Discuss
Water in refrigerator, bottom freezer mount
 in
Refrigerator & Freezer Repair
I have an Amana bottom mount freezer. I have noticed water collecting on the fins of the temperature control box
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water in refrigerator, bottom freezer mount
  #1 (permalink)
Old 09-14-2017, 08:56 PM
Junior Member
theboysmom3 is on a distinguished road
Default Water in refrigerator, bottom freezer mount
Model Number: BR18VW-P1320703WW   Brand: Amana   Age: More than 10 years
I have an Amana bottom mount freezer. I have noticed water collecting on the fins of the temperature control box in the back of the refrigerator. There is also ice on 2 slots behind the crisper drawers and a small amount of water under the drawers. Any suggestions as to what the problem may be.
Thank you
Related Models
Amana BR20J REF - BOTTOM MOUNTS
Amana BR20K REF - BOTTOM MOUNTS
Amana BR20M REF - BOTTOM MOUNTS
Amana BR20N REF - BOTTOM MOUNTS
Amana BR20QBL REF - BOTTOM MOUNTS
Amana BR20QBW REF - BOTTOM MOUNTS
Amana BR22S6E REF - BOTTOM MOUNTS
Amana BR22S6L REF - BOTTOM MOUNTS
Amana BR22S6W REF - BOTTOM MOUNTS
Amana BR22TE REF - BOTTOM MOUNTS
Amana BR22TL REF - BOTTOM MOUNTS
Amana BR22TW REF - BOTTOM MOUNTS
Amana BR22V1C REF - BOTTOM MOUNTS
Amana BR22V1E REF - BOTTOM MOUNTS
Amana BR22V1W REF - BOTTOM MOUNTS
Amana BR22VC REF - BOTTOM MOUNTS
Amana BR22VE REF - BOTTOM MOUNTS
Amana BR22VL REF - BOTTOM MOUNTS
Amana BR22VW REF - BOTTOM MOUNTS
Whirlpool BR51IMW1 FREESTANDING ICE MAKER
Amana BRD18V1C REF - BOTTOM MOUNTS
Amana BRD18V1E REF - BOTTOM MOUNTS
Amana BRD18V1S REF - BOTTOM MOUNTS
Amana BRD18V1W REF - BOTTOM MOUNTS
Amana BRD18V2C REF - BOTTOM MOUNTS
Amana BRD18V2E REF - BOTTOM MOUNTS
Amana BRD18V2S REF - BOTTOM MOUNTS
Amana BRD18V2W REF - BOTTOM MOUNTS
Admiral BRD924B REF - SXS/I&W
Amana BRE14 MISC / ACCESSORY
Amana BRF14 MISC / ACCESSORY
Amana BRF14L MISC / ACCESSORY
Amana BRF20TE REF - BOTTOM MOUNTS
Amana BRF20TL REF - BOTTOM MOUNTS
Amana BRF20TLW REF - BOTTOM MOUNTS
Amana BRF20TW REF - BOTTOM MOUNTS
Amana BRF20V1C REF - BOTTOM MOUNTS
Amana BRF20V1CPCR REF - BOTTOM MOUNTS
Amana BRF20V1CPER REF - BOTTOM MOUNTS
Amana BRF20V1CPSR REF - BOTTOM MOUNTS
Amana BRF20V1CPWR REF - BOTTOM MOUNTS
Amana BRF20V1E REF - BOTTOM MOUNTS
Amana BRF20V1S REF - BOTTOM MOUNTS
Amana BRF20V1W REF - BOTTOM MOUNTS
Amana BRF20VC REF - BOTTOM MOUNTS
Amana BRF20VCPC REF - BOTTOM MOUNTS
Amana BRF20VCPCR REF - BOTTOM MOUNTS
Amana BRF20VCPE REF - BOTTOM MOUNTS
Amana BRF20VCPER REF - BOTTOM MOUNTS
Amana BRF20VCPSE REF - BOTTOM MOUNTS
Amana BRF20VCPSER REF - BOTTOM MOUNTS
Amana BRF20VCPW REF - BOTTOM MOUNTS
Amana BRF20VCPWR REF - BOTTOM MOUNTS
Amana BRF20VE REF - BOTTOM MOUNTS
Amana BRF20VL REF - BOTTOM MOUNTS
Amana BRF20VSE REF - BOTTOM MOUNTS
Amana BRF20VW REF - BOTTOM MOUNTS
Amana BRF520T1E REF - BOTTOM MOUNTS
Amana BRF520T1W REF - BOTTOM MOUNTS
Amana BRF520TE REF - BOTTOM MOUNTS
Amana BRF520TW REF - BOTTOM MOUNTS
Amana BRFS14 MISC / ACCESSORY
Amana BRFS14L MISC / ACCESSORY
Amana BRS14 MISC / ACCESSORY
Amana BRS14L MISC / ACCESSORY
Whirlpool BRS62ABANA00 REFRIGERATOR
Whirlpool BRS62ABANA01 REFRIGERATOR
Whirlpool BRS62ARANA00 REFRIGERATOR
Whirlpool BRS62ARANA01 REFRIGERATOR
Whirlpool BRS62BBANA00 REFRIGERATOR
Whirlpool BRS62BBBNA00 REFRIGERATOR
Whirlpool BRS62BRANA00 REFRIGERATOR
Whirlpool BRS62BRBNA00 REFRIGERATOR
Whirlpool BRS62CBANA00 REFRIGERATOR
Whirlpool BRS62CBBNA00 REFRIGERATOR
Whirlpool BRS62CRANA00 REFRIGERATOR
Whirlpool BRS62CRBNA00 REFRIGERATOR
Whirlpool BRS70ABANA01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool BRS70ABANA02 REFRIGERATOR
Whirlpool BRS70BBANA00 SIDE BY SIDE REFRIGERATOR
Whirlpool BRS70BBANA01 REFRIGERATOR
Whirlpool BRS70CBANA00 REFRIGERATOR
Whirlpool BRS70DBANA00 REFRIGERATOR
Whirlpool BRS70DRANA00 REFRIGERATOR
Whirlpool BRS70EBANA00 REFRIGERATOR
  #2 (permalink)
Old 09-15-2017, 09:21 PM
Senior Member
