Discuss
Whirlpool Refrigerator not able to cool enough!
 in
Refrigerator & Freezer Repair
Steps I have done : Completely defrosted it. Cleaned up all the coils underneath the fridge from the heavy amount
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Refrigerator not able to cool enough!
  #1 (permalink)
Old 01-11-2018, 11:04 AM
Junior Member
lucienbond24@yahoo.com is on a distinguished road
Default Whirlpool Refrigerator not able to cool enough!
Model Number: 25C0   Brand: Whirlpool   Age: 5 - 10 years
Steps I have done :
Cleaned up all the coils underneath the fridge from the heavy amount of dust.
Let it sit overnight without opening it.
Checked that all the fans are spinning. > The one in the freezer behind the panel surges between on and off - he stays on for 20 to 30 seconds then it goes off then starts right back , then it goes off again and then it starts again and only stays on for 2 to 3 seconds and shuts off again and then starts again...
Related Models
Amana 25M33PB ROOM AIR CONDITIONER
Amana 25SC FREEZER- VERTICAL
Amana 25SM FREEZER- VERTICAL
Amana 25W FREEZER- VERTICAL
Amana 25WA FREEZER- VERTICAL
Amana 25WB FREEZER- VERTICAL
Jenn-Air 2600ESC WALLOVEN- STD ELE
Jenn-Air 2601ESC WALLOVEN- STD ELE
Jenn-Air 2602ESC WALLOVEN- STD ELE
Hoover 2610
Hardwick 2639 GAS RANGE
Jenn-Air 2650 RANGE- F/S STD DDRAFT ELE
Maytag 2699A Refrigerator/Freezer
Maytag 2699W Refrigerator/Freezer
Jenn-Air 2700EEL WALLOVEN- STD ELE
Hoover 2720
Hoover 2726
Roper 2733*0A Ranges, Electric*
Roper 2733W0A Ranges, Electric*
Roper 2735*0A Ranges, Electric*
Jenn-Air 2750ELS WALLOVEN- STD ELE
Roper 2763*0A Ranges, Electric*
Roper 2763W0A Ranges, Electric*
Roper 2765*0A Ranges, Electric*
Roper 2765W0A Ranges, Electric*
Jenn-Air 2770ELD WALLOVEN- STD ELE
Jenn-Air 2775ELD WALLOVEN- STD ELE
Hoover 2800
Frigidaire 2803 GAS RANGE
Frigidaire 2803-80B GAS RANGE
Frigidaire 28044 FRIGIDAIRE GAS RANGE
Frigidaire 280440C GAS RANGE
Frigidaire 280447C GAS RANGE
Frigidaire 2809A GAS RANGE
Frigidaire 2811 GAS RANGE
Frigidaire 2812A GAS RANGE
Frigidaire 2813-80B GAS RANGE
Frigidaire 2813A GAS RANGE
Frigidaire 2819A GAS RANGE
Frigidaire 2820A GAS RANGE
Frigidaire 282240A GAS RANGE
Frigidaire 282240B GAS RANGE
Frigidaire 282240C GAS RANGE
Frigidaire 282247B GAS RANGE
Frigidaire 282247C GAS RANGE
Frigidaire 2822A GAS RANGE
Frigidaire 2823 GAS RANGE
Frigidaire 2823-80B GAS RANGE
Frigidaire 2828A GAS RANGE
Frigidaire 2829A GAS RANGE
Hoover 2830
Frigidaire 2833 GAS RANGE
Frigidaire 2833-80B GAS RANGE
Frigidaire 2834-80A GAS RANGE
Frigidaire 2834-80B FRIGIDAIRE GAS RANGE
Frigidaire 2834-87B FRIGIDAIRE GAS RANGE
Frigidaire 283440A GAS RANGE
Frigidaire 283440B GAS RANGE
Frigidaire 283440C FRIGIDAIRE GAS RANGE
Frigidaire 283440D GAS RANGE
Frigidaire 283447B GAS RANGE
Frigidaire 283447C FRIGIDAIRE GAS RANGE
Frigidaire 283447D GAS RANGE
Frigidaire 283460B GAS RANGE
Frigidaire 283460C GAS RANGE
Frigidaire 283467B GAS RANGE
Frigidaire 283467C GAS RANGE
Hoover 2836
Frigidaire 28364 GAS RANGE
Frigidaire 2841A GAS RANGE
Frigidaire 284260A GAS RANGE
Frigidaire 284267A GAS RANGE
Frigidaire 2843-80A GAS RANGE
Frigidaire 2843-80B GAS RANGE
Frigidaire 2843-80C GAS RANGE
Roper 2843W0A Ranges, Electric*
Frigidaire 284440A GAS RANGE
Frigidaire 284440B GAS RANGE
Frigidaire 284447A GAS RANGE
Frigidaire 284447B GAS RANGE
Frigidaire 2851A GAS RANGE
Frigidaire 2853 GAS RANGE
Frigidaire 28564 FRIGIDAIRE GAS RANGE
Frigidaire 285640A FRIGIDAIRE GAS RANGE
Frigidaire 285640B GAS RANGE
Frigidaire 285640D GAS RANGE
Frigidaire 285640E GAS RANGE
Frigidaire 285647A FRIGIDAIRE GAS RANGE
Frigidaire 285647B GAS RANGE
Frigidaire 285647D GAS RANGE
Frigidaire 285647E GAS RANGE
Frigidaire 285660A GAS RANGE
Frigidaire 285667A GAS RANGE
