Discuss
FF compartment IceMaker Defrost Drain
 in
Refrigerator & Freezer Repair
I have a Kenmore French Door refrigerator with the ice maker in the fresh food compartment. It is actually a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » FF compartment IceMaker Defrost Drain
  #1 (permalink)
Old 01-01-2018, 08:01 AM
Junior Member
barryware is on a distinguished road
Default FF compartment IceMaker Defrost Drain
Model Number: 253.70313211   Brand: Kenmore   Age: 1 - 5 years
It is actually a Frigidaire FFHB2740P with a Kenmore name plate on it.
The problem is that the defrost drain for the icemaker evaporator freezes shut.
This is the second time this has happened in the last year. The first time, I did not realize the problem.
The icemaker and fridge defrost at the same time. The icemaker evaporator has its own heater and thermal switch.
When the drain (for the ice maker) freezes shut, water drips down the back panel of the fridge (on the inside), pools, then freezes under the bottom drawer. If left unchecked, it will eventually make its way to the damper and freeze causing the damper to no longer be able to move.
The last time I had to fix it, I did not realize the problem was the icemaker defrost drain frozen shut until I had everything apart. Even then, It took almost two days for it to thaw itself out. The drain pipe (tube) is encapsulated in the foam insulation sprayed in between the interior walls, and the exterior panels. Even a heat gun was not much help.
So.. My questions is if anyone knows how this drain tube is routed.
It is not even mentioned in any parts lists, prints, or views I have been able to find online.
I only see one drain tube underneath the fridge leading into the drain pan.
I suspect that maybe the icemaker drain terminates at or near the main evaporator and there is only one drain for both, or, the icemaker drain is inside the larger drain tube that drips into the pan.
I was thinking I could clear the drain by pushing something from the end of the drain, back up to the frozen part near the icemaker.
So.. Can someone advise as to where the icemaker defrost drain terminates?
Related Models
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Kenmore 25314702102 FREEZER
Kenmore 25314702103 FREEZER
Kenmore 25314702104 FREEZER
Kenmore 25314712100 FREEZER
Kenmore 25314712101 FREEZER
Kenmore 25314712102 FREEZER
Kenmore 25314712103 FREEZER
Kenmore 25314772100 FREEZER
Kenmore 25314772101 FREEZER
Kenmore 25314772102 FREEZER
Kenmore 25314772103 FREEZER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Icemaker water valve leaking inside drawer compartment militaryman Refrigerator & Freezer Repair 0 08-31-2017 06:08 AM
Frigidaire defrost pan drain not lined up with drain hose tmw1040@aol.com Refrigerator & Freezer Repair 0 08-15-2016 05:04 AM
Jennair refrigerator compartment warm plus ice forming on top of freezer compartment judelangdon Refrigerator & Freezer Repair 0 07-01-2014 06:16 PM
Freezer compartment drain access cwtravis Refrigerator & Freezer Repair 4 11-28-2011 05:50 PM
fridge icemaker does not defrost cube to eject ppop1119 Refrigerator & Freezer Repair 0 04-05-2011 01:45 PM
