Discuss
U-Line Ice Machine low production & cube size issue
 in
Refrigerator & Freezer Repair
Cranked my old U-Line CLR2060 back up this weekend after installing a new water inlet solenoid. Started up fine, water
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » U-Line Ice Machine low production & cube size issue
  #1 (permalink)
Old 11-13-2017, 09:02 AM
Junior Member
hc803 is on a distinguished road
Default U-Line Ice Machine low production & cube size issue
Model Number: CLR2060   Brand: -other-   Age: More than 10 years
Cranked my old U-Line CLR2060 back up this weekend after installing a new water inlet solenoid. Started up fine, water comes in, pump runs, compressor kicks on. But it's only making ice on the top 2 rows of the production grid and no matter how I set the "cube dimple" knob, it makes thin cubes. No way for the bin to fill at this rate. I can't figure out why only half of the grid would produce: it's an all-or-nothing system (i.e. if there was a leak in the tube behind the grid, it wouldn't make any ice at all). Ideas?
Related Models
Magic Chef CLY1610ADB RV RANGE- GAS
Magic Chef CLY1610ADQ RV RANGE- GAS
Magic Chef CLY1610ADW RV RANGE- GAS
Magic Chef CLY1610BDB RV RANGE- GAS
Maytag CLY1610BDB13 16" GAS RV RANGE SUPER BURNER
Magic Chef CLY1610BDQ RV RANGE- GAS
Magic Chef CLY1610BDW RV RANGE- GAS
Magic Chef CLY1611BDH RV RANGE- GAS
Magic Chef CLY1612ADH RV RANGE- GAS
Magic Chef CLY1612BDH RV RANGE- GAS
Magic Chef CLY1620ADB RV RANGE- GAS
Magic Chef CLY1620ADQ RV RANGE- GAS
Magic Chef CLY1620ADS RV RANGE- GAS
Magic Chef CLY1620ADW RV RANGE- GAS
Magic Chef CLY1620BDB RV RANGE- GAS
Maytag CLY1620BDB13 16" GAS RV RANGE SUPER BURNER
Magic Chef CLY1620BDS RV RANGE- GAS
Maytag CLY1620BDS12 16" GAS RV RANGE SUPER BURNER
Magic Chef CLY1620BDW RV RANGE- GAS
Magic Chef CLY1628ADB RV RANGE- GAS
Magic Chef CLY1628BDB RV RANGE- GAS
Magic Chef CLY1631ADB RV RANGE- GAS
Magic Chef CLY1631ADH RV RANGE- GAS
Magic Chef CLY1631ADL RV RANGE- GAS
Magic Chef CLY1631BDB RV RANGE- GAS
Magic Chef CLY1631BDH RV RANGE- GAS
Magic Chef CLY1631BDL RV RANGE- GAS
Magic Chef CLY1631BDT RV RANGE- GAS
Magic Chef CLY1632ADB RV RANGE- GAS
Magic Chef CLY1632ADH RV RANGE- GAS
Magic Chef CLY1632ADL RV RANGE- GAS
Magic Chef CLY1632BDB RV RANGE- GAS
Magic Chef CLY1632BDH RV RANGE- GAS
Magic Chef CLY1632BDL RV RANGE- GAS
Magic Chef CLY1632BDT RV RANGE- GAS
Magic Chef CLY1638BDB RV RANGE- GAS
Magic Chef CLY1641ADB RV RANGE- GAS
Magic Chef CLY1641ADH RV RANGE- GAS
Magic Chef CLY1641ADL RV RANGE- GAS
Magic Chef CLY1641BDB RV RANGE- GAS
Magic Chef CLY1641BDH RV RANGE- GAS
Magic Chef CLY1641BDL RV RANGE- GAS
Magic Chef CLY1641BDT RV RANGE- GAS
Magic Chef CLY1642ADH RV RANGE- GAS
Magic Chef CLY1642BDH RV RANGE- GAS
Magic Chef CLY1645BDB RV RANGE- GAS
Magic Chef CLY1662ADH RV RANGE- GAS
Magic Chef CLY1662BDH RV RANGE- GAS
Magic Chef CLY2210ADB RV RANGE- GAS
Magic Chef CLY2210ADW RV RANGE- GAS
Magic Chef CLY2210BDB RV RANGE- GAS
Magic Chef CLY2212ADH RV RANGE- GAS
Magic Chef CLY2212BDH RV RANGE- GAS
Magic Chef CLY2220ADB RV RANGE- GAS
Magic Chef CLY2220ADW RV RANGE- GAS
