Discuss
Frigidaire damper motor constantly running
 in
Refrigerator & Freezer Repair
My side by side has been giving me some trouble, looking for first thing to troubleshoot. Every so often, my
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidaire damper motor constantly running
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-12-2017, 09:36 PM
Junior Member
Bumblebeebunny is on a distinguished road
Default Frigidaire damper motor constantly running
Model Number: Ffhs2313ls1   Brand: Frigidaire   Age: More than 10 years
Every so often, my fridge gets unhappy, and the display shows odd temps, like freezer at -21 and fridge at +58, but then i cycle power and temps are ok. A few times recently i have seen ice coming out of the damper (on fridge side), which i clear away, and things are okay for a while.
Last night I noticed the damper was constantly cycling open for about 10 sec, then close for about 10 sec, and repeated this for hours. I felt cold air coming out, and temps displayed looked okay, so I went to bed. I think the compressor was on for a really long time too, but I dont know what a normal cycle should be.
Today, the fridge started beeping 5 times in a row, every 30 seconds, but temps looked okay. I initiated a defrost, then after that complted, I unplugged it, opened te doors for a while, and plugged back in (based on some advice I saw for 5 beeps).
So far, things seem to be okay -- fridge is cooling back down. But this sort of thing seems to happen a lot now.
How often should damper motor be actuating once fridge is at temperature? does frequent movement indicate a problem with temp sensors, or controller?
Also, when I see nonsense temperatures displayed, is that a thermistor issue, or motherboard? I was measuring about 13.7 kOhm on both, but the service control sheet doesnt have a table.
As an aside, I noticed that my seal is torn on the fridge side, near the bottom ( the magnet side is smooth, but there is a tear on the edge between magnet and door). It seems sealed still when the door is closed, but not sure if there is like a stream of humidity or warmth or something scrwing with the controls?
Thanks for any suggestions on what to check next
Related Models
Frigidaire FFHS2313LS1 REFRIGERATOR
Frigidaire FFHS2313LS2 REFRIGERATOR
Frigidaire FFHS2313LS3 REFRIGERATOR
Frigidaire FFHS2313LS4 REFRIGERATOR
Frigidaire FFHS2322MB0 REFRIGERATOR
Frigidaire FFHS2322MM0 REFRIGERATOR
Frigidaire FFHS2322MQ0 REFRIGERATOR
Frigidaire FFHS2322MS0 REFRIGERATOR
Frigidaire FFHS2322MW0 REFRIGERATOR
Frigidaire FFHS2611LB0 REFRIGERATOR
Frigidaire FFHS2611LB1 REFRIGERATOR
Frigidaire FFHS2611LB2 REFRIGERATOR
Frigidaire FFHS2611LQ0 REFRIGERATOR
Frigidaire FFHS2611LQ1 REFRIGERATOR
Frigidaire FFHS2611LQ2 REFRIGERATOR
Frigidaire FFHS2611LS0 REFRIGERATOR
Frigidaire FFHS2611LS1 REFRIGERATOR
Frigidaire FFHS2611LS2 REFRIGERATOR
Frigidaire FFHS2611LW0 REFRIGERATOR
Frigidaire FFHS2611LW1 REFRIGERATOR
Frigidaire FFHS2611LW2 REFRIGERATOR
Frigidaire FFHS2612LS0 REFRIGERATOR
Frigidaire FFHS2612LS1 REFRIGERATOR
Frigidaire FFHS2612LS2 REFRIGERATOR
Frigidaire FFHS2622MB0 REFRIGERATOR
Frigidaire FFHS2622MH0 REFRIGERATOR
Frigidaire FFHS2622MM0 REFRIGERATOR
Frigidaire FFHS2622MQ0 REFRIGERATOR
Frigidaire FFHS2622MS0 REFRIGERATOR
Frigidaire FFHS2622MW0 REFRIGERATOR
Frigidaire FFHS2624LE0 REFRIGERATOR
Frigidaire FFHS2624LM0 REFRIGERATOR
Frigidaire FFHS2624LP0 REFRIGERATOR
Frigidaire FFHS2624LS0 REFRIGERATOR
Frigidaire FFHS2626LE0 REFRIGERATOR
Frigidaire FFHS2626LP0 REFRIGERATOR
Frigidaire FFHS2626LS0 REFRIGERATOR
