Freezer Repair 1 10-05-2016 07:46 AM
Water Supply Tube & Spray arm dangling yinger Dishwasher Repair 1 09-15-2015 03:19 AM
supply tube to icemaker freezes townsendtim Refrigerator & Freezer Repair 1 10-21-2012 01:50 PM
Icemaker supply tube replace ChuckB7 Refrigerator & Freezer Repair 0 02-25-2011 05:03 PM
Ice maker supply tube frozen ttsnuffy Refrigerator & Freezer Repair 1 10-25-2010 05:27 AM
