Ice maker issue. Voltmeter on terminals L and N no power. Freezer door switch taped closed. L terminal is hot but it is as if N terminal is not connected. Same issue when I disconnect the wire harness and check the black and white terminals. Power on the black when checked to ground but nothing black to white,