Frigidaire FFHT1513LB3 REFRIGERATOR
Frigidaire FFHT1513LB4 REFRIGERATOR
Frigidaire FFHT1513LB5 REFRIGERATOR
Frigidaire FFHT1513LQ0 REFRIGERATOR
Frigidaire FFHT1513LQ1 REFRIGERATOR
Frigidaire FFHT1513LQ2 REFRIGERATOR
Frigidaire FFHT1513LQ3 REFRIGERATOR
Frigidaire FFHT1513LQ4 REFRIGERATOR
Frigidaire FFHT1513LQ5 REFRIGERATOR
Frigidaire FFHT1513LQ6 REFRIGERATOR
Frigidaire FFHT1513LS0 REFRIGERATOR
Frigidaire FFHT1513LS3 REFRIGERATOR
Frigidaire FFHT1513LS4 REFRIGERATOR
Frigidaire FFHT1513LS5 REFRIGERATOR
Frigidaire FFHT1513LW0 REFRIGERATOR
Frigidaire FFHT1513LW1 REFRIGERATOR
Frigidaire FFHT1513LW2 REFRIGERATOR
Frigidaire FFHT1513LW3 REFRIGERATOR
Frigidaire FFHT1513LW4 REFRIGERATOR
Frigidaire FFHT1513LW5 REFRIGERATOR
Frigidaire FFHT1513LW6 REFRIGERATOR
Frigidaire FFHT1513LZ3 REFRIGERATOR
Frigidaire FFHT1513LZ4 REFRIGERATOR
Frigidaire FFHT1513LZ5 REFRIGERATOR
Frigidaire FFHT1513LZ6 REFRIGERATOR
Frigidaire FFHT1515LW0 REFRIGERATOR
Frigidaire FFHT1515LW1 REFRIGERATOR
Frigidaire FFHT1515LW2 REFRIGERATOR
Frigidaire FFHT1515LW3 REFRIGERATOR
Frigidaire FFHT1515LW4 REFRIGERATOR
Frigidaire FFHT1515LW5 REFRIGERATOR
Frigidaire FFHT1713LQ0 REFRIGERATOR
Frigidaire FFHT1713LQ1 REFRIGERATOR
Frigidaire FFHT1713LQ2 REFRIGERATOR
Frigidaire FFHT1713LQ3 REFRIGERATOR
Frigidaire FFHT1713LQ4 REFRIGERATOR
Frigidaire FFHT1713LQ5 FRIGIDAIRE/REFRIGERATOR
Frigidaire FFHT1713LW0 REFRIGERATOR
Frigidaire FFHT1713LW1 REFRIGERATOR
Frigidaire FFHT1713LW2 REFRIGERATOR
Frigidaire FFHT1713LW3 REFRIGERATOR
Frigidaire FFHT1713LW4 REFRIGERATOR
Frigidaire FFHT1713LW5 REFRIGERATOR
Frigidaire FFHT1713LZ4 REFRIGERATOR
Frigidaire FFHT1713LZ5 REFRIGERATOR
Frigidaire FFHT1715LB0 REFRIGERATOR
Frigidaire FFHT1715LB1 REFRIGERATOR
Frigidaire FFHT1715LB2 REFRIGERATOR
Frigidaire FFHT1715LB3 REFRIGERATOR
Frigidaire FFHT1715LB4 REFRIGERATOR
Frigidaire FFHT1715LB5 REFRIGERATOR
Frigidaire FFHT1715LW0 REFRIGERATOR
Frigidaire FFHT1715LW1 REFRIGERATOR
Frigidaire FFHT1715LW2 REFRIGERATOR
Frigidaire FFHT1715LW3 REFRIGERATOR
Frigidaire FFHT1715LW4 REFRIGERATOR
Frigidaire FFHT1715LW5 REFRIGERATOR
Frigidaire FFHT1725LK0 REFRIGERATOR
Frigidaire FFHT1725LK1 REFRIGERATOR
Frigidaire FFHT1725LK2 REFRIGERATOR
Frigidaire FFHT1725LK3 REFRIGERATOR
Frigidaire FFHT1725LK4 REFRIGERATOR
Frigidaire FFHT1725LK5 REFRIGERATOR
Frigidaire FFHT1725LK6 REFRIGERATOR
Frigidaire FFHT1725LS0 REFRIGERATOR
Frigidaire FFHT1725LS1 REFRIGERATOR
Frigidaire FFHT1725LS2 REFRIGERATOR
Frigidaire FFHT1725LS3 REFRIGERATOR
Frigidaire FFHT1725LS4 REFRIGERATOR
Frigidaire FFHT1725LS5 REFRIGERATOR
Frigidaire FFHT1725LS6 REFRIGERATOR
Frigidaire FFHT1814LB0 REFRIGERATOR
Frigidaire FFHT1814LB1 REFRIGERATOR
Frigidaire FFHT1814LB2 REFRIGERATOR
Frigidaire FFHT1814LB3 REFRIGERATOR
Frigidaire FFHT1814LB4 REFRIGERATOR
Frigidaire FFHT1814LM0 REFRIGERATOR
Frigidaire FFHT1814LM1 REFRIGERATOR
Frigidaire FFHT1814LM2 REFRIGERATOR
Frigidaire FFHT1814LM3 REFRIGERATOR
Frigidaire FFHT1814LM4 REFRIGERATOR
Frigidaire FFHT1814LW0 REFRIGERATOR
Frigidaire FFHT1814LW1 REFRIGERATOR
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire ice maker auger constantly running Xjohn Refrigerator & Freezer Repair 0 09-06-2016 04:02 PM
Refrigerator constantly running, damper moving frequently Jplasse Refrigerator & Freezer Repair 4 11-03-2012 02:24 AM
Frigidaire Damper motor continuasly cycling phil.woodell@verizon.net Refrigerator & Freezer Repair 3 08-02-2012 09:07 AM
Motor constantly running not cooling linda1962 Refrigerator & Freezer Repair 0 05-28-2011 05:58 AM
stirrer motor constantly running dsrdon Microwave Repair 1 01-25-2010 06:06 PM