Frigidaire 28584 GAS RANGE
Frigidaire 285840A GAS RANGE
Frigidaire 285840B GAS RANGE
Frigidaire 285840C GAS RANGE
Frigidaire 285840D GAS RANGE
Frigidaire 285847A GAS RANGE
Frigidaire 285847B GAS RANGE
Frigidaire 285847C GAS RANGE
Frigidaire 285847D GAS RANGE
Frigidaire 28586 FRIGIDAIRE GAS RANGE
Frigidaire 285860A GAS RANGE
Frigidaire 285860B FRIGIDAIRE GAS RANGE
Frigidaire 285860C FRIGIDAIRE GAS RANGE
Frigidaire 285867A GAS RANGE
Frigidaire 28594 FRIGIDAIRE GAS RANGE
Frigidaire 285940A FRIGIDAIRE GAS RANGE
Frigidaire 285940B GAS RANGE
Frigidaire 285941A FRIGIDAIRE GAS RANGE
Frigidaire 285947A FRIGIDAIRE GAS RANGE
Frigidaire 285947B GAS RANGE
Frigidaire 2859A GAS RANGE
Frigidaire 2861A GAS RANGE
Frigidaire 2864 GAS RANGE
Frigidaire 2864-80B GAS RANGE
Frigidaire 2869A GAS RANGE
Frigidaire 2871A GAS RANGE
Roper 2872*0A Ranges, Electric*
  #2 (permalink)
Old 01-11-2018, 05:38 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
That motor doesn't sound right. Could you post your full model number?
  #3 (permalink)
Old 01-11-2018, 05:48 PM
Junior Member
Default Model #
Make = Whirlpool
Model # = GC5SHEXNS05
SN = SW1929547
  #4 (permalink)
Old 01-11-2018, 06:25 PM
Junior Member
Default Which one?
Do you think itís the condenser fan motor or the evaporator fan motor ?
  #5 (permalink)
Old 01-11-2018, 06:45 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
In my experience the evaporator fan (freezer) stays on as long as the compressor is running. The evap. motor like you have can fail in odd ways I've seen them where they spin a little, quit then spin a little more. Its also possible it could be the board.
These refrigerators are too complicated for what they are doing.
Whirlpool W10822580 Motor-Evap - AppliancePartsPros.com
  #6 (permalink)
Old 01-11-2018, 06:53 PM
Junior Member
Default
I thank you so much for all your time ...
I think Iím going to attempt to replace it and I will update here if that was the issue..
  #7 (permalink)
Old 01-11-2018, 11:14 PM
Junior Member
Question
Now this: all the cooling I got last night ... itís gone...
Now it doesnít even cool at all..
When I reset the power I hear the beeping that I think All fridges do which goes on for about 4-5 seconds when first plugging in the fridge, but after about 2 seconds the beeing kind of squeals interrupted, almost like a radio that works on batteries and the batteries are on their last little bits of voltage.
I know there is power going through the fridge - lights are one, the fan from the condenser motor is still spinning with no issue...
So it sound like the cooling system is having trouble starting...
What could THAT be?
Any bit of help is GREATLY appreciated...
  #8 (permalink)
Old 01-12-2018, 11:26 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
You might be in over your head on this one. These units use a variable speed compressor fed power from an inverter, (part no. 36) on this diagram.
Parts for Whirlpool GC5SHEXNS05: Unit Parts - AppliancePartsPros.com
It could also be the board (part 19) and they are hard to come by. There is no easy way to tell what is wrong. you could pull the boards and look for burnt traces, bulging capacitors, or obvious damage. But mostly you need a good multi-meter and the wiring diagram. A service manual would be helpful.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Refrigerator Want Cool pharmon Refrigerator & Freezer Repair 3 10-27-2015 11:11 AM
Refrigerator warm(not cool) freezer cool (not cold) Magnum777 Refrigerator & Freezer Repair 3 12-24-2011 04:40 PM
Whirlpool refrigerator don't cool blas_13 Refrigerator & Freezer Repair 1 08-04-2009 11:38 AM
Refrigerator won't cool millerbeachbum Refrigerator & Freezer Repair 2 11-16-2007 01:21 PM
