Auger Motor and Drive Bar
Refrigerator & Freezer Repair
Hi, The ice is not being pushed out of the bin. The auger motor is working, but isn't getting the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Auger Motor and Drive Bar
  #1 (permalink)
Old 09-15-2017, 09:51 PM
Junior Member
stevemcches is on a distinguished road
Default Auger Motor and Drive Bar
Model Number: FRS26KF6EW5   Brand: Frigidaire   Age: 5 - 10 years
The ice is not being pushed out of the bin. The auger motor is working, but isn't getting the strength to turn the auger. It appears the drive bar is slipping. It seems like it is held on by a 15mm nut. How is the drive bar tightened to the auger motor? I can't seem to tighten or loosen the nut. How should the drive bar be tightened so it will not slip against the auger motor spline?
Thanks for any help!
Related Models
Frigidaire FRS26KF6EW6 Frigidaire/refrigerator
Frigidaire FRS26KF6EW7 Frigidaire/refrigerator
Frigidaire FRS26KF7AB0 Frigidaire efrigerator
Frigidaire FRS26KF7AB1 Frigidaire efrigerator
Frigidaire FRS26KF7AB3 Frigidaire/refrigerator
Frigidaire FRS26KF7AB4 Frigidaire/refrigerator
Frigidaire FRS26KF7AB5 Frigidaire/refrigerator
Frigidaire FRS26KF7AB6 Frigidaire/refrigerator
Frigidaire FRS26KF7AQ0 Frigidaire efrigerator
Frigidaire FRS26KF7AQ1 Frigidaire efrigerator
Frigidaire FRS26KF7AQ3 Frigidaire/refrigerator
Frigidaire FRS26KF7AQ4 Frigidaire/refrigerator
Frigidaire FRS26KF7AQ5 Frigidaire/refrigerator
Frigidaire FRS26KF7AQ6 Frigidaire/refrigerator
Frigidaire FRS26KF7AW0 Frigidaire efrigerator
Frigidaire FRS26KF7AW1 Frigidaire efrigerator
Frigidaire FRS26KF7AW3 Frigidaire/refrigerator
Frigidaire FRS26KF7AW4 Frigidaire/refrigerator
Frigidaire FRS26KF7AW5 Frigidaire/refrigerator
Frigidaire FRS26KF7AW6 Frigidaire/refrigerator
Frigidaire FRS26KR4AB0 Frigidaire efrigerator
Frigidaire FRS26KR4AB1 Frigidaire efrigerator
Frigidaire FRS26KR4AB3 Frigidaire/refrigerator
Frigidaire FRS26KR4AB4 Frigidaire/refrigerator
Frigidaire FRS26KR4AB5 Frigidaire/refrigerator
Frigidaire FRS26KR4AB6 Frigidaire/refrigerator
Frigidaire FRS26KR4AQ0 Frigidaire efrigerator
Frigidaire FRS26KR4AQ1 Frigidaire efrigerator
Frigidaire FRS26KR4AQ3 Frigidaire/refrigerator
Frigidaire FRS26KR4AQ4 Frigidaire/refrigerator
Frigidaire FRS26KR4AQ5 Frigidaire/refrigerator
Frigidaire FRS26KR4AQ6 Frigidaire/refrigerator
Frigidaire FRS26KR4AW0 Frigidaire efrigerator
Frigidaire FRS26KR4AW1 Frigidaire efrigerator
Frigidaire FRS26KR4AW3 Frigidaire/refrigerator
Frigidaire FRS26KR4AW4 Frigidaire/refrigerator
Frigidaire FRS26KR4AW5 Frigidaire/refrigerator
Frigidaire FRS26KR4AW6 Frigidaire/refrigerator
Frigidaire FRS26KR4CB0 Frigidaire/refrigerator
Frigidaire FRS26KR4CB1 Frigidaire/refrigerator
Frigidaire FRS26KR4CB3 Frigidaire/refrigerator
Frigidaire FRS26KR4CQ0 Frigidaire/refrigerator
Frigidaire FRS26KR4CQ1 Frigidaire/refrigerator
Frigidaire FRS26KR4CQ3 Frigidaire/refrigerator
Frigidaire FRS26KR4CW0 Frigidaire/refrigerator
Frigidaire FRS26KR4CW1 Frigidaire/refrigerator
Frigidaire FRS26KR4CW3 Frigidaire/refrigerator
Frigidaire FRS26KR4DB0 Frigidaire/refrigerator
Frigidaire FRS26KR4DB1 Frigidaire/refrigerator
Frigidaire FRS26KR4DB2 Frigidaire/refrigerator
