Discuss
icemaker no ice
 in
Refrigerator & Freezer Repair
The red LED on the right side flashes ONLY when the freezer door is opened ie. and not pressing the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » icemaker no ice
View Poll Results: What's the normal behavior of the red LED on the laser controlled Whirlpool icemaker?
Whirlpool model # GD5DHAXVB07 0 0%
icemaker no ice problem 0 0%
icemaker already replaced 0 0%
tested water solenoid valve - OK 0 0%
Voters: 0. You may not vote on this poll
  #1 (permalink)
Old 02-16-2018, 03:48 PM
Junior Member
ghostrider is on a distinguished road
Default icemaker no ice
Model Number: GD5DHAXVB07   Brand: Whirlpool   Age: 5 - 10 years
The red LED on the right side flashes ONLY when the freezer door is opened ie. and not pressing the overhead light switch and when the left side plastic hinged flapper is popped out obstructing the laser beam as it's supposed to. It flashes a similar sequence as in the other posts ie. blink twice then 1 second pause then repeat cycle.
With freezer door open and while pressing the overhead switch and pressing the flapper (closing it to allow the laser beam to hit the receiver - simulating the freezer door being closed) my red LED is not lit solid or flashing.
So I need to know what the normal working conditions of this red LED are under these 2 scenarios:
1 - with freezer door open and not doing anything to any of the other switches or flaps
2 - with the freezer door open while pressing the overhead switch AND while pressing closed the hinged flapper to simulate the condition of the freezer door being closed. Should the red LED be on solid under this scenario ?
I read some of the posts on this forum regarding the Infrared laser components being the source of the icemaker problem (model GD5PHAXxxxx and/or model GD5YHAXxxxx). There were 2 in particular that stated that the red LED was flashing and the sequenced pattern....but I don't recall them getting into the exact details of the conditions of everything else surrounding this ie. only the freezer door opened, freezer door opened AND the laser beam blocked by the hinged flapper on the left AND the upper door switch (light & other control). And never saw any formal test procedure for this laser setup.
Other details:
The icemaker has already been replaced and no change in symptoms.
The water solenoid valve has been tested in the same manner as the other posts described ie. pull out the frig and swap the wires between the water dispensers water valve and the icemakers valve then press water dispensers paddle and water DID come out into the icemaker tray. So the water valve is definitely good and the line in not clogged.
So this is narrowed down to the 2 Infrared laser boards kit OR the main control board. Any help would be greatly appreciated. And if there is a formal test procedure on your web site please tell me where.
Thanks,
Larry (ghostrider)
Related Models
Whirlpool GD5DHAXVQ00 REFRIGERATOR
Whirlpool GD5DHAXVQ02 REFRIGERATOR
Whirlpool GD5DHAXVQ03 REFRIGERATOR
Whirlpool GD5DHAXVQ04 REFRIGERATOR
Whirlpool GD5DHAXVQ05 REFRIGERATOR
Whirlpool GD5DHAXVQ06 REFRIGERATOR
Whirlpool GD5DHAXVY00 REFRIGERATOR
Whirlpool GD5DHAXVY02 REFRIGERATOR
Whirlpool GD5DHAXVY03 REFRIGERATOR
Whirlpool GD5DHAXVY04 REFRIGERATOR
Whirlpool GD5DHAXVY05 REFRIGERATOR
Whirlpool GD5DHAXVY06 REFRIGERATOR
Whirlpool GD5LHGXKB00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXKB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXKQ00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXKQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXKT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXKT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXLB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXLB02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXLQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXLQ02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXLT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5LHGXLT02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHAXMB00 REFRIGERATOR
Whirlpool GD5NHAXML00 REFRIGERATOR
Whirlpool GD5NHAXMQ00 REFRIGERATOR
Whirlpool GD5NHAXMT00 REFRIGERATOR
Whirlpool GD5NHAXSB00 REFRIGERATOR
Whirlpool GD5NHAXSQ00 REFRIGERATOR
Whirlpool GD5NHAXST00 REFRIGERATOR
