Discuss
temp control not reading correctly
 in
Refrigerator & Freezer Repair
I picked up this GE PROFILE fridge on the premise it was the motherboard that was shot. When powered up
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » temp control not reading correctly
  #1 (permalink)
Old 03-15-2018, 08:30 PM
Junior Member
TIMANDREWS is on a distinguished road
Default temp control not reading correctly
Model Number: PFCS1RKZA SS   Brand: GE   Age: 5 - 10 years
I picked up this GE PROFILE fridge on the premise it was the motherboard that was shot. When powered up everything worked but the compressor. Turns out it was the inverter board. I replaced that and the unit started to cool. After sometime the fridge and freezer were cool but the front display was not reflecting the current inside temps. I put a thermometer in the fridge and one in the freezer and let it run. I returned to it after a few hours. Here's what I noticed:
1) the fridge seemed okay. Thermometer and actual temp matched and the damper had shut things off. But its still a little strange how the temp display did not reflect the inside temp earlier during the initial cooling stage.
2) the freezer was still running at -15 on the thermometer with the front display indicating 0.
I decided to open the doors and let the unit warm up to see what happens and I observed the following after the fridge and freezer was warmed 10 degrees or so above the set points (0 & 37):
3) the compressor and fan took a really long tome to kick in. It must have been 15 mins or more after the doors were closed.
4) the digital display for both the fridge and freezer did not change with the decreasing inside temps. When I unplug the fridge and plug it back in the temp display changes to the correct temp for that moment but does not change as the unit continues to cool.
I'm going to check the thermistors when I have a chance. I'm just wondering if someone has seen and/or deal with a similar problem and could provide some guidance/suggestions.
Many thanks
Tim
Related Models
General Electric PFCS1RKZASS REFRIGERATOR
General Electric PFDN440EL0WW ELECTRIC DRYER
General Electric PFDN440GL0WW GAS DRYER
General Electric PFDN440GL1WW GAS DRYER
General Electric PFDN445EL0MG ELECTRIC DRYER
General Electric PFDN445EL0MV ELECTRIC DRYER
General Electric PFDN445GL0MG GAS DRYER
General Electric PFDN445GL0MV GAS DRYER
General Electric PFDN445GL1MG GAS DRYER
General Electric PFDN445GL1MV GAS DRYER
General Electric PFDS450EL0WW ELECTRIC DRYER
General Electric PFDS450GL0WW GAS DRYER
General Electric PFDS451GL1WW GAS DRYER
General Electric PFDS455EL0MG ELECTRIC DRYER
General Electric PFDS455EL0MV ELECTRIC DRYER
General Electric PFDS455GL0MG GAS DRYER
General Electric PFDS455GL0MV GAS DRYER
General Electric PFDS455GL1MG GAS DRYER
General Electric PFDS455GL1MV GAS DRYER
Frigidaire PFE21TFA1 Frg(v2) / Top Mount Refrigerator
Frigidaire PFEF317ES1 Frigidaire Canada/electric Range
Frigidaire PFEF319ES1 Frigidaire Canada/electric Range
Frigidaire PFEF373ES1 Frigidaire Canada/electric Range
Frigidaire PFEF373ES2 Frigidaire Canada/electric Range
Frigidaire PFEF373ES3 Frigidaire/range
Frigidaire PFEF374EC1 Frigidaire Canada/electric Range
Frigidaire PFEF374EC2 Frigidaire/range
Frigidaire PFEF374EC3 Frigidaire Canada/electric Range
Frigidaire PFEF374EC4 ELECTRIC RANGE
Frigidaire PFEF374EC6 ELECTRIC RANGE
Frigidaire PFEF374ES2 Frigidaire Canada/electric Range
Frigidaire PFEF374ES3 Frigidaire Canada/electric Range
Frigidaire PFEF374ES4 ELECTRIC RANGE
Frigidaire PFEF374ES5 ELECTRIC RANGE
Frigidaire PFEF375CS3 Frigidaire Canada/electric Range
General Electric PFIC1NFWABV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFWAWV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFWBBV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFWBWV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFWCBV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFWCWV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFYABV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFYAWV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFYCBV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFYCWV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFZABV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFZAWV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFZBBV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFZBWV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFZCBV BOTTOM MOUNT REFRIGERATOR
General Electric PFIC1NFZCWV BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFWAABV BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFWAAKB BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFWBABV BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFWBAKB BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFWCABV BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFWCAKB BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFYAAKB BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFYCABV BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFYCAKB BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFZAAKB BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFZBAKB BOTTOM MOUNT REFRIGERATOR
General Electric PFIE1NFZCAKB BOTTOM MOUNT REFRIGERATOR
General Electric PFQS5PJZASS BOTTOM MOUNT REFRIGERATOR
General Electric PFQS5PJZCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MBSABB Refrigerator
General Electric PFS22MBSAWW Refrigerator
General Electric PFS22MBSBBB Refrigerator
General Electric PFS22MBSBWW Refrigerator
General Electric PFS22MBWABB BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MBWAWW BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MBWBBB BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MBWBWW BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MBWCBB BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MBWCWW BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MISABB Refrigerator
General Electric PFS22MISAWW Refrigerator
General Electric PFS22MISBBB Refrigerator
General Electric PFS22MISBWW Refrigerator
General Electric PFS22MIWABB BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MIWAWW BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MIWBBB BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MIWBWW BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MIWCBB BOTTOM MOUNT REFRIGERATOR
General Electric PFS22MIWCWW BOTTOM MOUNT REFRIGERATOR
General Electric PFS22SBSASS Refrigerator
General Electric PFS22SBSBSS Refrigerator
General Electric PFS22SBSCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFS22SBSDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFS22SISASS Refrigerator
General Electric PFS22SISBSS Refrigerator
General Electric PFS22SISCSS BOTTOM MOUNT REFRIGERATOR
General Electric PFS22SISDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSA5NJZADSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSA5NJZCDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWADBB BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWADSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWADWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWBDBB BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWBDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWBDWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWCDBB BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWCDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJWCDWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJYADSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJYADWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJYCDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJYCDWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJZADSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJZBDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSE5NJZCDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFSF0MFZBBB BOTTOM MOUNT REFRIGERATOR
General Electric PFSF0MFZBWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSF0MFZEBB BOTTOM MOUNT REFRIGERATOR
General Electric PFSF0MFZEWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSF2MIXABB BOTTOM MOUNT REFRIGERATOR
General Electric PFSF2MIXAWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSF2MIXBBB BOTTOM MOUNT REFRIGERATOR
General Electric PFSF2MIXBWW BOTTOM MOUNT REFRIGERATOR
General Electric PFSF2MIYABB BOTTOM MOUNT REFRIGERATOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Incorrect Temp Reading Errant Oven Repair (including Ranges and Cooktops) 3 10-13-2014 08:30 PM
reading wrong temp crosspatch Refrigerator & Freezer Repair 1 04-16-2013 02:09 PM
Fan Temp Reading Higher Then Room Temp RICK.JOHANNES@NORTRAX.COM Refrigerator & Freezer Repair 0 01-16-2012 06:28 AM
A/c Window Unit Temp Reading Wrong Chris311L Heating, Ventilation, and Air Conditioning (HVAC) 1 04-29-2011 05:48 PM
Flashing Temp reading in refrigerator jgmiller32 Refrigerator & Freezer Repair 0 03-10-2011 04:16 PM