Frigidaire FRS26KR4DB3 Frigidaire/refrigerator
Frigidaire FRS26KR4DB6 Frigidaire/refrigerator
Frigidaire FRS26KR4DB7 Frigidaire/refrigerator
Frigidaire FRS26KR4DB8 Frigidaire/refrigerator
Frigidaire FRS26KR4DBB Frigidaire/refrigerator
Frigidaire FRS26KR4DBC Frigidaire/refrigerator
Frigidaire FRS26KR4DQ0 Frigidaire/refrigerator
Frigidaire FRS26KR4DQ1 Frigidaire/refrigerator
Frigidaire FRS26KR4DQ2 Frigidaire/refrigerator
Frigidaire FRS26KR4DQ3 Frigidaire/refrigerator
Frigidaire FRS26KR4DQ6 Frigidaire/refrigerator
Frigidaire FRS26KR4DQ7 Frigidaire/refrigerator
Frigidaire FRS26KR4DQ8 Frigidaire/refrigerator
Frigidaire FRS26KR4DQB Frigidaire/refrigerator
Frigidaire FRS26KR4DQC Frigidaire/refrigerator
Frigidaire FRS26KR4DQN Frigidaire/refrigerator
Frigidaire FRS26KR4DS0 Frigidaire/refrigerator
Frigidaire FRS26KR4DS1 Frigidaire/refrigerator
Frigidaire FRS26KR4DS2 Frigidaire/refrigerator
Frigidaire FRS26KR4DS3 Frigidaire/refrigerator
Frigidaire FRS26KR4DS4 Frigidaire/refrigerator
Frigidaire FRS26KR4DS6 Frigidaire/refrigerator
Frigidaire FRS26KR4DW0 Frigidaire/refrigerator
Frigidaire FRS26KR4DW1 Frigidaire/refrigerator
Frigidaire FRS26KR4DW2 Frigidaire/refrigerator
Frigidaire FRS26KR4DW3 Frigidaire/refrigerator
Frigidaire FRS26KR4DW4 Frigidaire/refrigerator
Frigidaire FRS26KR4DW5 Frigidaire/refrigerator
Frigidaire FRS26KR4DW6 Frigidaire/refrigerator
Frigidaire FRS26KR4DW7 Frigidaire/refrigerator
Frigidaire FRS26KR4DW8 Frigidaire/refrigerator
Frigidaire FRS26KR4DWB Frigidaire/refrigerator
Frigidaire FRS26KR4DWC Frigidaire/refrigerator
Frigidaire FRS26KR4JQ0 Frg(v1) / Refrigerator
Frigidaire FRS26KR4JQ1 Frg(v1) / Refrigerator
Frigidaire FRS26KR4JW0 Frg(v2) / Refrigerator
Frigidaire FRS26KW3AB0 Frigidaire/refrigerator
Frigidaire FRS26KW3AB1 Frigidaire/refrigerator
Frigidaire FRS26KW3AB3 Frigidaire/refrigerator
Frigidaire FRS26KW3AB4 Frigidaire/refrigerator
Frigidaire FRS26KW3AB5 Frigidaire/refrigerator
Frigidaire FRS26KW3AB6 Frigidaire/refrigerator
Frigidaire FRS26KW3AQ0 Frigidaire/refrigerator
Frigidaire FRS26KW3AQ1 Frigidaire/refrigerator
Frigidaire FRS26KW3AQ3 Frigidaire/refrigerator
Frigidaire FRS26KW3AQ4 Frigidaire/refrigerator
Frigidaire FRS26KW3AQ5 Frigidaire/refrigerator
Frigidaire FRS26KW3AQ6 Frigidaire/refrigerator
Frigidaire FRS26KW3AW0 Frigidaire/refrigerator
Frigidaire FRS26KW3AW1 Frigidaire/refrigerator
Frigidaire FRS26KW3AW3 Frigidaire/refrigerator
Frigidaire FRS26KW3AW4 Frigidaire/refrigerator
Frigidaire FRS26KW3AW5 Frigidaire/refrigerator
Frigidaire FRS26KW3AW6 Frigidaire/refrigerator
Frigidaire FRS26LF7DS0 Frigidaire/refrigerator
Frigidaire FRS26LF7DS1 Frigidaire/refrigerator
Frigidaire FRS26LF7DS2 Frigidaire/refrigerator
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
auger drive motor replacement proted Refrigerator & Freezer Repair 0 07-15-2014 12:52 PM
Ice Bucket Auger Cup Drive and Helix repair mchase971 Refrigerator & Freezer Repair 2 02-12-2011 11:36 AM
GE PSS Ice Maker Auger Drive and Drive Cup HELP TheGD Refrigerator & Freezer Repair 0 11-03-2010 04:30 AM
the Drive Auger on my Ice dispenser is loose danleo01 Refrigerator & Freezer Repair 1 08-31-2010 12:06 PM
Removal of auger drive motor dkw75nov Refrigerator & Freezer Repair 0 07-05-2010 11:39 AM
