Discuss
Need Figidaire side by side help, repeated start-stop inside compartments
 in
Refrigerator & Freezer Repair
Can hear it start/stop 20X or so from inside freezer and especially in refrigerator section, sound comes from the control
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Need Figidaire side by side help, repeated start-stop inside compartments
  #1 (permalink)
Old 11-13-2017, 09:59 AM
Junior Member
mrow22 is on a distinguished road
Default Frigidaire side by side advice request, repeated start-stop inside compartments
Model Number: FRS26H7CSB2   Brand: Frigidaire   Age: More than 10 years
Can hear it start/stop 20X or so from inside freezer and especially in refrigerator section, sound comes from the control assembly at the top of the compartment, and not at the compressor. (Possibly Evaporator motor or some type of control or relay?). At first I thought this might be the run capacitor and start device at the compressor (was all set to buy and install new ones) but they seem to be fine. The compressor fan works, coils are clean as I can make them. Temps seem right.
Reluctant to start disassembling the covers inside the fridge compartment evaporator section until I have a firm idea what is causing it not to start the fans on the first try, as there will be quite a bit of food out of the box unprotected. If there is a basic part I could have standing by it might be helpful. If it is an entire control board or something like that, maybe a component can be fixed first before replacing an entire assembly or board. The sound is loudest on the right (fridge section) side. I will get a video recording of it if I can.
This start-stop is occurring often enough, but definitely not at every cycle. Sounds like fan(s) are trying to engage and not succeeding. Sometimes it starts as it should. The start-stop interval is 1 sec, and has increased from a few X in a cycle per day whenever it does occur, to 20 start-stops in one cycle a month later( now). The fan(s) sound fine once they finally do engage.
Thanks much. Don
Related Models
Frigidaire FRS26H7CSB2 Frigidaire/refrigerator
Frigidaire FRS26H7CSB3 Frigidaire/refrigerator
Frigidaire FRS26H7CSB4 Frigidaire/refrigerator
Frigidaire FRS26H7CW0 Frigidaire/refrigerator
Frigidaire FRS26H7CW1 Frigidaire/refrigerator
Frigidaire FRS26H7CW2 Frigidaire/refrigerator
Frigidaire FRS26H7CW3 Frigidaire/refrigerator
Frigidaire FRS26H7CW4 Frigidaire/refrigerator
Frigidaire FRS26HBBSB0 Frigidaire/refrigerator
Frigidaire FRS26HBBSB1 Frigidaire/refrigerator
Frigidaire FRS26HBBSB2 Frigidaire/refrigerator
Frigidaire FRS26HBBSB3 Frigidaire/refrigerator
Frigidaire FRS26HF5AB0 Frigidaire/refrigerator
Frigidaire FRS26HF5AB1 Frigidaire/refrigerator
Frigidaire FRS26HF5AB2 Frigidaire/refrigerator
Frigidaire FRS26HF5AB3 Frigidaire/refrigerator
Frigidaire FRS26HF5AB4 Frigidaire/refrigerator
Frigidaire FRS26HF5AB5 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ0 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ1 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ2 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ3 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ4 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ5 Frigidaire/refrigerator
Frigidaire FRS26HF5AW0 Frigidaire/refrigerator
Frigidaire FRS26HF5AW1 Frigidaire/refrigerator
Frigidaire FRS26HF5AW2 Frigidaire/refrigerator
Frigidaire FRS26HF5AW3 Frigidaire/refrigerator
Frigidaire FRS26HF5AW4 Frigidaire/refrigerator
Frigidaire FRS26HF5AW5 Frigidaire/refrigerator
