I just had this unit installed last week by a contractor who was performing all the plumbing work for our finished basement.
He never tested the unit and when I started it water sprayed all inside of the unit cabinet from the drain pump. It turns out he connected the drain line to the vent tube instead of the drain pump.
My question is will the water being sprayed on all of the electronic components potentially cause any damage to the unit?
