Hi I saw the post about the door switch related to the water dispenser not working. My problem started a couple of weeks ago. I replaced the water filter, the front display board on the advice of a repair person that came to my house, the dual water intake valve and the chute. Nothing fixed the problem. I noticed that if I depress the depressor and open the fridge door and flick the switch the water will come out. There are two door switches on this model, and I have no idea which one to replace because the behavior is the same for both door switches. Any help is greatly appreciated. Kelly
