Discuss
Light work not running
 in
Refrigerator & Freezer Repair
I'll try to keep this short, any help appreciated. About a month ago , even though this darn upright freezer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Light work not running
  #1 (permalink)
Old 09-14-2017, 11:17 AM
Junior Member
davi1td is on a distinguished road
Default Freezer Light working but not running
Model Number: LFFH20F3QWC   Brand: Frigidaire   Age: 1 - 5 years
About a month ago , even though this darn upright freezer is only 2 years old ... open it to find everything thawed! After cleaning up the mess I plugged it back in and it worked, so I thought. It literally stuck on, I monitored it going past -40!
Played with the thermostat and then it stuck off. I had already ordered a evaporator motor, and now a thermostat. I installed them and had been monitoring everything for about 2 weeks, everything is fine, I have a remote temp sensor which monitors very often, so I know there where no problems.
Today I opened it to do a final cleaning and get ready to use it, had door open for about 10 minutes, which of course at some point the compressor and fan kick in, no problem with that, a few minutes later I walk by and notice I hear nothing running and knew that couldn't be right, I open the door and sure enough, nothing running and its registering over 40. I unplugged and re-plugged and messed with the temperature control, still nothing. Frustrated, I walk away and about 5-10 minutes later I hear the distinct click when the compressor kicks on, I go over and sure enough it's running.
Based on what I described could that have been normal? If not what other parts do I need to check? Run Capacitor? If it's the Run Capacitor could it behave this way or would it not work at all? Also when this happened I turned the temp control and heard no clicks.
-TD
Related Models
Frigidaire LFFH21F7HWA FREEZER
Frigidaire LFFH21F7HWB FREEZER
Frigidaire LFFH21F7HWC FREEZER
Frigidaire LFFH21F7HWD FREEZER
Frigidaire LFFH21F7HWE FREEZER
Frigidaire LFFH21F7HWF FREEZER
Frigidaire LFFH21F7HWG FREEZER
Frigidaire LFFH21F7HWH FREEZER
Frigidaire LFFH21F7HWJ FREEZER
Frigidaire LFFN15M5HWA FREEZER
Frigidaire LFFN15M5HWB FREEZER
Frigidaire LFFU1153DW0 Frigidaire/freezer
Frigidaire LFFU1153DW1 Frigidaire/freezer
Frigidaire LFFU1153DW2 Frigidaire/freezer
Frigidaire LFFU1153DW3 Frigidaire/freezer
Frigidaire LFFU1424DW0 Frigidaire/freezer
Frigidaire LFFU1424DW1 Frigidaire/freezer
Frigidaire LFFU1424DW10 FREEZER
Frigidaire LFFU1424DW11 FREEZER
Frigidaire LFFU1424DW12 FREEZER
Frigidaire LFFU1424DW13 FREEZER
Frigidaire LFFU1424DW14 FREEZER
Frigidaire LFFU1424DW15 FREEZER
Frigidaire LFFU1424DW16 FREEZER
Frigidaire LFFU1424DW2 Frigidaire/freezer
Frigidaire LFFU1424DW3 Frigidaire/freezer
Frigidaire LFFU1424DW4 Frigidaire/freezer
Frigidaire LFFU1424DW5 Frigidaire/freezer
Frigidaire LFFU1424DW6 FREEZER
Frigidaire LFFU1424DW7 FREEZER
Frigidaire LFFU1424DW8 FREEZER
Frigidaire LFFU1424DW9 FREEZER
Frigidaire LFFU1465DW0 Frigidaire/freezer
Frigidaire LFFU1465DW1 Frigidaire/freezer
Frigidaire LFFU1465DW2 Frigidaire/freezer
Frigidaire LFFU1465DW3 Frigidaire/freezer
Frigidaire LFFU1465DW4 Frigidaire/freezer
Frigidaire LFFU1465DW5 Frigidaire/freezer
Frigidaire LFFU1465DW6 Frigidaire/freezer
Frigidaire LFFU1466GW0 FREEZER
Frigidaire LFFU1466GW1 FREEZER
Frigidaire LFFU1466GW2 FREEZER
Frigidaire LFFU1466GW3 FREEZER