Whirlpool GD5NHAXSY00 REFRIGERATOR
Whirlpool GD5NHGXKB01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXKB02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXKQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXKQ02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXKT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXKT02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXLQ00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXLQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXLT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NHGXLT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5NVAXSA00 REFRIGERATOR
Whirlpool GD5NVAXSA01 REFRIGERATOR
Whirlpool GD5NVAXSA02 REFRIGERATOR
Whirlpool GD5NVAXSA03 REFRIGERATOR
Whirlpool GD5NVAXSB00 REFRIGERATOR
Whirlpool GD5NVAXSB01 REFRIGERATOR
Whirlpool GD5NVAXSB02 REFRIGERATOR
Whirlpool GD5NVAXSB03 REFRIGERATOR
Whirlpool GD5NVAXSL00 REFRIGERATOR
Whirlpool GD5NVAXSL01 REFRIGERATOR
Whirlpool GD5NVAXSL02 REFRIGERATOR
Whirlpool GD5NVAXSL03 REFRIGERATOR
Whirlpool GD5NVAXSQ00 REFRIGERATOR
Whirlpool GD5NVAXSQ01 REFRIGERATOR
Whirlpool GD5NVAXSQ02 REFRIGERATOR
Whirlpool GD5NVAXSQ03 REFRIGERATOR
Whirlpool GD5NVAXSS00 REFRIGERATOR
Whirlpool GD5NVAXSS01 REFRIGERATOR
Whirlpool GD5NVAXSS02 REFRIGERATOR
Whirlpool GD5NVAXSS03 REFRIGERATOR
Whirlpool GD5NVAXST00 REFRIGERATOR
Whirlpool GD5NVAXST01 REFRIGERATOR
Whirlpool GD5NVAXST02 REFRIGERATOR
Whirlpool GD5NVAXST03 REFRIGERATOR
Whirlpool GD5NVAXSY00 REFRIGERATOR
Whirlpool GD5NVAXSY01 REFRIGERATOR
Whirlpool GD5NVAXSY02 REFRIGERATOR
Whirlpool GD5NVAXSY03 REFRIGERATOR
Whirlpool GD5NVAXWA00 REFRIGERATOR
Whirlpool GD5PHAXLB00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5PHAXLB01 REFRIGERATOR
Whirlpool GD5PHAXLQ00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool GD5PHAXLQ01 REFRIGERATOR
Whirlpool GD5PHAXMS00 REFRIGERATOR
Whirlpool GD5PHAXMS10 REFRIGERATOR
Whirlpool GD5PHAXMS11 REFRIGERATOR
Whirlpool GD5RHAXNB00 REFRIGERATOR
Whirlpool GD5RHAXNB01 REFRIGERATOR
Whirlpool GD5RHAXNL00 REFRIGERATOR
Whirlpool GD5RHAXNL01 REFRIGERATOR
Whirlpool GD5RHAXNQ00 REFRIGERATOR
Whirlpool GD5RHAXNQ01 REFRIGERATOR
Whirlpool GD5RHAXNT00 REFRIGERATOR
Whirlpool GD5RHAXNT01 REFRIGERATOR
Whirlpool GD5RHAXRB00 REFRIGERATOR
Whirlpool GD5RHAXRL00 REFRIGERATOR
Whirlpool GD5RHAXRQ00 REFRIGERATOR
Whirlpool GD5RHAXRT00 REFRIGERATOR
Whirlpool GD5RHAXSB00 REFRIGERATOR
Whirlpool GD5RHAXSB01 REFRIGERATOR
Whirlpool GD5RHAXSL00 REFRIGERATOR
Whirlpool GD5RHAXSL01 REFRIGERATOR
Whirlpool GD5RHAXSQ00 REFRIGERATOR
Whirlpool GD5RHAXSQ01 REFRIGERATOR
Whirlpool GD5RHAXSS00 REFRIGERATOR
Whirlpool GD5RHAXSS01 REFRIGERATOR
Whirlpool GD5RHAXTB00 REFRIGERATOR
Whirlpool GD5RHAXTB01 REFRIGERATOR
Whirlpool GD5RHAXTL00 REFRIGERATOR
Whirlpool GD5RHAXTL01 REFRIGERATOR
Whirlpool GD5RHAXTQ00 REFRIGERATOR
Whirlpool GD5RHAXTQ01 REFRIGERATOR
Whirlpool GD5RHAXTS00 REFRIGERATOR
Whirlpool GD5RHAXTS01 REFRIGERATOR
Whirlpool GD5RVAXVA00 REFRIGERATOR
Whirlpool GD5RVAXVA01 REFRIGERATOR
Whirlpool GD5RVAXVA02 REFRIGERATOR
Whirlpool GD5RVAXVA03 REFRIGERATOR
Whirlpool GD5RVAXVA04 REFRIGERATOR
Whirlpool GD5RVAXVA05 REFRIGERATOR
Whirlpool GD5RVAXVB00 REFRIGERATOR
Whirlpool GD5RVAXVB01 REFRIGERATOR
Whirlpool GD5RVAXVB02 REFRIGERATOR
Whirlpool GD5RVAXVB03 REFRIGERATOR
Whirlpool GD5RVAXVB04 REFRIGERATOR
Whirlpool GD5RVAXVB05 REFRIGERATOR
Whirlpool GD5RVAXVQ00 REFRIGERATOR
Whirlpool GD5RVAXVQ01 REFRIGERATOR
  #2 (permalink)
Old 02-17-2018, 08:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Answered here: icemaker - no ice
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sears Kenmore Slim-door Icemaker still not dumping ice after icemaker, module cl1chicago Refrigerator & Freezer Repair 0 07-10-2016 05:13 PM
Whirlpool Fridge Top Freezer Icemaker Water will not stop filling Icemaker hmslouie Refrigerator & Freezer Repair 2 04-27-2015 07:39 AM
Intermittant Issue -- Icemaker and Water / Icemaker Dispenser stop working GoVikings1 Refrigerator & Freezer Repair 1 01-05-2015 03:32 PM
Icemaker - water continues to dispense when Icemaker shut off arm is activated dpassaro Refrigerator & Freezer Repair 0 07-24-2011 09:57 AM
Icemaker - water continues to dispense when Icemaker shut off arm is activated dpassaro Refrigerator & Freezer Repair 0 07-24-2011 09:49 AM
