Discuss
Fridge isn't cool
 in
Refrigerator & Freezer Repair
My temp is staying around 60 F in the fridge section. Pulled out and checked all fans and they are
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge isn't cool
  #1 (permalink)
Old 09-14-2017, 03:03 PM
Junior Member
tgillenw is on a distinguished road
Default Fridge isn't cool
Model Number: LFHB2741PFBA   Brand: Frigidaire   Age: 1 - 5 years
My temp is staying around 60 F in the fridge section. Pulled out and checked all fans and they are working. However, the compressor seems to be rather hot. I've tried resetting the temp panel. Nothing is helping. Any thoughts on what could be wrong. This fridge is only a little over a year old
Related Models
Frigidaire LFHI1826LB0 REFRIGERATOR
Frigidaire LFHI1826LM0 REFRIGERATOR
Frigidaire LFHI1826LW0 REFRIGERATOR
Frigidaire LFHT1513LB0 REFRIGERATOR
Frigidaire LFHT1513LB1 REFRIGERATOR
Frigidaire LFHT1513LB2 REFRIGERATOR
Frigidaire LFHT1513LB3 REFRIGERATOR
Frigidaire LFHT1513LB4 REFRIGERATOR
Frigidaire LFHT1513LB5 REFRIGERATOR
Frigidaire LFHT1513LW0 REFRIGERATOR
Frigidaire LFHT1513LW1 REFRIGERATOR
Frigidaire LFHT1513LW2 REFRIGERATOR
Frigidaire LFHT1513LW3 REFRIGERATOR
Frigidaire LFHT1513LW4 REFRIGERATOR
Frigidaire LFHT1513LW5 REFRIGERATOR
Frigidaire LFHT1713LB0 REFRIGERATOR
Frigidaire LFHT1713LB1 REFRIGERATOR
Frigidaire LFHT1713LB2 REFRIGERATOR
Frigidaire LFHT1713LB3 REFRIGERATOR
Frigidaire LFHT1713LQ2 REFRIGERATOR
Frigidaire LFHT1713LQ3 REFRIGERATOR
Frigidaire LFHT1713LW0 REFRIGERATOR
Frigidaire LFHT1713LW1 REFRIGERATOR
Frigidaire LFHT1713LW2 REFRIGERATOR
Frigidaire LFHT1713LW3 REFRIGERATOR
Frigidaire LFHT1817LB0 REFRIGERATOR
Frigidaire LFHT1817LB1 REFRIGERATOR
Frigidaire LFHT1817LB2 REFRIGERATOR
Frigidaire LFHT1817LB3 FRIGIDAIRE/REFRIGERATOR
Frigidaire LFHT1817LB4 REFRIGERATOR
Frigidaire LFHT1817LF0 REFRIGERATOR
Frigidaire LFHT1817LF1 REFRIGERATOR
Frigidaire LFHT1817LF2 REFRIGERATOR
Frigidaire LFHT1817LF3 FRIGIDAIRE/REFRIGERATOR
Frigidaire LFHT1817LF4 REFRIGERATOR
Frigidaire LFHT1817LR1 REFRIGERATOR
Frigidaire LFHT1817LR2 REFRIGERATOR
Frigidaire LFHT1817LR3 FRIGIDAIRE/REFRIGERATOR
Frigidaire LFHT1817LR4 REFRIGERATOR
Frigidaire LFHT1817LW0 REFRIGERATOR
Frigidaire LFHT1817LW1 REFRIGERATOR
Frigidaire LFHT1817LW2 REFRIGERATOR
Frigidaire LFHT1817LW3 FRIGIDAIRE/REFRIGERATOR
Frigidaire LFHT1817LW4 REFRIGERATOR
Frigidaire LFHT2117LB0 REFRIGERATOR
Frigidaire LFHT2117LB1 REFRIGERATOR
Frigidaire LFHT2117LW0 REFRIGERATOR
Frigidaire LFHT2117LW1 REFRIGERATOR
Frigidaire LFHT2117LW2 REFRIGERATOR
 LFN480CE Air Conditioner
Frigidaire LFTR1512LW0 REFRIGERATOR
Frigidaire LFTR1814LB0 REFRIGERATOR
Frigidaire LFTR1814LB1 REFRIGERATOR
Frigidaire LFTR1814LB2 REFRIGERATOR
Frigidaire LFTR1814LB3 REFRIGERATOR
Frigidaire LFTR1814LB4 REFRIGERATOR
Frigidaire LFTR1814LB6 REFRIGERATOR
Frigidaire LFTR1814LW0 REFRIGERATOR
Frigidaire LFTR1814LW1 REFRIGERATOR
Frigidaire LFTR1814LW2 REFRIGERATOR
Frigidaire LFTR1814LW3 REFRIGERATOR