Frigidaire LFFU14F5HWA FREEZER
Frigidaire LFFU14F5HWB FREEZER
Frigidaire LFFU14F5HWC FREEZER
Frigidaire LFFU14F5HWD FREEZER
Frigidaire LFFU14F5HWE FREEZER
Frigidaire LFFU14F5HWF FREEZER
Frigidaire LFFU14F5HWG FREEZER
Frigidaire LFFU14F5HWH FREEZER
Frigidaire LFFU14F5HWJ FREEZER
Frigidaire LFFU14F5HWK FREEZER
Frigidaire LFFU14F5HWL FREEZER
Frigidaire LFFU14F5HWM FREEZER
Frigidaire LFFU14F5HWN FREEZER
Frigidaire LFFU1765DW0 Frigidaire/freezer
Frigidaire LFFU1765DW1 Frigidaire/freezer
Frigidaire LFFU1765DW11 Frigidaire/freezer
Frigidaire LFFU1765DW12 Frigidaire/freezer
Frigidaire LFFU1765DW13 Frigidaire/freezer
Frigidaire LFFU1765DW14 Frigidaire/freezer
Frigidaire LFFU1765DW15 Frigidaire/freezer
Frigidaire LFFU1765DW16 FREEZER
Frigidaire LFFU1765DW2 Frigidaire/freezer
Frigidaire LFFU1765DW3 Frigidaire/freezer
Frigidaire LFFU1765DW4 Frigidaire/freezer
Frigidaire LFFU1765DW5 Frigidaire/freezer
Frigidaire LFFU1765DW6 Frigidaire/freezer
Frigidaire LFFU1765DW8 Frigidaire/freezer
Frigidaire LFFU1765DW9 Frigidaire/freezer
Frigidaire LFFU1766GW1 FREEZER
Frigidaire LFFU1766GW2 FREEZER
Frigidaire LFFU1766GW3 FREEZER
Frigidaire LFFU1766GW4 FREEZER
Frigidaire LFFU17F5HWA FREEZER
Frigidaire LFFU17F5HWB FREEZER
Frigidaire LFFU17F5HWC FREEZER
Frigidaire LFFU17F5HWD FREEZER
Frigidaire LFFU17F5HWE FREEZER
Frigidaire LFFU17F5HWF FREEZER
Frigidaire LFFU17F5HWG FREEZER
Frigidaire LFFU17F5HWH FREEZER
Frigidaire LFFU17F5HWJ FREEZER
Frigidaire LFFU17F5HWK FREEZER
Frigidaire LFFU17F5HWL FREEZER
Frigidaire LFFU2065DW0 Frigidaire/freezer
Frigidaire LFFU2065DW1 Frigidaire/freezer
Frigidaire LFFU2065DW10 Frigidaire/freezer
Frigidaire LFFU2065DW2 Frigidaire/freezer
Frigidaire LFFU2065DW3 Frigidaire/freezer
Frigidaire LFFU2065DW4 Frigidaire/freezer
Frigidaire LFFU2065DW5 Frigidaire/freezer
Frigidaire LFFU2065DW6 Frigidaire/freezer
Frigidaire LFFU2065DW7 Frigidaire/freezer
Frigidaire LFFU2065DW8 Frigidaire/freezer
Frigidaire LFFU2065DW9 Frigidaire/freezer
Frigidaire LFFU2067DS0 Frigidaire/freezer
Frigidaire LFGF3014LBA GAS RANGE
Frigidaire LFGF3014LBB GAS RANGE
Frigidaire LFGF3014LBC GAS RANGE
Frigidaire LFGF3014LWA GAS RANGE
Frigidaire LFGF3014LWB GAS RANGE
Frigidaire LFGF3014LWC GAS RANGE
Frigidaire LFGF3022LSA GAS RANGE
Frigidaire LFGF3022LSB GAS RANGE
Frigidaire LFGF3022LSC GAS RANGE
Frigidaire LFGF3022LSD GAS RANGE
Frigidaire LFGF3022LWA GAS RANGE
Frigidaire LFGF3022LWC GAS RANGE
Frigidaire LFGF3027LBA GAS RANGE
Frigidaire LFGF3027LBB GAS RANGE
Frigidaire LFGF3027LSA GAS RANGE
Frigidaire LFGF3027LSB GAS RANGE
Frigidaire LFGF3027LSC GAS RANGE
Frigidaire LFGF3027LWA GAS RANGE
Frigidaire LFGF3027LWB GAS RANGE
Frigidaire LFHI1826LB0 REFRIGERATOR
Frigidaire LFHI1826LM0 REFRIGERATOR
Frigidaire LFHI1826LW0 REFRIGERATOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frig light and controls don't light. Cooling and freezer work fine. RONWALKER Refrigerator & Freezer Repair 0 02-27-2014 01:38 PM
KITCHENAID Built in not working, lights work but nothing is running placerappliancenick Refrigerator & Freezer Repair 0 12-06-2013 11:14 AM
Lock light and Clean light indicator does not work Donna J Oven Repair (including Ranges and Cooktops) 1 12-15-2012 04:59 AM
oven wont work after running self clean kohel Oven Repair (including Ranges and Cooktops) 0 08-31-2012 02:59 PM
Range Light and Nite light won't work Bms229 Microwave Repair 4 12-23-2009 11:22 PM
