Discuss
Amana Refrigerator TR25VW Leaking From Freezer
 in
Refrigerator & Freezer Repair
Hi, Our old Amana has been slowly dripping water into the fridge for weeks. I fainlly go around to dealing
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Refrigerator TR25VW Leaking From Freezer
  #1 (permalink)
Old 11-29-2017, 09:00 AM
Junior Member
Lamf77 is on a distinguished road
Default Amana Refrigerator TR25VW Leaking From Freezer
Model Number: TR25VW   Brand: Amana   Age: More than 10 years
Our old Amana has been slowly dripping water into the fridge for weeks. I fainlly go around to dealing with it today. Removed everything, unplugged and opened doors.
I took the drain assembly out from the back and it is not clogged.
I believe it may be something under the "floor" of the freezer. But for the life of me I can not get it out!
I see how it clips down in the from, but it appears it is somehow screwed in, but I can not find where the screws are?
Just wondering if I am missing something or what my next move is.
Somewhat desperate...
Thanks!
Mike
Related Models
Amana TR25VW REF - TOP MOUNT
Admiral TR475NF REF - TOP MOUNT
Amana TR518G REF - TOP MOUNT
Amana TR518H REF - TOP MOUNT
Amana TR518I REF - TOP MOUNT
Amana TR518IQ REF - TOP MOUNT
Amana TR518IT REF - TOP MOUNT
Amana TR518ITAL REF - TOP MOUNT
Amana TR518ITAW REF - TOP MOUNT
Amana TR518ITVL REF - TOP MOUNT
Amana TR518ITVW REF - TOP MOUNT
Amana TR518ITWL REF - TOP MOUNT
Amana TR518ITWW REF - TOP MOUNT
Amana TR518K REF - TOP MOUNT
Amana TR518M REF - TOP MOUNT
Amana TR518N REF - TOP MOUNT
Amana TR518Q REF - TOP MOUNT
Amana TR520G1 REF - TOP MOUNT
Amana TR520H1 REF - TOP MOUNT
Amana TR520K1 REF - TOP MOUNT
Amana TR520M1 REF - TOP MOUNT
Amana TR520N1 REF - TOP MOUNT
Amana TR520Q1 REF - TOP MOUNT
Amana TR521VE REF - TOP MOUNT
Amana TR521VW REF - TOP MOUNT
Amana TR522SL REF - TOP MOUNT
Amana TR522SW REF - TOP MOUNT
Amana TR525SL REF - TOP MOUNT
Amana TR525SW REF - TOP MOUNT
Amana TR525VW REF - TOP MOUNT
Admiral TR580NF REF - TOP MOUNT
Amana TRG16J REF - TOP MOUNT
Amana TRG18J REF - TOP MOUNT
Amana TRG18K REF - TOP MOUNT
Amana TRG18M REF - TOP MOUNT
Amana TRG18N REF - TOP MOUNT
Amana TRG18QB2L REF - TOP MOUNT
Amana TRG18QB2W REF - TOP MOUNT
Amana TRG18QB3G REF - TOP MOUNT
Amana TRG18QB3L REF - TOP MOUNT
Amana TRG18QB3W REF - TOP MOUNT
Amana TRG18QBG REF - TOP MOUNT
Amana TRG18QBL REF - TOP MOUNT
Amana TRG18QBW REF - TOP MOUNT
Amana TRG18SPH REF - TOP MOUNT
Amana TRG20J REF - TOP MOUNT
Amana TRG20M REF - TOP MOUNT
Amana TRG20SPH REF - TOP MOUNT
Amana TRG22J REF - TOP MOUNT
Amana TRGI18J REF - TOP MOUNT
Amana TRGI18QBL REF - TOP MOUNT
Amana TRGI18QBW REF - TOP MOUNT
Amana TRGI20J REF - TOP MOUNT
Amana TRGI22J REF - TOP MOUNT
Amana TRI-17D MISC / ACCESSORY
Amana TRI-17D-1 MISC / ACCESSORY
Amana TRI-17E MISC / ACCESSORY
Amana TRI-17LD MISC / ACCESSORY
Amana TRI-17LD-1 MISC / ACCESSORY
Amana TRI-17LE MISC / ACCESSORY
Amana TRI16K REF - TOP MOUNT
Amana TRI17E MISC / ACCESSORY
Amana TRI17LE MISC / ACCESSORY
Amana TRI18D REF - TOP MOUNT
Amana TRI18D MISC / ACCESSORY
Amana TRI18D-A REF - TOP MOUNT
Amana TRI18D-C REF - TOP MOUNT
Amana TRI18D-G REF - TOP MOUNT
Amana TRI18D-L REF - TOP MOUNT
Amana TRI18E MISC / ACCESSORY
Amana TRI18E-A MISC / ACCESSORY
Amana TRI18E-C MISC / ACCESSORY
Amana TRI18E-G MISC / ACCESSORY
Amana TRI18E-L MISC / ACCESSORY
Amana TRI18J REF - TOP MOUNT
Amana TRI18K REF - TOP MOUNT
  #2 (permalink)
Old 11-29-2017, 11:44 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Its a fun job.......not.
You need to take both doors off and the center hinge. Then you need to pull the center part out. All the wiring and controls is in that center section as well as the drain pan and vents.
Image 2 on this parts diagram.
Parts for Amana TR25VW / P1196404W W: Interior Cabinet and Drain Block Assy Parts - AppliancePartsPros.com
Often ice builds up under the freezer "floor" and its what is dripping. The drain is full of ice or was in the past.
Set aside a few hours to do this and make plans to put your food in coolers. I used to be able to do this in about 90 minutes. I used hot water and a shop vac to control the mess.
If the drain pan is full of ice you may need to add a 12 gauge copper wire to the defrost element, to help keep the drain clear. Its an old trick I was taught 30 years ago when I was a lot younger.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana bottom freezer ice build-up and leaking ckleckne Refrigerator & Freezer Repair 29 08-01-2016 11:32 AM
amana side by side refrigerator water line inside freezer door leaking borth Refrigerator & Freezer Repair 1 10-21-2012 02:45 PM
amana bottom freezer leaking joe1934 Refrigerator & Freezer Repair 7 03-08-2010 01:44 PM
Amana leaking water from freezer haight78 Refrigerator & Freezer Repair 0 05-12-2008 08:29 AM
Refrigerator/Freezer has liquid leaking inside freezer and frig terrib Refrigerator & Freezer Repair 0 12-25-2007 11:15 PM