Frigidaire LFTR1814LW4 REFRIGERATOR
Frigidaire LFTR1814LW5 REFRIGERATOR
Frigidaire LFTR1814LW6 REFRIGERATOR
 LFU480CE Air Conditioner
Frigidaire LFUH21F7LM0 FREEZER
Frigidaire LFUH21F7LM1 FREEZER
Frigidaire LFUH21F7LM2 FREEZER
Frigidaire LFUS2613LE0 REFRIGERATOR
Frigidaire LFUS2613LE1 REFRIGERATOR
Frigidaire LFUS2613LE2 REFRIGERATOR
Frigidaire LFUS2613LE3 REFRIGERATOR
Frigidaire LFUS2613LF0 REFRIGERATOR
Frigidaire LFUS2613LF1 REFRIGERATOR
Frigidaire LFUS2613LF2 REFRIGERATOR
Frigidaire LFUS2613LF3 REFRIGERATOR
Frigidaire LFUS2613LM0 REFRIGERATOR
Frigidaire LFUS2613LM1 REFRIGERATOR
Frigidaire LFUS2613LM2 REFRIGERATOR
Frigidaire LFUS2613LM3 REFRIGERATOR
Frigidaire LFUS2613LP0 REFRIGERATOR
Frigidaire LFUS2613LP1 REFRIGERATOR
Frigidaire LFUS2613LP2 REFRIGERATOR
Frigidaire LFUS2613LP3 REFRIGERATOR
Frigidaire LFW201EW0 WASHER
 LFX21960ST Refrigerator
 LFX21971ST Refrigerator
 LFX21975ST Refrigerator
 LFX21980ST Refrigerator
 LFX23961SB Refrigerator
 LFX23961ST Refrigerator
 LFX23961SW Refrigerator
 LFX25950SB Refrigerator
 LFX25950SW Refrigerator
 LFX25950TT Refrigerator
 LFX25960SB Refrigerator
 LFX25960ST Refrigerator
 LFX25960SW Refrigerator
 LFX25960TT Refrigerator
 LFX25961SB Refrigerator
 LFX25961ST Refrigerator
 LFX25961SW Refrigerator
 LFX25971SB Refrigerator
 LFX25971ST Refrigerator
 LFX25971SW Refrigerator
 LFX25975SB Refrigerator
 LFX25975ST Refrigerator
  #2 (permalink)
Old 09-15-2017, 11:01 PM
Senior Member
PNWDrew is on a distinguished road
Default
Is freezer is cold, 10deg F or around there? Ice cream is a nice way to check for temps below 15 degrees, above that it'll begin to soften.
Some quick checks:
1) Door switch in top section? Push it to ensure that light is turning off, a bulb staying on can create a lot of heat.
2)Air flowing out of vents in tower on back wall of fridge? You may need to have door switch depressed for the fan to run. It blows air up into fridge section through a damper that open/closes as needed. It may be delayed a little after you press the door switch in.
If no air is making it into fridge section I think you'll need to pull that rear wall apart to access damper, if it is frozen closed or broken that's your issue.
3)Return air ducts... air blown up must be able to return to freezer, I'm not 100% sure where they are on this machine, probably back corners of the upper compartment. They may be visible from inside freezer section too; up in freezer ceiling.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fridge cool, freezer cool stavros Refrigerator & Freezer Repair 0 03-10-2014 12:10 AM
Fridge won't cool Wildrat Refrigerator & Freezer Repair 2 04-27-2010 04:50 PM
Fridge Does Not Cool Below 40 Overland Refrigerator & Freezer Repair 1 07-01-2009 12:58 PM
freezer cool, fridge too cool Maddyrosedad Refrigerator & Freezer Repair 5 02-12-2009 07:46 PM
My Fridge won't cool vxmolina4 Refrigerator & Freezer Repair 1 10-16-2008 06:18 PM
