Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   fridgidaire water inlet valve leaking (http://forum.appliancepartspros.com/refrigerator-freezer-repair/572371-fridgidaire-water-inlet-valve-leaking.html)
Priestb 11-21-2017 06:28 AM
I have Fridgidaire FRS6LF7FQ6 and the water inlet valve was leaking. I replaced it (AP03160649) and the new valve has new quick connect fittings, which are much easier....except I cant get them to stop leaking. I have double and triple checked that the cuts I made to the plastic tubes are clean and straight. Connections appear to be fine, but continue to leak ( a lot ) when the water dispenser is pressed.
Any ideas?
