The ice maker solenoid vale works when I hot wire 1120V to it. I can hear it pulling in. When I check voltage at the connecter, I get 120V. when I plug in the solenoid voltage drops to like 18 V. any ideas??all this started because the valve was leaking.everything else is working. Help please...