PNWDrew is on a distinguished road
Default
There are several possibilities here. 1st question is if temps in fresh food and freezer section are normal?
1) Check your door gaskets; top and bottom doors, air leaks could cause it.
2) Look at back of freezer, you do not want to see any significant ice on back wall.
3) Does the fan in the freezer sound normal? A slow or dead fan might cause it.
Air blows up from the freezer through the damper in the back bottom to cool the top section, if that damper isn't opening/closing properly or airflow is poor moisture in the fresh food air will condense out on the cold damper door and freeze.
Whirlpool R0161050 Damper Control - AppliancePartsPros.com
  #3 (permalink)
Old 09-17-2017, 11:48 AM
Junior Member
Default
Thank you for your response. Door gaskets look good, there isn't any significant ice on the back wall and the fan in the freezer seems to be working as it should. We did take your advice and removed the damper unit. The door with the small spring seems to be working as it should with adjusting the temp. it is a manual damper and my husband adjusted the screw at the bottom, which he must have went the wrong was as it was warmer than it should be. There is a coil on the right side of the damper unit and we are not sure how that affects the damper. We took the whole damper unit out and left it open. Within 6-8 hours things were very very cold in the refrigerator. When my husband readjusted the damper and put it in we are experiencing the same issue. Does that coil on the side effect the coldness? I also noticed that when you open the freezer door and the refrigerator door at the same time the air blows stronger in the refrigerator. There are not any blocks that we are aware of. What would you suggest.
  #4 (permalink)
Old 09-17-2017, 01:25 PM
Senior Member
Default
The coil is part of the thermostat that tells the damper when to open/close. It is a sealed tube, so pressure changes in it correlate with temp.
If you run the unit without a damper it will become a freezer up top too as the 0-10deg air of the freezer is blown up top. The damper's job is to close to block air flow into the fridge and maintain fridge temps.
I do not think you should be able to easily depress the plastic plunger that pushes the damper door, if that plunger moves freely that sounds like a broken damper.
There is no adjustment for it, (or at least I've never adjusted one) so I'm not sure what screw you refer to.
As for airflow it does change when doors are opened, but if you have ice around the damper it probably is also in the return, where warmer fridge air is entering freezer to circulate. It's not always the case but I'd check if I was servicing it. You could let it thaw itself by unplugging the unit for 12-24 hours or find the return(s) and clear them yourself. I can't tell you where they are on that unit, bad memory on my part.
  #5 (permalink)
Old 09-17-2017, 03:17 PM
Junior Member
Default
I want to thank you so very much for taking time out of your day to respond to my question. I have gone ahead and ordered the damper you recommended. I will let the fridge sit for 12 or so hours just in case there is ice in the returns and install the new damper unit. Again thank you very much!
  #6 (permalink)
Old 09-17-2017, 03:33 PM
Senior Member
Default
Your welcome. I hope I'm right!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag bottom mount freezer NorrisA Refrigerator & Freezer Repair 0 08-19-2016 05:01 PM
Kenmore bottom-mount refrigerator (Model #59665932404) ApplianceBudda Refrigerator & Freezer Repair 0 07-30-2013 04:04 PM
Ice forming in bottom of bottom mount freezer gordow Refrigerator & Freezer Repair 10 06-12-2013 08:29 PM
GE bottom mount freezer rjagger Refrigerator & Freezer Repair 1 05-20-2011 05:41 PM
Coils Inside Bottom Mount Freezer Freezing Up VS828 Refrigerator & Freezer Repair 1 03-16-2011 05:59 AM
