Hey everyone, I have a client "Dylan" complains of a worm fridge compartment and compressor won't turn on. I took off the evaporator coil cover and found a large and very dense chunk of ice formed only around the defrost thermostat. I procedid to defrost the ice then I did a diagnostics test to find the compressor and condenser fan are now working ;however I discovered the evaporator fan has failed. I was wondering what caused that odd circular formation of ice around the defrost thermostat and does it have anything to do with the failed fan? Appliance Boy attached the following image(s):