Frigidaire FRS26HF6BB0 Frigidaire/refrigerator
Frigidaire FRS26HF6BB1 Frigidaire/refrigerator
Frigidaire FRS26HF6BB2 Frigidaire/refrigerator
Frigidaire FRS26HF6BB3 Frigidaire/refrigerator
Frigidaire FRS26HF6BB4 Frigidaire/refrigerator
Frigidaire FRS26HF6BB6 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ0 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ1 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ2 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ3 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ4 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ6 Frigidaire/refrigerator
Frigidaire FRS26HF6BW0 Frigidaire/refrigerator
Frigidaire FRS26HF6BW1 Frigidaire/refrigerator
Frigidaire FRS26HF6BW2 Frigidaire/refrigerator
Frigidaire FRS26HF6BW3 Frigidaire/refrigerator
Frigidaire FRS26HF6BW4 Frigidaire/refrigerator
Frigidaire FRS26HF6BW6 Frigidaire/refrigerator
Frigidaire FRS26HF7BB0 Frigidaire/refrigerator
Frigidaire FRS26HF7BB1 Frigidaire/refrigerator
Frigidaire FRS26HF7BB2 Frigidaire/refrigerator
Frigidaire FRS26HF7BB3 Frigidaire/refrigerator
Frigidaire FRS26HF7BB4 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ0 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ1 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ2 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ3 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ4 Frigidaire/refrigerator
Frigidaire FRS26HF7BW0 Frigidaire/refrigerator
Frigidaire FRS26HF7BW1 Frigidaire/refrigerator
Frigidaire FRS26HF7BW2 Frigidaire/refrigerator
Frigidaire FRS26HF7BW3 Frigidaire/refrigerator
Frigidaire FRS26HF7BW4 Frigidaire/refrigerator
Frigidaire FRS26HR4AB0 Frigidaire efrigerator
Frigidaire FRS26HR4AB1 Frigidaire efrigerator
Frigidaire FRS26HR4AB3 Frigidaire/refrigerator
Frigidaire FRS26HR4AQ0 Frigidaire efrigerator
Frigidaire FRS26HR4AQ1 Frigidaire efrigerator
Frigidaire FRS26HR4AQ3 Frigidaire/refrigerator
Frigidaire FRS26HR4AW0 Frigidaire efrigerator
Frigidaire FRS26HR4AW1 Frigidaire efrigerator
Frigidaire FRS26HR4AW3 Frigidaire/refrigerator
Frigidaire FRS26HR4DB0 Frigidaire/refrigerator
Frigidaire FRS26HR4DB2 Frigidaire/refrigerator
Frigidaire FRS26HR4DB4 Frigidaire/refrigerator
Frigidaire FRS26HR4DB5 Frigidaire/refrigerator
Frigidaire FRS26HR4DB6 Frigidaire/refrigerator
Frigidaire FRS26HR4DB9 Frigidaire/refrigerator
Frigidaire FRS26HR4DQ0 Frigidaire/refrigerator
Frigidaire FRS26HR4DQ2 Frigidaire/refrigerator
Frigidaire FRS26HR4DQ3 Frigidaire/refrigerator
Frigidaire FRS26HR4DQ4 Frigidaire/refrigerator
Frigidaire FRS26HR4DQ5 Frigidaire/refrigerator
Frigidaire FRS26HR4DQ6 Frigidaire/refrigerator
Frigidaire FRS26HR4DQ7 Frigidaire/refrigerator
Frigidaire FRS26HR4DQ9 Frigidaire/refrigerator
Frigidaire FRS26HR4DW0 Frigidaire/refrigerator
Frigidaire FRS26HR4DW1 Frigidaire/refrigerator
Frigidaire FRS26HR4DW2 Frigidaire/refrigerator
Frigidaire FRS26HR4DW3 Frigidaire/refrigerator
Frigidaire FRS26HR4DW4 Frigidaire/refrigerator
Frigidaire FRS26HR4DW5 Frigidaire/refrigerator
Frigidaire FRS26HR4DW6 Frigidaire/refrigerator
Frigidaire FRS26HR4DW7 Frigidaire/refrigerator
Frigidaire FRS26HR4DW8 Frigidaire/refrigerator
Frigidaire FRS26HR4DW9 Frigidaire/refrigerator
Frigidaire FRS26HR4DWB REFRIGERATOR
Frigidaire FRS26KF5CB0 Frigidaire/refrigerator
Frigidaire FRS26KF5CB1 Frigidaire/refrigerator
Frigidaire FRS26KF5CB3 Frigidaire/refrigerator
Frigidaire FRS26KF5CQ0 Frigidaire/refrigerator
Frigidaire FRS26KF5CQ1 Frigidaire/refrigerator
Frigidaire FRS26KF5CQ3 Frigidaire/refrigerator
