Discuss
Kenmore Elite intermittently cooling
 in
Refrigerator & Freezer Repair
I apologize as I try to explain what happened without confusing anyone. Our refrigerator freezer started to slowly become warmer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Elite intermittently cooling
  #1 (permalink)
Old 11-29-2017, 05:37 PM
rkm rkm is offline
Junior Member
rkm is on a distinguished road
Default Kenmore Elite intermittently cooling
Model Number: 40141003010   Brand: Kenmore   Age: 5 - 10 years
Our refrigerator freezer started to slowly become warmer over the past few weeks. Eventually, ice cream would no longer stay frozen, but everything else appeared to (that's ok, I can eat ice cream no matter what temperature!) Last week, I decided to get out my multimeter and start searching the internet to figure out how refrigerators work so I could try to troubleshoot the issue. The day after thanksgiving (I still couldn't figure out the issue), the refrigerator started to having issue with cooling (we put an appliance thermometer in there). The fridge started to fluctuate up to above 40 but if we turned on rapid cooling, then the refrigerator would get down to 34F (which is the correct temperature for rapid cooling). Eventually it would end up back around or above 40. After a couple days the rapid cooling stopped working. For the freezer, the rapid freeze mode did not help temporarily bring down the temperature when it started having issues. The couple days before the refrigerator compartment stopped cooling, the freezer stopped working all together after I spent a day trying to figure out why it wasn't cold enough. I now know way more than I ever thought I would about the fridge except what is wrong with it. Basically, it's a fancy fridge with mostly Samsung electronics. It has a pretty comprehensive diagnostic mode, which of course says everything is fine. I tested the voltages of the sensors at the main PCB, and those all appeared fine. I had checked the evaporator coils in the freezer which were cold, but not froze up with ice. The evaporator fan appeared to be operating correctly as well as the thermistor. The condenser fan was also running. The condenser itself is also pretty warm to the touch and the refrigerator and condenser all sound like they are running fine.
After many hours of research and discovery (as I slowly figured out which advice was wrong and right about testing certain things), I decided that I could see how the main PCB could be potentially the issue (especially because we had a lightning strike near our hour 3 years ago which fried a bunch of stuff in the house and the pcb board smelled a little burnt while troubleshooting). Replacing the PCB did not seem to make any difference, so I swapped it back for the original one. Once I got the original back in and did some more poking around, I eventually plugged the fridge back in and called it a night (that was 2 days ago), since then, the freezer started to cool again and is now at 20 degrees (it has bounced between the 20s and 30s during the past 2 days). The freezer temp is set to it's default -2F, so obviously it's still 22F above what it's supposed to be at. The fridge has been staying around 40F plus or minute 2F (it's set for the default 38F)
This is confusing me a bit as to what might be the issue. The compressor has to be working (the fridge diagnostics has always said it was on) otherwise the fridge wouldn't cool at all. I thought maybe since the fridge has a multi speed compressor, that maybe the compressor isn't being kicked into high speed? I tried to get to the pins on the compressor to test for resistance, but having a hard time getting the internal protector off of it (I got the black cover off, but there is something else underneath that needs to come off.) The only other thought is maybe the inverter board could be going bad? I'm wondering if because how the behavior of the fridge temperature fluctuating, if that might point to one or the other. My wife is getting impatient and wants the fridge fixed. I am a software engineer, so I feel like I should at least be capable of diagnosing the problem and determine whether I need a professional to come out or need a new fridge.
Anyone have any thoughts? It's hard to find any info about this particular fridge, most repair information seems to be about fridges that use a non-variable speed compressor and no inverter.
Thanks for any suggestions! If I have to tuck my tail and call someone out to diagnose it I will, regardless of how much my pride will take a hit.