Magic Chef CLY2220BDB RV RANGE- GAS
Maytag CLY2220BDB13 22" GAS RV RANGE SUPER BURNER
Magic Chef CLY2220BDW RV RANGE- GAS
Magic Chef CLY2231ADH RV RANGE- GAS
Magic Chef CLY2231BDB RV RANGE- GAS
Magic Chef CLY2231BDH RV RANGE- GAS
Magic Chef CLY2232ADH RV RANGE- GAS
Magic Chef CLY2232BDB RV RANGE- GAS
Magic Chef CLY2232BDH RV RANGE- GAS
Magic Chef CLY2235BDB RV RANGE- GAS
Magic Chef CLY2241ADH RV RANGE- GAS
Magic Chef CLY2241ADL RV RANGE- GAS
Magic Chef CLY2241BDB RV RANGE- GAS
Magic Chef CLY2241BDH RV RANGE- GAS
Magic Chef CLY2241BDL RV RANGE- GAS
Magic Chef CLY2241BDT RV RANGE- GAS
Magic Chef CLY2242ADB RV RANGE- GAS
Magic Chef CLY2242ADH RV RANGE- GAS
Magic Chef CLY2242ADL RV RANGE- GAS
Magic Chef CLY2242BDB RV RANGE- GAS
Magic Chef CLY2242BDH RV RANGE- GAS
Magic Chef CLY2242BDL RV RANGE- GAS
Magic Chef CLY2242BDT RV RANGE- GAS
Magic Chef CLY2245BDB RV RANGE- GAS
Magic Chef CLY2245BDT RV RANGE- GAS
Magic Chef CLY2248BDB RV RANGE- GAS
Magic Chef CLY2249BDB RV RANGE- GAS
Magic Chef CLY2253ADB RV RANGE- GAS
Magic Chef CLY2253BDB RV RANGE- GAS
Magic Chef CLY2260ADB RV RANGE- GAS
Magic Chef CLY2260ADW RV RANGE- GAS
Magic Chef CLY2260BDB RV RANGE- GAS
Maytag CLY2260BDB12 22" GAS RV RANGE SEALED BURNERS
Magic Chef CLY2260BDW RV RANGE- GAS
Magic Chef CLY2262ADH RV RANGE- GAS
Magic Chef CLY2262BDH RV RANGE- GAS
Magic Chef CLZ8501ADL RV SURFACE UNIT- GAS
Magic Chef CLZ8501BDB RV SURFACE UNIT- GAS
Magic Chef CLZ8501BDH RV SURFACE UNIT- GAS
Magic Chef CLZ8501BDL RV SURFACE UNIT- GAS
Magic Chef CLZ8501BDT RV SURFACE UNIT- GAS
Magic Chef CLZ8502ADB RV SURFACE UNIT- GAS
Magic Chef CLZ8502ADH RV SURFACE UNIT- GAS
Magic Chef CLZ8502ADL RV SURFACE UNIT- GAS
Magic Chef CLZ8502BDB RV SURFACE UNIT- GAS
Magic Chef CLZ8502BDH RV SURFACE UNIT- GAS
Magic Chef CLZ8502BDL RV SURFACE UNIT- GAS
Magic Chef CLZ8502BDT RV SURFACE UNIT- GAS
Magic Chef CLZ8505BDB RV SURFACE UNIT- GAS
Magic Chef CLZ8505BDT RV SURFACE UNIT- GAS
Magic Chef CLZ8508BDB RV SURFACE UNIT- GAS
Magic Chef CLZ8509BDB RV SURFACE UNIT- GAS
Magic Chef CLZ8550ADQ RV SURFACE UNIT- GAS
Magic Chef CLZ8550ADW RV SURFACE UNIT- GAS
Magic Chef CLZ8560ADB RV SURFACE UNIT- GAS
Maytag CLZ8560ADB15 22" GAS RV COOKTOP SEALED BURNERS
Magic Chef CLZ8560ADQ RV SURFACE UNIT- GAS
Magic Chef CLZ8560ADW RV SURFACE UNIT- GAS
Whirlpool CM02743BL1 Microwaves*
Jenn-Air CM100 SURFACE BASE UNIT- DDRAFT ELE
Jenn-Air CM100-E SURFACE BASE UNIT- DDRAFT ELE
Crosley CM151 MWAVE- CNTRTP / STAND ALONE
Crosley CM153 MWAVE- CNTRTP / STAND ALONE
Magic Chef CM15K-7BS-NB MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM15KW-7BS-NB MWAVE- MOUNTED OVER RANGE/WO
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE ice maker ice cube size adjustment Frank63 Refrigerator & Freezer Repair 0 07-16-2017 02:13 PM
Gas line replacement issue judremy Dryer Repair 0 02-08-2011 08:51 AM
Ice maker cube size haggis2 Refrigerator & Freezer Repair 2 02-19-2010 01:43 PM
low ice cube production a2x5welrs Refrigerator & Freezer Repair 0 08-28-2009 08:45 AM
GE Profile Ice cube size Flash Gordon Refrigerator & Freezer Repair 1 08-12-2008 04:44 PM