Frigidaire FRS26KF5CS0 Frigidaire/refrigerator
Frigidaire FRS26KF5CS2 Frigidaire/refrigerator
Frigidaire FRS26KF5CW0 Frigidaire/refrigerator
Frigidaire FRS26KF5CW1 Frigidaire/refrigerator
Frigidaire FRS26KF5CW3 Frigidaire/refrigerator
Frigidaire FRS26KF5DB0 Frigidaire/refrigerator
Frigidaire FRS26KF5DB1 Frigidaire/refrigerator
Frigidaire FRS26KF5DB2 Frigidaire/refrigerator
Frigidaire FRS26KF5DB3 Frigidaire/refrigerator
Frigidaire FRS26KF5DB5 Frigidaire/refrigerator
Frigidaire FRS26KF5DB7 Frigidaire/refrigerator
Frigidaire FRS26KF5DB9 Frigidaire/refrigerator
Frigidaire FRS26KF5DQ0 Frigidaire/refrigerator
Frigidaire FRS26KF5DQ1 Frigidaire/refrigerator
Frigidaire FRS26KF5DQ2 Frigidaire/refrigerator
Frigidaire FRS26KF5DQ3 Frigidaire/refrigerator
Frigidaire FRS26KF5DS0 Frigidaire/refrigerator
  #2 (permalink)
Old 11-13-2017, 05:42 PM
Junior Member
LyndaG is on a distinguished road
Default Frigidaire Side by Side FRS26LR5CW0
Don,
I am having the same issue. I just replaced the Damper Control Assembly because after about a month of the starting and stopping (also from inside the frig, not the back where the compressor is) the frig compartment started freezing food - I researched and thought it to be the Damper Control motor perhaps was protecting itself by coming on and off because it couldn't shut the door - so I elected to spend the money (and time/frustration at poorly designed and placed screws) and replace the Damper Control...sure enough the door was stuck in the open position - almost "fused" in the open position...because there is a small motor attached to the assembly, I was relatively certain this was the sound I was hearing and the motor was doing it's job by on/offing protecting itself...after reassembling and plugging back in - it ran like a top and I didn't hear the on/off attempts any longer...until today - a little more than 24 hrs later the on and off attempts started again. I will say not as many tries - it was 20 + tries before whatever it is would run...now it's 3 or 4 tries and it doesn't happen as often, but nonetheless the problem is still there sans freezing my food.
Does anyone know what this could be? My research came up with 5 parts it could be, replacing the damper control leaves me with 4 parts it could be and none of them are cheap...this is a 14 yr old frig that is otherwise fine, but i'm going to have a hard time spending several hundred more dollars without knowing for sure it's going to fix it....help!!
  #3 (permalink)
Old 11-14-2017, 10:38 PM
Junior Member
Default
Hi sounds like it could be a similar (or same) issue, but I am not clear on exactly what parts are not working properly. I would think that damper disassembly, cleaning, lubing joints (probably lithium good for metal or plastic) and possibly small motor replacement could make it work reliably again. I have not taken mine apart yet, and the compartment temps have been good.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Side-by-side Compressor Making Repeated Thunking Sounds profilelimo Refrigerator & Freezer Repair 1 02-01-2011 02:27 AM
side-by-side, top of compartments warm Bay City Refrigerator & Freezer Repair 7 02-03-2010 04:27 AM
Side by Side leaking from top inside fridge side jns992001 Refrigerator & Freezer Repair 0 01-16-2010 09:17 AM
Whirlpool side by side start / stop issue totobis Refrigerator & Freezer Repair 0 12-24-2009 10:33 AM
Freezer side warms up but is icing up inside back panel, ref side warm atunaya Refrigerator & Freezer Repair 2 04-07-2009 12:46 PM
