Discuss
Remove drip tray
 in
Refrigerator & Freezer Repair
I have Amana bottom freezer refrigerator model #BX22S5L (P1196701WL) I need instructions on how to remove the drip tray to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Remove drip tray
  #1 (permalink)
Old 09-16-2017, 01:14 PM
Junior Member
hinspect is on a distinguished road
Default Remove drip tray
Model Number: BX22S5L   Brand: Amana   Age: More than 10 years
I have Amana bottom freezer refrigerator model #BX22S5L (P1196701WL) I need instructions on how to remove the drip tray to clean
Related Models
Amana BX22S5L REF - BOTTOM MOUNTS
Amana BX22S5W REF - BOTTOM MOUNTS
Amana BX22TE REF - BOTTOM MOUNTS
Amana BX22TL REF - BOTTOM MOUNTS
Amana BX22TW REF - BOTTOM MOUNTS
Amana BX518VE REF - BOTTOM MOUNTS
Amana BX518VW REF - BOTTOM MOUNTS
Amana BX521VCPER REF - BOTTOM MOUNTS
Amana BX521VCPSR REF - BOTTOM MOUNTS
Amana BX521VCPWR REF - BOTTOM MOUNTS
Amana BX521VE REF - BOTTOM MOUNTS
Amana BX521VW REF - BOTTOM MOUNTS
Amana BXF19TL REF - BOTTOM MOUNTS
Amana BXF19TW REF - BOTTOM MOUNTS
Amana BXI21VE REF - BOTTOM MOUNTS
Amana BXI21VL REF - BOTTOM MOUNTS
Amana BXI21VW REF - BOTTOM MOUNTS
Amana BXI22S5E REF - BOTTOM MOUNTS
Amana BXI22S5L REF - BOTTOM MOUNTS
Amana BXI22S5W REF - BOTTOM MOUNTS
Whirlpool BYCCD3421W0 COMPACT ELECTRIC DYER
Whirlpool BYCCD3421W1 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3421W2 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3421W3 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3921W0 ELECTRIC DRYER
Whirlpool BYCD3722W0 DRYERS
Whirlpool BYCD3722W1 ELECTRIC DRYER
Whirlpool BYCD3723W0 DRYERS
Whirlpool BYCD3723W1 GAS DRYER
Whirlpool BYCD3723W2 DRYER
Whirlpool BYCD4932W0 ELECTRIC DRYER
Whirlpool BYCD4933W0 GAS DRYER
Whirlpool BYCW4271W0 DIRECT-DRIVE WASHER
Whirlpool BYCW6292W0 WASHER
Whirlpool BYCWD6274W0 LAUNDRY COMBINATION UNITS
Whirlpool BYCWD6274W1 WASHER / DRYER COMBINATION UNIT
Whirlpool BYCWD6274W2 WASHER/DRYER COMBO
Whirlpool BYCWD6274W3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool BYCWD6274W4 WASHER/DRYER LAUNDRY SYSTEM
Amana BZ20QE REF - BOTTOM MOUNTS
Amana BZ20QG REF - BOTTOM MOUNTS
Amana BZ20QL REF - BOTTOM MOUNTS
Amana BZ20QW REF - BOTTOM MOUNTS
Amana BZ20R REF - BOTTOM MOUNTS
Amana BZ20RE REF - BOTTOM MOUNTS
Amana BZ20RG REF - BOTTOM MOUNTS
Amana BZ20RL REF - BOTTOM MOUNTS
Amana BZ20RW REF - BOTTOM MOUNTS
Amana BZ22QE REF - BOTTOM MOUNTS
Amana BZ22QL REF - BOTTOM MOUNTS
Amana BZ22QW REF - BOTTOM MOUNTS
Amana BZ22R3E REF - BOTTOM MOUNTS
Amana BZ22R3L REF - BOTTOM MOUNTS
Amana BZ22R3W REF - BOTTOM MOUNTS
Amana BZ22R5L REF - BOTTOM MOUNTS
Amana BZ22R5W REF - BOTTOM MOUNTS
Amana BZ22RE REF - BOTTOM MOUNTS
Amana BZ22RL REF - BOTTOM MOUNTS
Amana BZ22RW REF - BOTTOM MOUNTS
Jenn-Air C SURFACE UNIT- DDRAFT ELE
Hardwick C-413 SURFACE UNIT- GAS
Hardwick C-414 SURFACE UNIT- GAS
Hardwick C-423 SURFACE UNIT- GAS
Hardwick C-424 SURFACE UNIT- GAS
Hardwick C-433 SURFACE UNIT- GAS
Hardwick C-434 SURFACE UNIT- GAS
Hardwick C-443 SURFACE UNIT- GAS
Hardwick C-444 SURFACE UNIT- GAS
Jenn-Air C100 SURFACE UNIT- DDRAFT ELE
Amana C100DW FREEZER- CHEST
Amana C100FW FREEZER- CHEST
Jenn-Air C101 SURFACE UNIT- DDRAFT ELE
Jenn-Air C101-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C101-J SURFACE UNIT- DDRAFT ELE
Amana C101DW FREEZER- CHEST
Amana C101FW FREEZER- CHEST
Jenn-Air C102 SURFACE UNIT- DDRAFT ELE
Amana C102B ROOM AIR CONDITIONER
Jenn-Air C106 SURFACE UNIT- DDRAFT ELE
Jenn-Air C106-C SURFACE UNIT- DDRAFT ELE
Hoover C1065--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1067--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1069--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1085--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1091--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1099--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Maytag C10AALWH FREEZER- CHEST
Amana C10B FREEZER- CHEST
  #2 (permalink)
Old 09-17-2017, 01:31 PM
Senior Member
PNWDrew is on a distinguished road
Default
That really isn't an option on that unit. It's possible but not something that a DIYer really would tackle.
Why do you want it cleaned?
  #3 (permalink)
Old 09-17-2017, 02:20 PM
Junior Member
Default Drip pan removal
It has old standing water and stinks worse than a mildewed rag!
  #4 (permalink)
Old 09-17-2017, 02:51 PM
Senior Member
Default
Ah... Each defrost will drop a cup or more of water in there. It should dry by evaporation. If it isn't drying it can get nasty. If there isn't much airflow due to clearances around the unit that can hinder drying too.
Check that the grille in front is clear and the condenser is clear. The fan will usually move enough air through to dry the pan in between defrosts.
Beyond that you can carefully access from back and clean the pan. Unplug it so the fan doesn't bite you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replace water dispenser drip tray pennsvalley Refrigerator & Freezer Repair 0 06-13-2014 04:45 PM
Drip Tray Replacement FF2140 Refrigerator & Freezer Repair 1 05-02-2014 10:27 PM
Whirlpool Fridge Drip Tray removal LauraNY Refrigerator & Freezer Repair 0 08-27-2013 05:45 PM
Water leaking under the drip tray and leaking rust down front michnos Refrigerator & Freezer Repair 0 08-04-2012 12:51 PM
How do I remove drip tray emock1 Refrigerator & Freezer Repair 3 02-21-2012 05:55 PM
