Discuss
Amana side-by-side water dispenser drip
 in
Refrigerator & Freezer Repair
I have an Amana side-by-side that is 11 or 12 years old. The water dispenser has started dripping. It will
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana side-by-side water dispenser drip
  #1 (permalink)
Old 10-06-2017, 05:43 AM
Junior Member
niffirg20 is on a distinguished road
Default Amana side-by-side water dispenser drip
Model Number: ARS9167AW   Brand: Amana   Age: More than 10 years
I have an Amana side-by-side that is 11 or 12 years old. The water dispenser has started dripping. It will drip slowly for 10 or 15 minutes after use. This would just be an annoyance except that the water line to the ice maker is doing the same thing. After a few days the slow drip to the ice maker forms an ice dam at the end of the water line coming into the ice maker.
I have replaced the primary and secondary water inlet valve and attempted to purge air from the system (detached the water reservoir and moved it around to dislodge any trapped bubbles then ran the water dispenser continuously for a little over 3 minutes). The drip has continued although it does seems like it has slowed down a bit.
Does anyone have ideas on what else could be causing my drip? Thanks.
Related Models
Amana ARS9167AW REF - SXS/I&W
Amana ARS9168AB REF - SXS/I&W
Amana ARS9168AC REF - SXS/I&W
Amana ARS9168AS REF - SXS/I&W
Amana ARS9168AW REF - SXS/I&W
Amana ARS9169AS REF - SXS/I&W
Amana ARS9265BB REF - SXS/I&W
Amana ARS9265BC REF - SXS/I&W
Amana ARS9265BW REF - SXS/I&W
Amana ARS9266BS REF - SXS/I&W
Amana ARS9268BB REF - SXS/I&W
Amana ARS9268BC REF - SXS/I&W
Amana ARS9268BW REF - SXS/I&W
Amana ARS9269BS REF - SXS/I&W
Amana ARSE664BB REF - SXS/I&W
Amana ARSE664BC REF - SXS/I&W
Amana ARSE664BS REF - SXS/I&W
Amana ARSE664BW REF - SXS/I&W
Amana ARSE665BB REF - SXS/I&W
Amana ARSE665BC REF - SXS/I&W
Amana ARSE665BS REF - SXS/I&W
Amana ARSE665BW REF - SXS/I&W
Amana ARSE667BB REF - SXS/I&W
Amana ARSE667BC REF - SXS/I&W
Amana ARSE667BS REF - SXS/I&W
Amana ARSE667BW REF - SXS/I&W
Amana ARSE66MBB REF - SXS/I&W
Amana ARSE66MBC REF - SXS/I&W
Amana ARSE66MBW REF - SXS/I&W
Amana ARSE66ZBB REF - SXS/I&W
Amana ARSE66ZBC REF - SXS/I&W
Amana ARSE66ZBS REF - SXS/I&W
Amana ARSE66ZBW REF - SXS/I&W
Amana ARSE67RBB REF - SXS/I&W
Amana ARSE67RBC REF - SXS/I&W
Amana ARSE67RBS REF - SXS/I&W
Amana ARSE67RBW REF - SXS/I&W
Amana ART1805BC REF - TOP MOUNT
Amana ART1805BW REF - TOP MOUNT
Amana ART2105BB REF - TOP MOUNT
Amana ART2105BC REF - TOP MOUNT
Amana ART2105BW REF - TOP MOUNT
Amana ART2107BB REF - TOP MOUNT
Amana ART2107BC REF - TOP MOUNT
Amana ART2107BS REF - TOP MOUNT
Amana ART2107BW REF - TOP MOUNT
Amana ART2127AB REF - TOP MOUNT
Amana ART2127AC REF - TOP MOUNT
Amana ART2127AS REF - TOP MOUNT
Amana ART2127AW REF - TOP MOUNT
Amana ART2129ABR REF - TOP MOUNT
Amana ART2129ACR REF - TOP MOUNT
Amana ART2129ASR REF - TOP MOUNT
Amana ART2129AWR REF - TOP MOUNT
Amana ART2527AB REF - TOP MOUNT
Amana ART2527AC REF - TOP MOUNT
Amana ART2527AW REF - TOP MOUNT
Amana ART5400L RANGE- STD MWAVE ELE
Amana ART5400W RANGE- STD MWAVE ELE
Amana ART6000L RANGE- S/C S/I DDRAFT GAS
Amana ART6000W RANGE- S/C S/I DDRAFT GAS
Amana ART6001L RANGE- S/C S/I DDRAFT GAS
Amana ART6001W RANGE- S/C S/I DDRAFT GAS
Amana ART6002L RANGE- S/C S/I DDRAFT GAS
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W RANGE- S/C S/I DDRAFT GAS
Amana ART6002W Range - S/c S/i Ddraft Gas
Amana ART6021C RANGE- S/C S/I DDRAFT GAS
Amana ART6021L RANGE- S/C S/I DDRAFT GAS
Amana ART6021W RANGE- S/C S/I DDRAFT GAS
Amana ART6100E RANGE- S/C S/I DDRAFT GAS
Amana ART6100LL RANGE- S/C S/I DDRAFT GAS
Amana ART6100WW RANGE- S/C S/I DDRAFT GAS
Amana ART6110E RANGE- S/C S/I DDRAFT ELE
  #2 (permalink)
Old 10-06-2017, 06:21 AM
Junior Member
Default I think the drip has stopped
I checked again a few minutes ago and it seems that my drip has stopped. I guess purging the water lines (which was the last work that I did the frig) is what stopped the drip. I didn't realize this initially because there was still some residual dripping immediately after purging the lines. All seems to be good now.
  #3 (permalink)
Old 10-16-2017, 07:59 AM
Junior Member
Default Still have the drip
So I thought that I had the drip fixed, but I was wrong. It has slowed down a lot but not gone away. It is still letting out 3-4 drops every 2-3 hours. Apparently, the drip is coming out of the water dispenser as well as the supply tube to the ice maker, because it is slowing blocking the supply tube with a chunk of ice. Any ideas? Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Side-by-Side Water Drip jladd Refrigerator & Freezer Repair 3 08-15-2012 11:05 AM
amana side by side water dispenser rogkyllo Refrigerator & Freezer Repair 0 10-31-2011 02:44 PM
Amana Side-by-Side Water Dispenser Leak AJCjr Refrigerator & Freezer Repair 0 06-12-2011 11:54 AM
Side by side Amana water dispenser not working Filbert Refrigerator & Freezer Repair 1 11-04-2010 08:06 AM
Amana Side by Side Water and Ice Dispenser stopped working RBrrttJr Refrigerator & Freezer Repair 0 01-27-2010 12:03 PM
