Discuss
Relay for Embraco Compressor EGX 90HLC
 in
Refrigerator & Freezer Repair
My refrigerator (LG LFX25961AL) has an Embraco Compressor EGX 90HLC controlled by an Embraco TDS 115/127V-60Hz-Y relay/capacitor assembly (also noted
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Relay for Embraco Compressor EGX 90HLC
  #1 (permalink)
Old 03-19-2018, 12:40 PM
Junior Member
partialresponse is on a distinguished road
Default Relay for Embraco Compressor EGX 90HLC
Model Number: LFX25961AL   Brand: -other-   Age: 5 - 10 years
My refrigerator (LG LFX25961AL) has an Embraco Compressor EGX 90HLC controlled by an Embraco TDS 115/127V-60Hz-Y relay/capacitor assembly (also noted on this assembly is part number 513604044). Recently it has stopped cooling (well, occasionally the compressor runs long enough to cool a little) accompanied by frequent clicking from what is likely the overload protector (OLP). The compressor winding resistances seem reasonable at about 4, 8, and 12 ohms. When the OLP allows the compressor to run briefly (for about 10s) the compressor draws about 13A; the OLP then kicks in and shuts down the compressor. I suspect the problem to be with either the OLP or the relay. The OLP seems easy to find but the relay seems unavailable. Is there a known substitute part for this relay? I've seen references to a newer part 6749C-0014E but it's not clear this part is a suitable replacement for the TDS 115/127V-60Hz-Y (513604044) since the compressor apparently requires a capacitor to run (according the compressor manufacturer data sheets) and the 6749C-0014E does not appear to use (or have connections) for one.
Related Models
 LFX25961SB Refrigerator
 LFX25961ST Refrigerator
 LFX25961SW Refrigerator
 LFX25971SB Refrigerator
 LFX25971ST Refrigerator
 LFX25971SW Refrigerator
 LFX25975SB Refrigerator
 LFX25975ST Refrigerator
 LFX25975SW Refrigerator
 LFX25980ST Refrigerator
Amana LG1009W DRYER- GAS
Amana LG1101 DRYER- GAS
Amana LG1112 WASHER-TOP LOADING
Amana LG1112 DRYER- GAS
Whirlpool LG2001XSW0 Residential Dryer
Amana LG2112L DRYER- GAS
Amana LG2112W DRYER- GAS
Amana LG2401 DRYER- GAS
Amana LG2412 WASHER-TOP LOADING
Amana LG2412 DRYER- GAS
Amana LG2501 DRYER- GAS
Amana LG2512 WASHER-TOP LOADING
Amana LG2512 DRYER- GAS
Amana LG2811 DRYER- GAS
Amana LG2812 WASHER-TOP LOADING
Amana LG2812 DRYER- GAS
Amana LG2902 WASHER-TOP LOADING
Amana LG2911 DRYER- GAS
Amana LG2912 WASHER-TOP LOADING
Amana LG2912 DRYER- GAS
Whirlpool LG3001XMW0 Residential Dryer
Whirlpool LG3001XMW1 Residential Dryer
Whirlpool LG3001XMW2 Residential Dryer
Whirlpool LG3001XPW0 Residential Dryer
Whirlpool LG3001XSW0 Residential Dryer
Whirlpool LG3006XPW0 Residential Dryer
Amana LG3412G DRYER- GAS
Amana LG3412L DRYER- GAS
Amana LG3412W DRYER- GAS
Amana LG3512L DRYER- GAS
Amana LG3512W DRYER- GAS
Amana LG3812L DRYER- GAS
Amana LG3812W DRYER- GAS
Amana LG3912L DRYER- GAS
Amana LG3912W DRYER- GAS
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L DRYER- GAS
Amana LG4209L2 DRYER- GAS
Amana LG4209W DRYER- GAS
Amana LG4209W2 DRYER- GAS
Amana LG4219L2 DRYER- GAS
Amana LG4219W2 DRYER- GAS
Amana LG4309L DRYER- GAS
Amana LG4309W DRYER- GAS
Amana LG4319L2 DRYER- GAS
Amana LG4319W2 DRYER- GAS
Amana LG4409L DRYER- GAS
Amana LG4409W DRYER- GAS
Amana LG4429L DRYER- GAS
Amana LG4429W DRYER- GAS
Whirlpool LG4441XWW0 Residential Dryer
Whirlpool LG4441XWW1 Residential Dryer
Amana LG4509L DRYER- GAS
Amana LG4509W DRYER- GAS
Amana LG4609L DRYER- GAS
Amana LG4609W DRYER- GAS
Amana LG4809L DRYER- GAS
Amana LG4809W DRYER- GAS
Amana LG4909L DRYER- GAS
Amana LG4909W DRYER- GAS
Whirlpool LG4931XMW0 Residential Dryer
Whirlpool LG4931XSW0 Residential Dryer
Whirlpool LG4931XTW0 Residential Dryer
Whirlpool LG4931XTW1 Residential Dryer
Whirlpool LG4931XTW2 Residential Dryer
Whirlpool LG4936XMW0 Residential Dryer
Whirlpool LG4936XMW1 Residential Dryer
Whirlpool LG5201XTW0 Residential Dryer
Whirlpool LG5201XTW1 Residential Dryer
Whirlpool LG5321XTW0 Residential Dryer
Whirlpool LG5531XKW0 Residential Dryer
Whirlpool LG5531XKW1 Residential Dryer
Whirlpool LG5531XMG2 GAS DRYER
Whirlpool LG5531XMN2 GAS DRYER
Whirlpool LG5531XMW0 Residential Dryer
Whirlpool LG5531XMW1 Residential Dryer
Whirlpool LG5531XMW2 GAS DRYER
Whirlpool LG5531XPW0 Residential Dryer
Whirlpool LG5531XSW0 Residential Dryer
Whirlpool LG5531XSW1 Residential Dryer
Whirlpool LG5536XPW0 Residential Dryer
Whirlpool LG5551XTG0 GAS DRYER
Whirlpool LG5551XTN0 GAS DRYER
Whirlpool LG5551XTW0 Residential Dryer
Whirlpool LG5601XMW0 Residential Dryer
Whirlpool LG5601XPW0 Residential Dryer
Whirlpool LG5601XSW0 Residential Dryer
Whirlpool LG5601XSW1 Residential Dryer
Whirlpool LG5606XPW0 Residential Dryer
Whirlpool LG5651XKW0 Residential Dryer
  #2 (permalink)
Old 03-19-2018, 11:24 PM
Junior Member
Default
During one the long running spells of the compressor (OLP did not trip to turn it off) I was able to measure the compressor current draw while it was running; I was surprised to find out it only draws about 1.2A. Thus the 13A I measured during the 10s or so after startup was mostly due to current draw of the start winding. It’s now clear to me that the solid-state “relay” (PTC thermistor actually) in series with the start winding is failing to effectively disable it (by its increased resistance due to heating from the high startup current) within the prescribed time, and this is, in turn, causing the OLP to turn off the compressor due to the sustained high current draw. The frequent clicking of the OLP now makes sense.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Embraco FGT 90HA Burnt Relay Starglow Refrigerator & Freezer Repair 1 02-18-2015 05:32 PM
GE Profile & Embraco QD TSD2 Relay install tomu570 Refrigerator & Freezer Repair 0 11-25-2014 05:39 PM
Embraco EGY90hlp Compressor won't start bbrashaw Refrigerator & Freezer Repair 2 08-21-2012 02:57 AM
Embraco Compressor pin locations FGT 90HA kcook Refrigerator & Freezer Repair 1 10-15-2011 02:27 AM
