Discuss
Replacing Door Hinge on KitchenAid Side by Side
 in
Refrigerator & Freezer Repair
The initial symptoms were internal lights (both freezer and fridge) intermittently failing, ice and water dispenser not working, and 'door
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Replacing Door Hinge on KitchenAid Side by Side
  #1 (permalink)
Old 11-24-2017, 05:15 PM
Junior Member
clivedaw is on a distinguished road
Default Replacing Door Hinge on KitchenAid Side by Side
Model Number: KSSC42QTS00   Brand: Kitchen Aid   Age: 5 - 10 years
The initial symptoms were internal lights (both freezer and fridge) intermittently failing, ice and water dispenser not working, and 'door open' alarm light illuminated. I determined that the door switch on the freezer side was not being depressed due to a detached extension arm (part AP6284656). The door closer cam (part AP6005693) which attaches to the top of the post on the top door hinge (part AP6006923) had come off because the head of the screw that holds it onto the hinge post had been sheared off.
I believe the screw had gradually loosened due to opening and closing the door, allowing the cam to travel upwards to where it wasn't anchored on the square portion of the hinge post, but only on the screw itself. At some point the spring which connects to the extension was strong enough to shear off the top of the screw, leaving the body of the screw stuck inside the hinge post.
While assessing the situation, I looked over at the similar configuration on the fridge door side. I noticed that the cam on the top of the hinge post was somewhat loose, so I used a socket wrench to tighten it down. A few hours later (thankfully I had replaced the upper panel) I heard a sound like a gunshot and discovered that the same thing had happened on the fridge side: the screw head had been sheared off and the spring had shot the extension arm toward the back of the refrigerator in the cavity to the right of the compressor housing.
I ordered two new hinges. Unfortunately, the drawings do not show the screw which fits into the hinges that hold the cams on. When I received the hinges, I went to several hardware stores looking for a screw that fit into the post, and only then discovered, to my surprise, that the inside of the posts on the replacement hinges are not threaded!!
I have no idea how to proceed. Is it possible that both replacement hinges were defective? Or is the screw I'm looking for supposed to be self-tapping?
Just a final comment: I consider it a poor design to have the extension arm that depresses the door switch (very small force) and the function of having the door automatically swing shut (large force) both depend on a very strong spring which is ultimately held in place by a screw of only 1/8" diameter. If I could figure out how to extract the screw bodies from the existing hinges, I could reuse the hinges. But they are too small to use conventional screw extraction tools, which is why I need to replace them.
Thanks in advance for any help.
Related Models
Whirlpool KSSC42QTS00 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QTS02 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QTS03 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QVS00 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QVS01 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QVS02 42" BUILT IN REFRIGERATOR
KitchenAid KSSC48FJB00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FJS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FJT00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FJW00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FKB00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FKB01 BUILT IN REFRIGERATOR
Whirlpool KSSC48FKB02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FKS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FKS01 BUILT IN REFRIGERATOR
Whirlpool KSSC48FKS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FMS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FMS01 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FMS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FMS03 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FTS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FTS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FTS03 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FTS04 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48MFS05 BUILT-IN REFRIGERATOR
Whirlpool KSSC48MHS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48QKS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48QKS01 BUILT IN REFRIGERATOR
Whirlpool KSSC48QKS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QMS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QMS01 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QMS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QMS03 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QTS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QTS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QTS03 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QVS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QVS01 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QVS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSO36FMX00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FMX01 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FMX02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FMX03 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FTX00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FTX02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FTX03 36" BUILT IN REFRIGERATOR
KitchenAid KSSO36FTX04 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMB00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMB01 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMB02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMB03 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMW00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMW01 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMX02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTB00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTB02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTB03 36" BUILT IN REFRIGERATOR
KitchenAid KSSO36QTB04 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTX00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTX02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTX03 36" BUILT IN REFRIGERATOR
KitchenAid KSSO36QTX04 36" BUILT IN REFRIGERATOR
Whirlpool KSSO42FMX00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FMX01 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FMX02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FMX03 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FTX00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FTX02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FTX03 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FTX04 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMB00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMB01 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMB02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMB03 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMW00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMW01 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMX01 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMX02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTB00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTB02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTB03 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTB04 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTX00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTX02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTX03 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTX04 42" BUILT IN REFRIGERATOR
Whirlpool KSSO48FMX00 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48FMX01 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48FMX02 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48FMX03 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48FTX00 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48FTX02 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48FTX03 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48FTX04 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QMB00 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QMB01 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QMB02 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QMB03 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QMW00 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QMW01 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QMX02 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QTB00 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QTB02 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QTB03 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QTB04 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QTX00 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QTX02 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QTX03 48" BUILT IN REFRIGERATOR
Whirlpool KSSO48QTX04 48" BUILT IN REFRIGERATOR
Whirlpool KSSP36MFB05 BUILT-IN REFRIGERATOR
Whirlpool KSSP36MFS05 BUILT-IN REFRIGERATOR
Whirlpool KSSP36MFT05 BUILT-IN REFRIGERATOR
Whirlpool KSSP36MFW05 BUILT-IN REFRIGERATOR
Whirlpool KSSP36QFB05 BUILT-IN REFRIGERATOR
Whirlpool KSSP36QFS05 BUILT-IN REFRIGERATOR
Whirlpool KSSP36QFW05 BUILT-IN REFRIGERATOR
KitchenAid KSSP36QGT00 BUILT-IN REFRIGERATOR
Whirlpool KSSP36QHB00 BUILT-IN REFRIGERATOR
Whirlpool KSSP36QHS00 BUILT-IN REFRIGERATOR
Whirlpool KSSP36QHT00 BUILT-IN REFRIGERATOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing in door side by side auger motor smartin2516 Refrigerator & Freezer Repair 0 01-06-2013 01:46 PM
Replacing door gasket seal on side by side Kitchen Aid Refrigerator curtisn Refrigerator & Freezer Repair 4 11-20-2012 07:39 PM
Replacing lower hinge on GE side by side with Ice Maker in door grichter Refrigerator & Freezer Repair 0 01-10-2012 09:38 AM
Replacing waterline for side by side refrigerator in door water Volsmcm Refrigerator & Freezer Repair 0 08-11-2011 02:01 PM
GE Side-by-side freezer door hinge replacement kinsman Refrigerator & Freezer Repair 2 03-25-2010 11:13 AM