Ryan
Related Models
Kenmore 40141003010 REFRIGERATOR
Kenmore 40141003110 REFRIGERATOR
Kenmore 40141003900 REFRIGERATOR
Kenmore 40141009010 REFIGERATOR
Kenmore 40141009110 REFRIGERATOR
Kenmore 40141009900 REFRIGERATOR
Kenmore 40180082700 MICROWAVE
Kenmore 40180083700 MICROWAVE
Kenmore 40180084700 MICROWAVE
Kenmore 40180086700 MICROWAVE
Kenmore 40180089700 MICROWAVE
Kenmore 40180092010 MICROWAVE
Kenmore 40180092700 MICROWAVE
Kenmore 40180093010 MICROWAVE
Kenmore 40180093700 MICROWAVE
Kenmore 40180094700 MICROWAVE
Kenmore 40180099010 MICROWAVE
Kenmore 40180099700 MICROWAVE
Kenmore 40185042010 MICROWAVE OVEN
Kenmore 40185043010 MICROWAVE OVEN
Kenmore 40185044010 MICROWAVE OVEN
Kenmore 40185046010 MICROWAVE OVEN
Kenmore 40185049010 MICROWAVE OVEN
Kenmore 40185052010 MICROWAVE HOOD COMBO
Kenmore 40185053010 MICROWAVE HOOD COMBO
Kenmore 40185059010 MICROWAVE HOOD COMBO
Kenmore 40185143010 MICROWAVE OVEN
Kenmore 4018822980 KENMORE MICROWAVE OVEN
Kenmore 40188522900 MICROWAVE
Kenmore 40188523900 MICROWAVE/HOOD COMBO
Kenmore 40188529900 MICROWAVE
Kenmore 4018901080 CAPRI MICROWAVE OVEN
Kenmore 4018912980 Microwave Domestic
Kenmore 4018922980 Microwave Domestic
Kenmore 4018922990 MICROWAVE OVEN
Kenmore 4018923590 MICROWAVE OVEN
Kenmore 4018934980 MICROWAVE OVEN
Kenmore 4018934991 MICROWAVE OVEN
Kenmore 4018996680 MICRO/CONVECTION OVEN
Amana 402.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 402.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 402.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 402.003 MWAVE - FAMILY SIZE (60 HZ)
Amana 403.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 403.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 403.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 404
Frigidaire 40437-7A FREEZER
Frigidaire 40437A-7 FREEZER
Frigidaire 40438-7A FREEZER
General Electric 4071120 DISHWASHER
General Electric 4071520 DISHWASHER
General Electric 4071620 DISHWASHER
Frigidaire 40846-7D FREEZER
Frigidaire 40846D FREEZER
Frigidaire 40847-7A FREEZER
Frigidaire 40847A UPRIGHT FREEZER
Frigidaire 40848-7A FREEZER
Frigidaire 40848-7B FREEZER
Frigidaire 40848-7C FREEZER
Frigidaire 40849-0C UPRIGHT FREEZER
Frigidaire 40849A FREEZER
Frigidaire 40849B UPRIGHT FREEZER
Hoover 409
Hoover 41
Amana 410.000 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 4100PRA RANGE- F/S STD GAS
Magic Chef 4100PRA-K RANGE- F/S STD GAS
Magic Chef 4100PRW RANGE- F/S STD GAS
Magic Chef 4100PRW-K RANGE- F/S STD GAS
Magic Chef 4100PTW RANGE- F/S STD GAS
Amana 411.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 412.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 412.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 412.002 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 4121WRA RANGE- F/S STD GAS
Magic Chef 4121WRW RANGE- F/S STD GAS
Frigidaire 4129B ELECTRIC RANGE
Amana 413.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 413.001 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 4131WRA RANGE- F/S STD GAS
Magic Chef 4131WRW RANGE- F/S STD GAS
General Electric 4132990 RADIANT MODULE
Amana 414.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 414.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 414.002 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 4141WTA RANGE- F/S STD GAS
Magic Chef 4141WTW RANGE- F/S STD GAS
Hoover 415
Amana 415.000 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 4151WTA RANGE- F/S STD GAS
Magic Chef 4151WTB RANGE- F/S STD GAS
Magic Chef 4151WTW RANGE- F/S STD GAS
Amana 416.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 416.001 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite He5 Gas Dryer Won't Run Diagnostics, Intermittently Won't Start cshot2 Dryer Repair 0 07-01-2017 03:19 PM
Kenmore Elite Not Cooling lawprelim Refrigerator & Freezer Repair 0 10-14-2016 02:16 PM
Kenmore Elite Dryer Intermittently Stops Running CVilla Dryer Repair 9 07-14-2015 03:35 AM
Kenmore Elite Refrigerator not cooling Parker23 Refrigerator & Freezer Repair 2 08-03-2012 10:30 AM
Kenmore Elite not cooling Bull-37 Refrigerator & Freezer Repair 3 06-10-2009 03:39 PM
